06-13-2014, 07:56 PM
2008 23' International
carlsbad
new to Airstream and large towing... help?
TOWING: 2008 23d
TRUCK: 2012 Ford F150 FX4 Ecoboost (400hp with mods)
QUESTION: I have a standard tow ball on my truck. My truck is set up for towing, has trailer brake control and tow setting for gear ratio and downshifting.
Do i need one of these special tow ball set ups (Sway bars...)?
I bought my Airstream in Texas and it is being shipped to me in San Diego and will be arriving in the next couple days.
THANKS!!!
06-13-2014, 08:11 PM
2012 27' Flying Cloud
W
, New England
At 4700# dry and a GVWR of 6300#, youay want to investigate a WD (weight distributing) hitch with some form of sway control.
There are (too) many threads on this topic. Try searching for Equal-I-zer, Reese, Andersen, Eaz-lift, Blue Ox, Hensley and ProPride for starters.
This link: http://www.serenitysys.com/rv/techni...omparison.html used to be the gold standard for comparison and is still very helpful, but dated.
This link: http://www.etrailer.com/faq-trailertowtips.aspx is pretty helpful for basic info.
Perhaps an ad?
http://rv-roadtrips.thefuntimesguide...izer_hitch.php
More "ads" here but in total, some good info:
http://www.mrtruck.net/wdh.htm
Good luck!
06-13-2014, 08:12 PM
carlsbad
Thank you do much SteveSueMac!!!
06-13-2014, 08:18 PM
carlsbad
SteveSueMac
What is your best recommendation out of these options based on my set up?
06-13-2014, 09:16 PM
W
, New England
I'm totally not qualified to answer that question. Sorry.
I replied to your PM with a lengthy list of things to think about and reasons why you might want one vs another.
I think the key is - you don't need it until you need it - and you will because you can not control everything around you. As a kid, seat belts were not even on the radar screen. For the past 30 years, I've worn them every minute in motion. No accidents (thank God) but I know I need those belts. Same with weight distribution and sway control.
Keep reading and asking questions. You'll make the right call for you!!
06-13-2014, 09:34 PM
2003 25' Safari
Riverside
Interested in your mods,on a gasser towing some are good some not so much
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
06-13-2014, 09:35 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Most ice cream parlors have more than one flavor on sale. The same goes with the tow vehicle discussions, hitch discussions and which trailer discussions.
The 23' models have a lighter weight (6,000 pounds GVW) that the wide body models (25' and longer) and are easily towable by the more modest tow vehicles. The 720 pound tongue weight in the factory literature is way lighter than reality.
So one needs to decide on how much stuff you want in both the trailer as well as the towing vehicle and see if there is enough capacity to carry all of it in terms of weight.
Good luck in your research.
06-13-2014, 09:37 PM
" You don't need it until you need it "
I think you will need a weight distribution hitch from the get go. For one, it will transfer weight back to the front steering tires. Second, WD hitches minimize " porpoising " when your rig goes over a bump, because it restricts the up and down movement between trailer and tow vehicle.
06-13-2014, 10:09 PM
1999 34' Excella
Hillsboro
Get a WD hitch system and sway protection.
Peace and Blessings..
Channing
WBCCI# 30676
06-14-2014, 09:44 AM
2011 31' Classic
Nellysford
, Virginia
Channing X 2. Don't leave home without it.
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
06-14-2014, 10:18 AM
Common Sense
I sometimes tow a 17' Casita with my 3/4 ton Dodge truck, and I use a WD anti sway hitch when I do, because it's better.
Do I have to have it? Obviously not, but it's better.
With that said, I would not tow a 23' Airstream around the block with a 1/2 ton truck, any 1/2 ton truck, without a WD hitch. But, this is only my opinion based on doing this since the '70's.
Regards,
Steve
06-14-2014, 11:51 AM
2006 25' Safari
St. Augustine
Cmmorsey, open your driver door on your truck and look for the sticker that says "combined weight for occupants and cargo should never exceed---- kg or ---lbs. What is the weight figure?
