07-15-2016, 07:29 AM
2015 27' Flying Cloud
Newberg
, Oregon
New shocks for my truck?
My tow vehicle is a 2009 Chevy Silverado LT crew 4x4 with the 5.3. Just got back from a ten day trip to the Olympic peninsula. Towing our 27 ft FB FC at 55-60 on US 101, lots of bumps in the road had the truck and trailer bouncing pretty good. We have 46000 miles on the truck, and I was thinking it might be time for new shocks and maybe bushings. Looking at KYBs on the Internet, does anyone have any thoughts or experience with this?
Mike
07-15-2016, 09:29 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Are the shocks leaking, any symptoms when not towing?
More info on your rig would be helpful, rating of wd bars, hitch brand & weights.
'Bounce' while towing is more commonly caused by improper loading and set-up.....
07-15-2016, 09:59 AM
1994 30' Excella
alexandria
, Kentucky
I am a fan of Blstein shocks. At 46k your OEM's are probably shot.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
07-15-2016, 10:53 AM
2007 28' International CCD
Springfield
, Missouri
Bilstein 5100's will be your best choice
07-15-2016, 01:27 PM
2014 28' International
Blacksburg
, Virginia
KYB Monomax
I have used and currently have KYB Monomax on my Jeep TJ. I had them on my previous Dodge Ram truck and on a Montero we had.
A friend of mine thought they were the best to use on the previous generation Ford Explorers, to keep them from bottoming out, and he put the miles on them.
You should get 50k out of them easily. You can tell when a shock gets weaker. You get a little more bounce, nosedive when you hit the brakes hard, more lean into a curve. I don't like the lean. I like a vehicle that stays flat in a curve.
They work very well on the Jeep, it has coils at all four corners and they keep it from rolling around, good and firm. I like a firm ride.
They are red and come with black boots. KYB makes a good strong shock.
Ra & Chelle
For my next trick, I will use my new AS & Dodge Ram CTD to make this pile of money disappear.
07-15-2016, 10:51 PM
1995 25' Excella
xxxxx
, xxxxxx
I have KYB gas a just shocks on my F150....No complaints.
07-16-2016, 03:44 AM
2014 27' Flying Cloud
Wenatchee
Another vote for the KYB Monomax's. I had Les Schwab install them on my Ram a couple years ago and they were an improvement over the ones that came from the factory. Not cheap, but Les Schwab gives them a lifetime warranty (and I hope to keep this truck for awhile).
2018 Ram 3500 SLT CTD 4X4 pickup
2014 Airstream Flying Cloud 27FB
WBCCI #7180
07-16-2016, 04:54 AM
Lin
, Ne
The best I know of.
07-16-2016, 06:05 AM
2015 30' FB FC Bunk
Ayer
, Massachusetts
That's what I did and the diffence was amazing. They won't take out the bumps, but they 'manage' the terrain vey well.
07-16-2016, 10:44 AM
2014 23' International
Hurst
Originally Posted by ROBERT CROSS
<<< SNIP >>>
Well, our F150/23D 'combo' has a bit of 'bounce' ... nothing serious but, from time to time, irritating. I'm convinced it's the truck's OEM (obviously soft) shocks... the darned thing has 'bounce' even when not towing. Maybe I'm just spoiled to nineteen years with a tight Toyota Land Cruiser.
I'm strongly considering installing [much] stiffer rear shocks before the next 'big trip.'
Rob
07-16-2016, 01:24 PM
2002 30' Classic S/O
Garden Valley
, Idaho
That's my choice as well. They are spendy but really are a superb shock.
07-16-2016, 03:40 PM
Newberg
, Oregon
Well, today I got a price on KYB gas adjust shocks. About a thousand bucks for all four installed. Yikes.
Mike
07-16-2016, 07:11 PM
1995 25' Excella
xxxxx
, xxxxxx
A thousand bucks for KYB Gas a Just?.....mine were a little over a hundred bucks. I put them on.
07-16-2016, 10:53 PM
Springfield
, Missouri
Rob
Bilstein 5100's will cure this
07-16-2016, 10:56 PM
Springfield
, Missouri
Mike
Find a new service center.Order from Amazon and install them yourself.Easy
07-17-2016, 04:52 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
X2
Saved 200bucks on two shocks for the Autoride system on our Burb.....I always ck Amazon first.
07-17-2016, 08:16 PM
1964 26' Overlander
Milton
, ON
Are Bilstien 5100's only for raised/lifted vehicles? Every time I search for them online I see notes that they are for raised or lifted vehicles.
07-17-2016, 08:40 PM
1991 25' Excella
Stanfield
, Oregon
07-18-2016, 06:54 AM
Blacksburg
, Virginia
check
always check http://www.shockwarehouse.com/index.cfm
They have free shipping also. I have used them in the past.
I need to get a set of Koni's for the IS350 soon.
Have a good one.
Ra & Chelle
07-20-2016, 03:58 PM
1964 26' Overlander
Milton
, ON
So from this thread and other online forums it sounds like it's a toss up as far as whether Bilstein or KYB is the better shock. There seems to be equal preference for both. I'm planning to go with KYB since they're a bit lower in price.
