Old 11-30-2014, 12:39 PM   #1
mje
2013 30' Flying Cloud
New Truck Hitch Setup Help
Wife and I recently bought a new 2015 GMC 2500HD Duramax 4x4 Crewcab. I need to set up Propride P3 hitch to connect 30' FC and 2500HD. I currently have 1400# spring bars included in the P3 setup. Everything as it is, I don't think I even need WD as the rear dropped only 1" and front remained unchanged without applying any pressure on the springbars. So my questions are: 1) should I leave WD spring bars off in that setup and still considered safe? 2) Do I need to adjust the stinger? 3) What is other concerns I need to be made aware?
ID:	227755   Click image for larger version
mje is offline   Reply With Quote
Old 11-30-2014, 01:44 PM   #2
2007 22' International CCD
You can put as much or as little tension on the bars as you want. Did Sean recommend the 1400 pound bars? If so just put some tension on them to bring the FRONT wheel wells back to about the same height as before you hitched. It will make a difference in the handling if you don't put some weight transfer in. It takes some careful experimenting to determine how much to raise the PP spring bar jacks. I use 5-6 inches on my setup with 1000 pound bRs to get good handling and eliminate porpoising under way. The bars aware there for a reason.
Old 11-30-2014, 01:45 PM   #3
I'd also suggest calling Sean at ProPride and see what he says--he's the expert.
Old 11-30-2014, 02:19 PM   #4
mje
More pics after some adjustments
Actually, Sean recommended 1400# bars only because my VW Touareg was my only TV at the time. I understand that 1400# bars is too much for 2500HD as it will be too hard on the trailer.
I made a few tweaks to the stinger and the yoke. I made some measurements:
3-1/4" drop at the jack from unhooked to fully hooked
Rear axle: 10-1/2" to 9"
Front axle: 9" to 9 1/4"
Pictures show before and after hooking and the result of modified stringer/yoke. You can see that I have bars removed as a test.
I also sent an email to Steve.
ID:	227764   Click image for larger version
Old 11-30-2014, 02:21 PM   #5
Talk to Sean and see if you need to swap out bars. It may be too stif.
Curt Mfg. Weight Distributing Hitch Setup COArgosy78 Hitches, Couplers & Balls 20 06-28-2016 07:42 AM
Reese Dual Cam & HD truck setup question Ridgerunner3 Hitches, Couplers & Balls 6 10-23-2011 11:24 AM
Equal-I-Zer Hitch Setup Report JimGolden Hitches, Couplers & Balls 95 01-23-2011 08:03 PM
Hitch Setup Jabba Hitches, Couplers & Balls 2 10-04-2002 10:33 AM