Check your hitch on the back for a sticker or information on the bottom. If the same class hitch as mine from the factory, it will have a weight rating of 1050 lbs using a WD system for that class hitch. Note the maximums without a weight distribution hitch. Here is the sticker from mine. Weight distributing figures on top. According to MY Ford hitch sticker, a WD hitch for your 23' is NOT an option but a requirement since your tongue weight AND towing capacity are greater than 500 lbs AND 5000 lbs. My unit is the lightest wide bodied 25'. Empty it is 5049 lbs. with a gross at 7000 lbs and I agree with other posters, I would not tow without a WD hitch though the day I bought mine, we drove 130 miles without trailer brakes- no controller.
There are so many options on hitches. My used model came with a Curt WD hitch that worked fine for me until I got new truck tires- who would know. Then suddenly I was wallowing all over the road. I checked hitch height, etc. all within specs. It was odd. I ended up with a ProPride hitch and they are excellent but expensive compared to options. This though is an item that you get what you pay for. Many of us on this forum have Hensley and ProPride hitches. Whatever one you end up with, make sure that your weight bars go beyond your tongue weight maximum quite a bit so that you have to adjustment room. Six hundred pound bars with a 600 lb tongue weight- no. Six hundred with 1000 lb bars- yes. I learned this after the fact. Once you put LP in those tanks figure on about 100 lbs more tongue weight too. All tongue weight is subtracted from that door sticker figure.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
06-14-2014, 04:54 PM
carlsbad
rodsterinfl...
06-14-2014, 05:15 PM
carlsbad
Everyone has been so helpful and I'm so greatfull! For about a $500-$1000 budget... What should I buy?
06-14-2014, 05:32 PM
Common Sense
Here we go. This will probably turn into a popularity contest, like Ford/Chevy, but for that budget you should be able to get most any WD hitch except the ProPride or Hensley.
I would suggest doing some reading on here and decide which one you like the best, but try to get one that is also anti-sway, rated for the tongue weight of your trailer, and then enlist some experienced help with the set-up. The set-up is at least 75%, if not more.
Regards,
Steve
06-14-2014, 05:48 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Maybe a new truck...
1163 payload ouch! Not much in the way of payload left on your vehicle. If your axle weight is 900lbs that leaves 263lbs before your truck is over loaded. Subtract your weight, any passengers.... well...
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
06-14-2014, 05:53 PM
carlsbad
New tires ought to help?
06-14-2014, 05:56 PM
carlsbad
I don't understand? Seems like a light trailer for a truck that has 14,000lb towing capacity... WD and sway control should take care of towing if I've been listening ok...
06-14-2014, 06:01 PM
carlsbad
I'm confused...
06-14-2014, 06:02 PM
2006 25' Safari
St. Augustine
Your model's base tongue weight is 700 lbs. Add about 100 for LP and hitch weight. 800 so that leaves you 363 pounds for people and cargo. Put as much camping cargo as you can in the trailer instead of the truck- favor the rear. Fudging a bit is probably ok 100 lbs or so. As far as a hitch goes in the price category. There are people on the forum that recommend Reese hitches but I am not familiar with them. This is what I could find. Supposedly this is the top of the line model up to 1200lbs tongue weight distribution. Straight-Line. It runs about $500. They have an up to 800 lb version but you are that already so, as Sean at ProPride told me when I was shopping an right at my tongue limit of 1000lb bars versus the next one up, go up one more.
You are still within the limits of your vehicle. What others are noticing is that your payload figure is low. Tires do make a difference but the figure is not just about tires rather the trucks build options. Check your tires for load rating D or E and the pounds of load they can take. Is your F150 a super crew? If so it weighs about 5300 lbs or so divided by four then consider the tires load max, what is left divided by four again? That is their load rating for the truck plus the tow load (tongue) You should be fine since they should have equipped the truck with tires that can take the truck and its maximum payload.
Strait-Line Weight Distribution w Sway Control - Trunnion Bar - 12,000 lbs GTW, 1,200 lbs TW Reese Weight Distribution RP66074
