Old 01-24-2013, 07:02 PM   #99
2013 27' Flying Cloud
Ann Arbor , Michigan
Wow, this is almost word-for-word my situation. The only difference is that I'm looking at the 27FB now and the hitch weight Of mine is less than yours. I am traveling in South America right now and don't have the spec with me but I should be clear that what I am trying to do is end up with an outfit that is indeed IN spec. It seems to me that just as you correctly noted The F150 Ecoboost when outfitted with the three hitch/payload packages and proper tires absolutely meets the spec that is published on weights both combined and individual. That includes responsible loading that don't exceed the CGVWRs
The tricky area is the hitch weight. In my case it was about 800 lbs. and the F150 rates at about 1120 lbs if I remember the numbers correctly. That means I have about 300 lbs to cover the hitch itself and other "stuff" such as the hitch weight portion of the fluids and cargo. From what I have read in these threads it seems that those items may bring me close to my max tongue weight but of course with a top-rated WD hitch I am pretty comfortable that I will be both safe and legal. Now, on the subject of legal i confess that I am not a lawyer or an expert but it seems that the critical specs are around axle weights and GVWR which I believe I will be well within . so as far as getting pulled over I will be fine ( not fined ) now on the subject of safety I am first relying again on the manufacturers specs and staying within. Secondly I am relying on the reputation and common knowledge that this new toy of mine will substantially outperform if operated properly and WITHIN specs. The last grey area seems to be around what will go in the box when we travel and whether or not that will blow through all the spec that I've worked so hard to stay within. That it appears will be my learning curve. I have learned an awful lot from all constituents and greatly appreciate it even if it has made me go back and forth like crazy. I feel like F250 is the safe bet but after driving it am not sure it is what I want for a daily driver. I feel like the F150 meets the spec and would be a great daily driver but I may end up regretting that I cannot bring extra payload. My decision... Drumroll please..... I will probably lease an F150 for the first two years until I retire. That gives me ample time to find out how I like the fit and feel of it while only using it for 20-40 days a year. it also allows me to trade up should i want to when we start putting major miles on the rig after I do the big "R". I also plan to keep reading and learning! Thanks again to everyone.
Airstream330 is offline   Reply With Quote
Old 01-24-2013, 07:10 PM   #100
Travel Bird's Avatar
2012 27' FB International
Denver , Colorado
We tow our 27FB with our Ford Expedition EL and a Hensley Hitch. Done!! Andy Thompson advised is and it's perfect.
Anna
Blog: Glamper~An Airstream Diary
www.glamperanairstreamdiary.com
WBCCI #4846, WBCCI DenCO Unit
Air #62992
Travel Bird is offline   Reply With Quote
Old 01-24-2013, 08:21 PM   #101
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by MrUKToad View Post
Thanks for that Moflash, I shall file it with all the other "Oh no, you're going to kill us all" posts.
I'll say it again, read up on Andy's work on his website and in his regular "Hitch Hints" column in Airstream Life. You will quickly see that towing is so much more than just weight and playing around with numbers.
You don't have to agree with his take on towing, but given that he's run a successful business specialising in towing solutions for travel trailers for over 40 years, you should at least respect his experience and knowledge in his chosen field. I can assure you that Can Am as a business would never let an unsafe or untested set up off their lot if they weren't 100% happy with it. However, you appear to know better....
Originally Posted by Travel Bird View Post
I totally agree with Mr UK Toad. Andy is the best. We followed his advise and couldn't be happier. We even went to CanAm after we purchased out new 'Stream!!
I feel exactly the same.
We tow our 25" Classic with a 2006 8.1 2/3 Suburban.
It tows like the Burb isn't even there.
And Can-Am Andy had nothing to do with it.
I have all the Americans right here on the Forums to thank for that.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 01-24-2013, 08:31 PM   #102
richinny's Avatar
2011 34' Classic
Airstream330 if you stay with the less heavily loaded models you'll end up with more payload capacity. i ended up at 1804 lbs. you'll probably have to order it because the dealers like to add lots of options.
Ricky
Old 01-24-2013, 09:03 PM   #103
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
Ok enough with your physics lessons. Your axle weights and payload capacity. Enough with 1/2 ton 3/4 ton 1 ton bla bla bla.
http://youtu.be/cedMN8Hx0DU
Smile and enjoy a little inner boy fun!
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 01-24-2013, 10:53 PM   #104
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Airstream330, leasing the F150 sounds like an excellent choice. You will learn a lot about YOUR towing needs. You won't need us to tell you what you must have.
In the meantime these new trucks are undergoing transition and offering equipment that makes them better and more economical vehicles for towing as well as general service.
You've already got as good a grip on the tow truck argument as those who are posting here, including me. So please join the next argument, new one every few days.
doug k
Old 01-25-2013, 05:01 AM   #105
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The tow vehicle is almost irrelevant as their are so many types of vehicles that can tow an Airstream quite well.
What matters is steering/handling and braking.
Proper hitch, proper set-up of same, and TT disc brakes are where discussions should lead.
