Old 01-08-2015, 03:45 PM   #29
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Originally Posted by ROBERT CROSS View Post
SS,
I was always told to install the chains with the open end toward the trailer.
Bob,
Thanks, I've never been told to do it either way.
SSquared is offline   Reply With Quote
Old 01-08-2015, 04:06 PM   #30
SSquared's Avatar
Longmont , Colorado
Auto Leveling
Originally Posted by Pat Cassity View Post
So, I just got off the phone with Blue Ox. They feel that my set up is good. However, they also feel that the Denali's automatic leveling system is interfering with the WD. They suggested that I deactivate the auto leveling system when towing. I am now trying to find out from GM if there is a way to do so. I have checked the manual but it doesn't address deactivation of the system. It only states that it is recommended to allow the shocks to inflate prior to adjusting the hitch. Any of you with Denali's out there had similar issues?
I don't think the auto leveling is a problem. To me, setup is best done with the truck scales. If you make an adjustment to the chains while your rig is parked in the parking lot, by the time you get onto the scales, the auto leveling will have done its thing, and you will have valid data. With the modern Sway Pro hitch, you have no head angle adjustment, so your setup has only one adjustment to make--the chain length. A little experimentation at the truck stop and you should be good.
By the way, if you want to be a perfectionist on the chain length, you can adjust by a fraction of a chain link by inserting a bolt into the chain such that it captures two adjoining links, and shortens the chain by the diameter of the bolt. I never did that with my Blue Ox, but on my current other brand hitch, 1/2 inch bolts are the right size.
Old 01-08-2015, 04:26 PM   #31
N/A , N/A
Yep....re-weigh.
TV alone loaded for camping.
TV & AS with and without WD set, (with full camping load), rig must be LEVEL when WD set properly.
Notice I'm within 100lbs of the TV alone steering axle weight.
This ticket is very informative. Thanks for sharing it.
I noticed that applying the WD, adds 660# to the TV front axle and only 160# to trailer axles. This means that roughly 75% of weight moved by WD goes to TV front axle and only 25% to trailer axles. Do you think these ratios are specific to your setup only or are rough estimates in general?
Applying the WD returns the front axle to (almost) its original weight, but does not seem reduce the the load on the TV much (160# only).
rostam is offline   Reply With Quote
Old 01-08-2015, 04:42 PM   #32
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Need More Help Understanding Weights
2 to 1 ratio is correct. And 20 to 25% off of ball. This is per formula.
Old 01-08-2015, 04:49 PM   #33
N/A , N/A
The above ticket shows a 4 to 1 ratio (660 to 160) for weight added to front axle and trailer axles. I am sure the overhang/wheelbase ratio can change this, but was curious what is the "general" rule.
Old 01-08-2015, 04:51 PM   #34
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
As stated. 75-80% off of rear axle and weight distributed 2 to 1 steer axle to trailer axle.
Old 01-08-2015, 04:56 PM   #35
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
Ron, per the Yukon manual one should let the shocks inflate before attaching WD. However, Blue Ox has told me that auto leveling will interfere with the WD process, resulting in poor handling and increased sway. In regards to pulling the fuse to disable the system, the fuse does not just disable auto leveling but is also involved in other stability and safety features. The GM service manager suggested that I pull the power plug from at the shocks.
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 01-08-2015, 07:02 PM   #36
Livingston , Texas
Pat, if you adjust the WDH FIRST and THEN allow the auto leveling to raise the rear of the TV --
the raising of the rear will cause load to be removed from the WD bars, and the amount of load transfer to the front of the TV will be decreased.
I'm guessing this is the scenario envisioned by Blue Ox when they say that load leveling will interfere with the WD process.
Many people have reported successfully using a WDH in conjunction with automatic leveling or with manual air leveling.
If you follow the instructions in the Yukon manual, you should not have a problem.
Ron
Ron Gratz is offline   Reply With Quote
Old 01-08-2015, 09:53 PM   #37
Montgomery , Texas
After talking with the Blue Ox folks again today, it has been determined that the head should have been installed 2.5 to 3" lower to compensate for the rise of the back of the Yukon from the auto leveling system. Ron, you were, in fact, correct. With the current setup, once the auto leveling system raised the rear of the Yukon, all of the pressure was removed from the WD bars.
Old 01-09-2015, 05:37 AM   #38
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Ron Gratz View Post
GMC also says:
"When using a weight-distributing hitch, the spring bars should be adjusted so the distance (Ground to Front Wheel Well) is the same after coupling the trailer to the tow vehicle and adjusting the hitch."
When you attach the TT and then allow the TV to level, the rear will rise to the preset level, but the front of the TV will be unloaded by the TW and the front will rise.
