Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 12-23-2012, 05:34 PM   #1
Perspective's Avatar
2017 27' Flying Cloud
2007 25' Safari
North Port , Florida
New to towing and airstream F-150/25ft Safari
We are new Airstreamers, having camped in teardrop for the last few years, we decided to take a leap for retirement and got a 2007 Safari 25ft. Paperwork says the Airstream has a GVWR of 7000# and a tongue weight of 860#.
Hoping to explore the country.
I have been reading all the towing and truck forums and to be honest it just becomes more confusing.
Currently we are about to purchase a 2010 Ford F-150 XLT crew cab, 5.4 V8, axle 3.55, Wheelbase 145", with tow package. I believe this will tow 9600#, but after reading the DATA plate on the door of the truck it states that the trucks GVWR is 7300.
Will we be OK with this??
Will it do the job?
Will I learn to back her up?
I was choosing the F-150 because I have heard very good things about its ride and driving comfort.
Thank you all in advance, these forums have provided us with such valuable information.
Tom
Perspective is offline   Reply With Quote
Old 12-23-2012, 05:53 PM   #2
2007 27' Classic FB
2001 25' Excella
2001 30' Classic S/O
2022 Atlas
Western slope , Colorado
Welcome to streaming.
Get a good wdh, good brake controller, learn by taking your time. Others have been there and will understand. Relax and have fun......
You are ok learn about gvwr, tow rating, two separate but not independent measures get some good tires visit the cat scales get level....OMG. THIS IS GONNA BE FUN!!!
"If you come to a fork in the road, take it."
Yogi Berra
Streamside is offline   Reply With Quote
Old 12-23-2012, 05:57 PM   #3
duffergeek's Avatar
2014 30' FB FC Bunk
Langley , Washington
I believe that is the GVWR for the truck itself, not its towing capacity.
duffergeek is offline   Reply With Quote
Old 12-23-2012, 06:32 PM   #4
A W Warn's Avatar
2000 25' Safari
That truck will pull the trailer, but whether it will be a satisfactory tow vehicle for you depends on many things like:
1. How much weight you carry in the truck - tongue weight and 2 passengers will take up a good portion of the payload capacity. Generator, tools, and other "stuff" may quickly max out the payload.
2. If you go into the mountains you will get down into the lower gears and maybe have to creep up steep grades. Though, if you have a 6 speed transmission, performance will be much better than a 4 speed.
3. The GCRW (gross combined rated weight) should be in a chart in the owners manual. You will have to look for the setup of your specific vehicle to see if it is adequate.
4. Etc, Etc,
With a half ton (Chevy crew with tow) I had prior to my present truck, I found I was not willing to get by with less stuff than I wanted to bring along, so I moved to a larger truck. I am not saying it is unsafe to use a lighter tow vehicle. But, my personal opinion is; I think it's safer to have a tow vehicle that is heavier than the trailer, with extra capacity, than to use a lighter vehicle and carry weight and/or tow loads right at the vehicles' maximum capacity.
You will get all kinds of opinions. Some will disagree with me. Only you can make the decision of what will work for you.
Alan
Old 12-23-2012, 06:38 PM   #5
2019 27' Globetrotter
Missouri Valley , Iowa
Tom,
We tow an '02 30' Classic w/slide w our '10 F150 S crew, 6.5 box and 5.4 eng and 3.73 gears. Trailer weighs 8,400 empty and 9,000+ w/ water and propane full. Hitch wt. is 890# fully loaded (weighed at my local coop scales). It may not be fast in the mountains but it does the job! We are headed for SW FL from SW IA on Thursday and it makes that trip easily!!! I think you'll be fine with your lighter trailer.
Dan
Farmer Dan is offline   Reply With Quote
Old 12-23-2012, 06:44 PM   #6
Travel Bird's Avatar
2012 27' FB International
Denver , Colorado
Yes, your F150 will tow a 25' just fine. Get a good hitch and brake controller. We tow a 27' International with our Ford Expedition with a Hensley hitch and Direclink brake controller. I wrote a blog post about our maiden voyage last month and our trip to Can-Am RV to dial in our Hensley! Good luck and Merry Christmas!
Anna
Blog: Glamper~An Airstream Diary
www.glamperanairstreamdiary.com
WBCCI #4846, WBCCI DenCO Unit
Air #62992
Travel Bird is offline   Reply With Quote
Old 12-23-2012, 06:54 PM   #7
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
A good 1/2 ton, properly set up with a weight-distributing hitch and brake controller, is plenty for a 25'. The tow package will include a transmission cooler and oil cooler, so there are no worries there. As for backing up... all I can say is unless you are 100% sure of what is back there, use a spotter or get a backup camera. There are many that can be wired to replace one of the rear marker lights. Too many dented corners on Airstreams... top and bottom... from posts, trees, vehicles...
