Old 06-15-2014, 07:35 AM   #41
cmmorsey's Avatar
2008 23' International
carlsbad , California
Thanks Msmoto...
Based on your suggestion, a few others and some research,... I think I will go with the Reese. Thanks!
cmmorsey is offline   Reply With Quote
Old 06-15-2014, 07:44 AM   #42
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
We have the Reese dual cam and have found it very satisfactory.
Old 06-15-2014, 07:47 AM   #43
cmmorsey's Avatar
new to Airstream and large towing... help?
Thanks everybody, this is what I think I'll be ordering:
http://www.reeseprod.com/content/pro...665&part=66084
With Lp I'm at 800lb and from some sudgestions I should go one up... 1200lb is one up.
Old 06-15-2014, 07:53 AM   #44
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
You got it cmmorsey. I would still contact Ford and have a discussion about the wheels/tires and options. You certainly have a nice truck and now a great vacation RV too!
@mrpres- sorry bout the 23D 23FB thing. cmmorsey is getting a 23D I believe so I was focused on that model. Yes, the 23FB has a much lower tongue weight, you are correct.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-15-2014, 07:54 AM   #45
cmmorsey's Avatar
Thanks for all your help @rodsterninfl
Old 06-15-2014, 07:57 AM   #46
2006 25' Safari
Images: 8
Hey, people on here have given me all kinds of direction. Naturally you have to always check everything out but it is a wealth of information and things to consider.
Old 06-15-2014, 07:58 AM   #47
Luigi123's Avatar
2018 30' International
2014 30' Flying Cloud
Los alamos , New Mexico
I was in your position a few months ago with many suggestions of specifics types, I ended up with a Reese Dual Cam, and for a newbie, all is good. I saved the money for a few solar panels. Cost installed for the Reese Dual was $1,000, installed, with 1200 and 800 sway bars.
Luigi123 is offline   Reply With Quote
Old 06-15-2014, 10:20 AM   #48
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I also use the Reese Dual Cam. About 8 years and 50,000 or so miles. Have not used another hitch so I have no comparison. Get the 800 lb bars. Camping World sold me the 1000 lb and later I went back and got the 800. Like them better. Read the Reese instructions for setting it up (even if the dealer does it). I do not have to re adjust my hitch after I got it setup. My 25' puts 800 lbs on the truck when it is loaded and hitched. Seems like yours will be that or less.
The payload on your truck seems awesome. I pull with a 2500. But I caravan a lot and have seen lots and lots of happy campers pulling with 1/2 ton trucks, SUVs, and whatevers. None of them have the payload and power of your rig. Once you get the setup right it will work for years with little attention. You are not likly to get (and probably do not want) 20% weight increase on the front axle when hitched. Best I can do is to restore the front axle to its unloaded weight. Seems about right to me.
Old 06-15-2014, 10:50 AM   #49
2006 25' Safari
Images: 8
Hmm. Bill, why do you like them better? Here is why I ask, when I was shopping for a hitch I planned to buy a 1000 lb bar hitch. Sean asked me what my tongue weight was and I told him that the cat scale was 970. He told me I needed the next model up as the limit of the bars was so close to the actual weight with little adjustment ability. Although it is a different hitch from the Reese, I would think that the weight bars would work the same. Just a thought.
Old 06-15-2014, 12:33 PM   #50
2006 25' Safari
Images: 8
Oh, just to share. I mis-named the vehicle window sticker and a forum member was nice enough to share the correct name for such- Monroney rather than Marone. THANK YOU.
Old 06-15-2014, 01:14 PM   #51
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
Rodsterinfi,
5.4 L, 2004 F150 (with a brand new engine 15M miles ago).
Photobum is offline   Reply With Quote
Old 06-16-2014, 05:34 PM   #52
2006 25' Safari
Images: 8
ok @Photobum, here is my source:
http://www.fleet.ford.com/resources/...s/2004_All.pdf
You are rated for 1420lbs payload. You will be good to go with a weight distributing hitch at least from the hitch, truck payload and towing capacity standpoint on a 25FB. It would have a tongue weight of about 600 w/loaded LP, etc. guessing.
A pro pride hitch is really nice and would work well for you. It that is too much $ then consider that Reese Straight line with 900lb or so weight bars. Get them more than what you need but not too much over, if that makes sense.
Old 06-16-2014, 05:46 PM   #53
Photobum's Avatar
I was looking at the Blue Ox. What do you think?
Old 06-17-2014, 10:15 AM   #54
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Our 2013 25FB International Serenity had a literature tongue weigh of 833 pounds but with a Hensley hitch installed, full propane tanks, street and rear awnings and a solar panel sitting at the dealership, the weight was 1,150 pounds.
Real world numbers may make a 1,420 payload vehicle inadequate for the task. The same trailer loaded for camping had a weight of 1,175 pounds and a GVW of 6,990 pounds.
Old 06-17-2014, 07:20 PM   #55
2006 25' Safari
Images: 8
It is a good thing he is looking at a 23' model Switz. That is a bit lighter for cmmorsey but yes, for Photobum's 25fb, it will be close.
I do not know anything about the Blue Ox. Anyone?
Old 06-22-2014, 07:38 AM   #56
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Gosh, I forgot to add about my TV that I had air springs installed so once the trailer is attached, the weight distribution hitch set up to transfer weight appropriately, I can fine tune the ball height so as to have the trailer perfectly level while towing.
I believe everything we can do to have the set up correct will improve the safety factor when towing. Once in a blizzard, heading up a slight grade, I saw my 27 FB Int hung out in the left mirrorat about a 45 degree angle. A huge wind blast had hit, and the truck tail followed it out to the left about four feet. But, a slight lift on the accelerator to bring the rear wheels back into traction, and some minor steering correction, combined with all the actions of the Reese dual cam sway control hitch, saved the day. The next 75 miles in the blizzard was at 35mph with several 18 wheelers behind me telling me on the CB this was the correct speed. LOL
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 07-08-2014, 10:03 PM   #57
cmmorsey's Avatar
Name:	ImageUploadedByAirstream Forums1404874882.971617.jpg
Well, this is what I installed with the father in-law.
Reese WD hitch with Trunion bars and duel cams ....
Any thoughts suggestions or the like...?
Airstream 2008 Int Sig 23d
2012 Ford F150 FX4
Old 07-08-2014, 10:53 PM   #58
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Take it easy over the bumps and when backing up... you won't like the sound they make....
have fun!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-08-2014, 11:06 PM   #59
Boulder , Colorado
Shipping Airstream
Hi,
I just bought a Safari airstream and am figuring out how to get it from Ohio to Denver. How much did it cost you to ship yours? What type of shipping did you use? Semi trailer, auto hauler?
PattyJ is offline   Reply With Quote
Old 07-08-2014, 11:10 PM   #60
cmmorsey's Avatar
Hi PattyJ. Used U Ship... $1300 ... We have a company in Denver... If you're looking for a whole house fan look at mygreenhomedesign.com
2012 Ford F150 FX4
Towing Large With A 1/2 Ton Truck? SteveH Tow Vehicles 196 06-28-2013 09:33 AM
Diecast 50's vintage airstream travel trailer large new eBay Watch Airstreams on eBay 0 08-06-2011 06:40 PM
medium, large or really, really large batteries bukib Land Yacht/Legacy Motorhomes 3 11-14-2010 11:00 PM
Help! Too large to get through door.... mrsdinapoli General Repair Forum 26 01-26-2010 04:12 PM
I'm Ready to drop Out and become a MAL (Member at Large!) rgesch WBCCI Forum 213 08-31-2006 07:22 PM
