Hi all, I've been browsing the forum for quit some time now and this my first post.
I'm pretty new to the TT world. I recently bought my first TT a 2006 25" FB SE LS (May '06) and we're lovin it.
I have a question and need some help. I'm having an issue lately that has never occurred since purchasing my AS. We've taken it out now on six trips. I'm not sure if it's the trailer, the hitch or my truck (2005 Toyota Tundra DC). When I accelerate from a stop there seems to be some play or slack that is taken up causing a clunking feel. When I slow to a stop, the same thing happens clunking forward. I can't see where anything can be loose. I've checked all of the bolts and fittings on the Equalizer hitch and everything is tight. I tried to adjust the brake controller (Tekonsha Voyager)but that definitely caused more pull and grabbing on my truck when I brake so I eased it off to where it was. I took my truck over to the Toyota dealer for service and explained the issue and had them check the drive shaft, rear axle and hitch assembly for any loose bolts or noticable issues and none were found, granted they weren't able to test it pulling a load since I didn't have the AS with me.
Any ideas what it could be or where else to look.
Greg-- A couple things come to mind--One is that after use some of the paint on the shank and reciever wears off giving a little more clearence then when every thing was brand new. Also the "newness" wears off the pin and the hole throught the reciever. While not any one of these are enough to be concerned about and infact normal, the sum total of these add up to a little "looseness" in the hitch assembly. If thats the case it's something you'll have to learn to live with. That said I wouldn't "blow it off" as that untill I thoroughly checked everything else. I once had a similar noise and found the hitch ball slightly loose. Oddly enough I couldn't detect it by hand but the weight and force of the trailer caused movement there. I would also be sure the ball had the threaded shank the same size as the ball mount hole. If it's smaller than the hole and there is not a spacer installed to fill the space what you have may be the ball moving in the ball mount as you stop or accelerate.
I also had a good friend with the same complaint. Oddly enough it was a tundra too. He and I looked that over from top to bottom and never found a problem or an answer. He used it several years with no apparant problem.
pieman
Thanks in advance,
Greg
Greg,
Nice trailer and you live in a nice town too. (See my info on left.)
If I understand this happens on straight pullaways and stops? If so it has to be narrowed down from transmission to hitch. No offense but you have the right sized ball on your hitch? Assuming you do have you crawled under your truck and tried to twist your drive shaft? If so what happened?
If you want I can drop by Sunday and check the truck. Another person on this site will know more about your hitch than I will and they will answer that end of it.
You are also invited to the NorCal Winter Rally in 29 Palms in Jan.
pieman
Mike,
Thanks for the quick reply! I will have a look at the hitch ball to make sure that it is tight. Now that you've mentioned your friend with the same issue and he also has a Tundra gets me more worried that it may be the Tundra!
Milo
Hey neighbor!
It does happen on straight pullaways and stops and I personnally think it may be between the transmission and hitch. I'll crawl under the truck and give a twist on the drive shaft and see what happens.
As far as I know I should have the right size ball, the dealer where I purchased the AS from did the installation.
I'd like to take you up on your offer to stop by. That would be very helpful.
Thanks for the invite to the NorCal Winter Rally. What are the dates?
Hi millertime -- I hope your experience at the Forums is working out well. You do have a 5/8" hitch pin, don't you? A too small hitch pin would allow the hitch bar to slide back and forth a little bit in the receiver on your truck. By mistake I used a smaller one for a short time but can't say I ever heard or felt it.
Well thanks a million to Goin camping for coming over on Sunday and helping me troubleshoot and to everyone else's suggestions!
At first we thought that it indeed may be related to my transmission but after I stressed out on that thought I went and got my AS and towed it over to Goin camping's place. We drove around and both confirmed that there was definitely a clunk but realized that what it was is simply the ball has some play while inside the hitch and as I pull forward it would clunk and same when slowing. I'm still a bit baffled as to why there is that amount of play there now when there never was before....
Is this normal?
There should not be play in the coupler ,I would think the piece that pulls up
under the ball as the coupler is locked down may be worn or loose somehow
and should not be as we know. It won't get better ,Id install the shank and ball into the coupler /removed from the TV and move it around with your
hands while looking at the coupler from the under side seeing if you can
determine whats loose there ,somthings wrong ,it should be nice and secure
with out much movement ,there would be a slight amount of clearance but
not enough to cause a sloppy fit.The coupler latch mechanism could be broke
or damaged or worn ,Id continue with the diagnosis on the loosness.
Thanks for the heads up on this as I would tend to agree but to install the shank and ball w/out the TV is a lot easier said than done. That Equalizer hitch weighs a ton!
Is that coupler latch replacable or is it a part of the hitch assembly on the trailer?
If the hitch isn't engaging the ball, weight distribution bars may dislodge. If that doesn't, moving down the road certainly might. Okay -- it's a 10,000# rated thick shaft 2 5/16" ball, right?