A corner panel replacement is going to set you back $5000... so invest the $200-300 in a backup camera.
Friday is offline   Reply With Quote
Old 12-26-2012, 03:57 AM   #8
2007 25' Safari
Thank you all for the support. I have found a page, fordf150.net that pointed me in the right direction for the info I needed.
This will sure be a fun learning process for us. Fortunately for us, having lived on a sailboat for five years has us ready for some of the adventure.
Thank you all,
Tom
NOW to sell the Teardrop!
Old 12-26-2012, 06:15 AM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
First off, welcome to the Forums. We're glad to have you with us.
You're going to love the 25. We have a 2005 25FB, named Lucy, that we have used extensively. Lucy now has almost 1,200 nights and over 100,000 miles under her belt. We have not tired of her yet.
As to your questions about the half ton tow vehicle, it may somewhat depend upon how much you plan to carry and where you intend to go. Lucy weighs in at 7,400# ready to camp with an 850# tongue weight. If your half ton truck is loaded down with gear and passengers, you will probably be at or near the vehicle's load limit.
Check the tires that come on the vehicle that you are considering. Some half tons come with P rated (passenger car) tires. You are going to want LT rated (light truck) tires with at least a Load Range D rating.
You are also going to want to research quality weight distributing/sway control hitch systems. You also need to look at trailer brake controllers if your new vehicle does not come equipped with an integrated trailer brake controller.
We started out with a half ton tow vehicle. It was OK, but not really satisfactory. We didn't like the lack of pulling power on significant grades and the lack of payload capacity. We eventually moved on to 3/4 ton (gasoline) tow vehicles, and found these quite satisfactory. With the addition of a 3,000# truck camper, we now pull Lucy with a one ton diesel tow vehicle.
A half ton tow vehicle can probably do the job, but you will need to choose and set up carefully.
Good luck, and have some great Airstream adventures.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 12-26-2012, 07:41 AM   #10
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Sounds as if you're on the right track. The advice given on this site will serve you well. The only thing I might add is to choose your weight distributing hitch carefully. The choice you make should be with you for a long time. So don't rush into something. You will read volumes here on the hitches available. If your checking acct. can handle it you may look towards the Hensely style hitch. The users seem to really like them after getting over the learning curve with hitching/un-hitching. Take a trip to Camping World and you will see a good selection of other brands and styles. After reading a lot I've chosen to go the Anderson route for it's reasonable cost and simplicity. I've kept my other one with the heavy WD bars so if I don't like the Anderson I can always go back. It's a fine hitch and has served me well.
Just do some homework. Ask questions because I don't really think you can return it if you try one out and don't like it.
Good Luck. Enjoy many miles of safe towing and See ya on the road sometime.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-26-2012, 07:54 AM   #11
Vintage Kin
Fort Worth , Texas
Pro-Pride Hitch and TT disc brakes. DIREC-LINK brake controller.
Set up the weight-distribution on a certified scale so that the trailer tongue weight is properly applied.
As above, if you carry too much junk you may want a HD pickup. On the other hand, a 25' is not too large too be pulled by a car (see threads/posts by Andrew_T [Andrew Thomson, of CAN AM RV) as we all of us did in the 1960's and '70's.
The best tow vehicle is not a truck, the best tow vehicle is the one that also fills solo duties economically and can pull the trailer.
How many nights aboard, how many annual miles, etc, are all determining factors.
The TT is the more important choice (which you've made), but there is no requirement for a pickup truck for this trailer type. The design advantages of the TT mean that a wide variety of vehicles can be used.
So, no matter the TV, the hitch, the brakes and controller will all do well in keeping the pickup truck on the road. The TT can -- behind the right TV -- get through a slalom faster than can the pickup truck while solo. Set it up correctly, and choose best equipment. Those who do never go back to inferior equipment or procedures.
Old 12-26-2012, 12:36 PM   #12
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
I frequently see this reference to towing with cars in the '60's and '70's and comparing that to towing with cars today. As someone who spent 25 in the auto industry (product development and manufacturing) I think this statement while true is very misleading as to the suitability of tow vehicles today.
I'm not trying to stir up anything or pick on anyone, but after reading it so many times I feel I must speak up. The cars that were used as tow vehicles and the cars of today are just not the same. Most cars in the '60's etc used to tow were full size sedans or station wagons. These vehicles were actually much closer to todays pickups than todays cars. They featured such things as a separate frame and large axles and transmissions and they used engines with a lot of torque. When the oil embargo of the '70's hit, the industry was forced into making cars lighter and one way was to make the mechanical components lighter which ment they were not overdesigned as much as they used to be.
