Old 01-10-2015, 04:36 PM   #43
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
in regards to TV weight, how is the weight of the driver and front seat passenger applied? To the Steer axle, drive axle or split between the two?
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 01-10-2015, 04:43 PM   #44
dznf0g's Avatar
Oswego , Illinois
Split between the two...but not equally. With most TVs you are physically closer to the front axle than the rear. You can figure the approximate split percentage by measuring the distance from about 6" in front of the seat back to an imaginary vertical line bisecting the front hub. Same thing for back hub. Divide each by the wheel base and you have your percentage. Multiply that times your weight and you have the pounds placed on each axle...approximately.
-Rich-
Old 01-10-2015, 04:46 PM   #45
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Pat,
It would be split, but hard to tell the ratio without weighing both in and out of the TV.
The #'s back the the trailer axles may even be out of the CAT scale limits, very likely less than 20lbs.
Old 01-16-2015, 09:52 AM   #46
Montgomery , Texas
GM states in online literature that my Denali's GVRW is 7,100 lbs. However, the sticker on front inside door states 7,300. Which one is correct and why the difference?
Old 01-16-2015, 11:01 AM   #47
2016 30' Classic
Erie , Colorado
The door sticker. Marketing literature is usually written before the design/engineering is completed. And you may have additional options on your unit.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 01-16-2015, 11:23 AM   #48
Montgomery , Texas
Wouldn't the additional options increase the total weight and decrease the GVWR?
Old 01-16-2015, 11:57 AM   #49
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The door sticker GVWR is about best braking/handling performance given the usual driver. The tire/axle ratings are the real concern.
Old 01-16-2015, 12:14 PM   #50
Montgomery , Texas
l
Old 01-16-2015, 02:06 PM   #51
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I don't know where GM has posted the 7100 number, but on their main web site, if you select Crossovers/SUVs -> Yukon Denali -> Features & Specs -> Capabilities -> Trailering & Payload, you will find the 7300 pound number.
My 2010 has 7300 pounds on its door sticker.
SSquared is offline   Reply With Quote
Old 01-16-2015, 03:21 PM   #52
Livingston , Texas
According to Model Information - Online Ordering Guide,
the GVWR is 7100# for 2WD and 7300# for 4WD.
Ron
Ron Gratz is offline   Reply With Quote
Old 01-16-2015, 04:32 PM   #53
Montgomery , Texas
Thus the confusion. Regardless, I was able to re-weigh my Denali and Airstream today. Attached are the CAT scale tickets.
As I mentioned earlier, last week the Blue Ox tech weighed my tongue with a result of 1,050 lbs.
The following is from the the sticker on my front door
GVWR - 7,300
GAWR FRT - 3,550
GAWR RR - 4,200
Your comments are appreciated
Old 01-16-2015, 05:25 PM   #54
Montgomery , Texas
Please accept my apologies as I uploaded the incorrect tickets. Let me try this again....
ID:	230530   Click image for larger version
Old 01-16-2015, 06:13 PM   #55
SSquared's Avatar
Longmont , Colorado
That looks pretty good. I say run it that way and tell us how you like it. I also suggest trying it with the WD one link tighter and see if you can feel any difference.
By the way, what is the payload number shown on the tire pressure sticker on the door frame? I'm curious to see if the vehicle has grown heavier over the years (though it also varies according to options included).
Enjoy!
Old 01-16-2015, 06:42 PM   #56
Montgomery , Texas
I had to put it on the 9th link to get front end from acting so squirrely. Here's a pic of the sticker. Click image for larger version
Name:	ImageUploadedByAirstream Forums1421458964.480823.jpg
Share Your Real World Tongue Weights & Trailer Weights BoldAdventure Towing, Tow Vehicles & Hitches 182 06-23-2015 06:10 AM
Need help understanding elec. Components Landrum Electrical - Systems, Generators, Batteries & Solar 3 05-08-2014 06:42 PM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
Help in understanding trailer weights Silvertwinkie Our Community 6 08-08-2003 08:47 PM
Trailer weights, hitch heights & more... ameeker Airstream Trailer Forums 1 06-25-2002 04:42 PM