Whether a decent-handling minivan or a crappy pickup truck (which is all of them) the lash-up is central, the brakes are immediately peripheral.
Spreadsheet analysis of pickup truck "weight ratings" is so fraught with fundamental error that it is not a reliable guide. The assumptions behind "frontal area restrictions" and aerodynamic-related problems do not include TT's like an A/S.
The best TV is the one which closely fits all solo duties . . and can tow the trailer. Not the other way 'round.
Old 01-25-2013, 05:26 AM   #106
Wink
Think of it as the polymath of toe vehicles....
Jack of all trades master of the 80/20 principle...
never mind.
PFC
"Tahawus"
RLC
John Prine
Old 01-25-2013, 06:34 AM   #107
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by Moflash View Post
Not real impressed with Andy if he let you go out the door with a Toyota Sienna that has a max tow rating of 3500 lbs and a total payload of approx 1200lbs knowing full well that you and your 5 children that ride with you and that you were going to pull a 28ft Airstream with a real tongue weight of appox 1000 lbs and a GVW 7600lbs.Plus the weight of the hitch they installed and wd system.
Wow!! Have you ever looked underneath your Sienna and looked at the the size of your drive axle and CV joints(about the diameter of a US quarter) much less the rear trailing axles and coil springs?
I read about these tow vehicle selections and I just cant believe the number of people out there that not only risk their lives but more importantly innocent people around them.To save gas? Money? Ride quality?What?
I would have liked to read the disclaimer that you signed from CanAm Rv center on this deal.
Definitely not cool MRUKTOAD
What you may be missing is that Andy does reinforce the vehicle - he doesn't just slap a hitch on it and call it a day. I was pretty confused by his setups until I realized that he modifies the car to add frame rails and the like. (Personally, having had a heavy duty transmission fail, I'd still worry about that issue, but that's just me.) I have no connection to Can-Am at all, and I tow with a truck - we need it for the space anyway.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 01-25-2013, 06:35 AM   #108
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Top Gear Trucks - YouTube
Damn, my real motive has been revealed!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-25-2013, 06:38 PM   #109
2013 28' International
Bozeman , Montana
Airstream330, great idea on the leasing.
I ended up at my local Ford dealer today and looked at and drove an F150 that is close to what I'm thinking about ordering. It was a heavily optioned supercrew Ecoboost with 5 1/2 foot bed, max tow. The Ford website and brochure shows at payload capacity of 1900 pounds, the door sticker on this truck was 1593. I expect what I'm going to order will be very close to this capacity. Again, I'll be well within the numbers for tow rating and GCWR with the 28 International. It is strictly the payload that I'll be right tight to the max amount. Tires are by far my biggest concern with running close to the the max in payload and will do an LT tire either ordering it that way or changing the p metrics to another tire as soon as I receive the truck.
I did look at and drive an F250 and just cannot go that route for my other needs. I'm not knocking it for others as tow vehicle but both my wife and I will be driving it as a daily driver. With the crew cab and 6'9" bed it is a huge vehicle any way you look at it.
If down the road I need sell it and move to a different truck I'm fine with doing so. From looking at the used trucks and seeing the high resale prices, I'm not too concerned about the cost to switch this out in the future if I decide that is what I need to do.
One other item I have seen mentioned here and elsewhere is optional gas tank sizes on the F150's. From everything I'm seeing, the 2013 US trucks have a 26 gallon tank if 2 wheel drive and the 4 wheel drive ones are all 36 gallon. I don't see an option on gas tank sizes so this might have been on prior model years.
HeadWest is offline   Reply With Quote
Old 01-26-2013, 06:47 AM   #110
Wingeezer's Avatar
2005 30' Classic
If ever you do find the need to move up in size you may not find it as bad as you think.
I remember the day I drove our 3/4 ton off the lot after having owned a 1/2 ton, I really wondered if I had made a mistake. It felt huge, and our plan was to use it as a daily driver!
It is surprising how quickly we can become used to something though, within a day or two it felt perfectly normal.
My wife - all of five feet on a good day - has no problem with it, and in fact she does a whole lot more driving with it around town than I do! I think she kind of enjoys it sitting up there so high!
Of course I recognize that not everyone will have the same experience as us. At times, it is not as easy to park. There are generally things you can do to compensate - but not always.
I have gotten to the point now that if we sell the trailer, I know that I will no longer have a sensible rationale to keep the truck, but I will be loath to let it go!
Brian
2005 Classic 30'
Old 01-26-2013, 01:53 PM   #111
Bozeman , Montana
It probably won't be too bad as you said. For right now, we are going from a BMW X3 and a BMW 330i as our daily drivers so even the F150 crew cab seems huge.
Old 01-30-2013, 07:24 AM   #112
Road Ruler's Avatar
Images: 38
Our 93 Nissan van was similar. The original CV joints had over 300,000 miles on them and never had a problem. The van spent 100's of hours towing all over the Continent. It's not how big the tug is. What matters is how well it handles the load.