A quick example is that the axle used in full size Ford cars of this era is larger than any axle offered in today's F150. The standard F150 axle of today is just about the same size as Ford used in small V-8 midsize cars like the Fairlane and Mustang, and the super duper tow package axle is still smaller than the full size car axle of that era.
My point is that while the vehicles of today are much better than 40 years ago they are not designed with the same factors of safety on the mechanical components. Therefore when one chooses to overload a vehicle today you are putting a relatively large strain on many of the parts and may be much closer to mechanical failure than you think you are. Lots of comments can be made about offsetting features of todays technologies, like better lubes and I am perfectly aware of those. Just pointing out the difference in vehicle design over the last 40 odd years.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 12-26-2012, 01:40 PM   #13
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I have a 2006 F150 with the 4.6 lit V8. It tows pretty good for the 3-4 times per year we use it, but it does seem to lack power. Once I hook up, load up all our gear, kids, dogs, and fire wood I'm pretty sure I'm maxed out. If we were going out more, I would want the larger engine or a f250. Right now it's not worth the extra cost.
Not all those who wonder are lost.
Silverflames is offline   Reply With Quote
Old 12-26-2012, 01:51 PM   #14
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Back to the F150, it is about as good a match for your Airstream as any.
Payload. It's a half-ton, with the trailer on there keep the bed load light.
Hitch. You're new to towing, only the Propride/Hensley design can guarantee no trailer sway. Propride is about $2500 plus installation and tax, but worth it. Call Sean, Propride owner, he will probably answer the phone and help you select the right one and get it set up.
Backing up. Biggest problem with even the most experienced is backing into something, often a garage roof or tree branch. Have someone watch for obstacles, put one hand on the bottom of the steering wheel and turn the way you want the trailer to turn. Practice.
Brake controller. The truck may have one built-in from the factory. If not get a good one.
Big truck people want you to get a big truck, SUV people want you to get a SUV, the F150 is in the middle, as is your 25' Airstream.
Retirement is fabulous. We spend 6 months a year in our Airstream, travel and as Snowbirds. We have a new Dodge Express 1/2 ton 5.7 regular cab 120" wheelbase. A bargain to buy, tows and rides great, and when we unhook it is very easy to get around with.
doug k
Old 12-26-2012, 02:36 PM   #15
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
What is your posted maximum payload?
Should be on the same sticker in door jamb
Moflash is offline   Reply With Quote
Old 12-26-2012, 02:46 PM   #16
1969 29' Ambassador
On my f150 6950 lbs GAWR. The truck weighs about 5800 lbs, so that give me about 1100 lbs to play with.
Old 12-26-2012, 03:07 PM   #17
Moflash's Avatar
They are all different according to factory options they were ordered with.I think (and hope)it is higher than that.It should be stated exactly on the sticker that shows your GVWR.If it is only 1100# by the time you subtract your tongue weight and your WD hitch weight (that you will definitely need).You have have nothing left for passengers ,gear or propane.Also note that Ford allows 150lbs for a driver so if you weigh more than that subtract that amount from your maximum payload also.
I have already been down this road myself with my previous 2010 F150 5.4 Supercrew with max tow package and was shocked when I learned It was rated to pull almost 11,000lbs but its maximum payload capability was just 1340lbs total..
Better check the factor sticker to see what your truck was built to haul safely.
Old 12-26-2012, 03:35 PM   #18
dkottum's Avatar
While you're subtracting all that from payload allowance, add back in the amount that is transferred by the weight distribution hitch. In theory up to one third of tongue weight goes to the trailer axles, but you would have to weigh it all hooked up and loaded to know the exact amount.
This was brought up in another thread here today as well, surprising it is always set aside when it is quite significant.
doug k
Old 12-26-2012, 04:04 PM   #19
Moflash's Avatar
I believe if you do some research you will find that in reality the actual weight transfer to the trailer axle will be less than 100lbs.The majority of the weight distributed is transferred to the front axle of the tow vehicle.
But either way spend a little time at the weigh station as mentioned above so you know that you can safely tow with what you have.And that you do not overload your tow vehicle.
Old 12-26-2012, 04:30 PM   #20
dkottum's Avatar
Another way to think about it, which is a better handling F150?
One with 1,200# in the bed with no trailer attached (as it is designed to do).
Or one with 1,300# in the bed with an Airstream attached, and a weight distribution hitch distributing that weight among the two truck axles and the trailer axles.
doug k