If you then apply load to the WD bars, load will be transferred to the front suspension, and the front will drop.
The rear will tend to rise, but the leveling system will try to keep the rear at the preset height.
The goal should be to keep the front end at the same height (same front axle load as when unhitched).
IMO, there is no reason to deactivate the auto leveling when towing as long as you follow GM's instructions -- 1) attach trailer, 2) allow TV to adjust rear height, and 3) adjust WDH to return front to unhitched height/load.
Ron
Ron,
This is a surefire way to overload the rear axle by "masking" the true rear squat and thus the WD applied to return the front to proper height. I guarantee, with this method you will not have enough WD applied.
The only way I found, by weights and measures, to accommodate the auto level control is this:
1) Empty TV; cycle ignition so the auto level control adjusts to the proper ride height. (this might take 30 seconds or more)
DO NOT CYCLE IGNITION UNTIL ALL THE FOLLOWING STEPS ARE COMPLETE. OR, IF VEHICLE MUST BE MOVED DURING THE HITCHING AND LOADING PROCESS, REMOVE AUTO LEVEL FUSE.
2) hitch up AS
3) fully load trailer and TV with all gear, food and supplies including water, if needed.
4) Apply WD until you return the front height to FALR height.
(Note) at this point the rear will probably be squatted enough to activate the auto level control at TV startup.
5) Apply a bit extra WD to compensate for auto level control activation at TV startup. I recommend one link (or one notch of head tilt...1/2 link would be good, but...) on chain systems and about 1/2" more jack lift on PPP.
6) At startup, you probably will still get some very minor activation of auto level control, but if it more than about 5 seconds, or 1/4 - 1/2" lift, you haven't applied enough WD for your setup.
Any ignition cycle (with fuse in) before significant loading is complete and WD is properly applied will result in the auto level control setting a new "baseline" height at a partial load status and will mask true load height and result in rear axle overloading.
Once done at the beginning of a trip, you will be close enough for the remainder of that trip, and for subsequent trips with similar loads.
The danger here is not so much rig handling as it is about durability of the rear axle. However, sway control on those hitches which rely on spring bar pressure can and will be affected masking true loaded ride height and, subsequently, by not enough WD application.
-Rich-
Old 01-09-2015, 08:18 AM   #39
Livingston , Texas
Originally Posted by dznf0g View Post
Ron,
Rich,
As long as step 3 (adjust WDH to return front to unhitched height/load) is done with the leveling activated,
the WDH will have restored the proper amount of load to the front
and will have removed the proper amount of load from the rear.
Ron
Old 01-09-2015, 08:27 AM   #40
dznf0g's Avatar
Oswego , Illinois
Ron,
True. My point here is to make sure that a true baseline is set when each person sets up their particular trailer and loading circumstance. IMPO, as a GM Rep, the baseline WD setup must be done without activation of the system. And there should not be significant activation after proper setup, or WD needs to be increased as described above. Again, if your particular load changes over time, or the system activates without a loaded setup, you will not have the proper WD and, at a minimum, you will have more severe rear axle overloading than normal. Remember the large SUVs are marginal with regard to RGAWR for those of us with....say 25' and up trailers (>750 - 800 lb tongue weight.)
-Rich-
Old 01-09-2015, 08:42 PM   #41
Montgomery , Texas
With the help of the Blue Ox tech today, we lowered the head by an inch. Unfortunately it couldn't go any lower. I coupled the trailer
to Yukon and let the load leveling system inflate the shocks. With the motor running, I attached the WD bars up to the 10th link.
By doing so, I was able to lower the front of the Yukons front end to 38.5" compared to the rear at 37.5. If the weather ever clears,
I will take it out to see how it handles and re-weigh.
Old 01-10-2015, 09:16 AM   #42
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Rostam,
Glad you found it helpful.
Here is a reason why a strict blanket rule on WD set-up is not helpful.
Notice my camping loaded trailer axle weights, 7640lbs.
AS determined that this trailer should be equipped with two 3500lb axles and they gave it a gross weight of 7300lbs.
Now, allowing for un-sprung weight this gives me a CCC of only 676lbs, hardly adequate.
My set-up is fully capable of transferring that last 100lbs forward to the steering axle, BUT it would also transfer weight to the already stressed out trailer axles, reducing what I'm able to carry.
So, what did I tweak?
Well it was a brand new trailer so up-grading the axles was out. I determined that with careful loading and maintenance I could work around the problem. Example...the trailer sits on jackstands with wheels removed for Winter storage, no axle loading helps prevent the internals from developing a set, with the added benefit of less stress on the tires.
The Hensley was next, I started with 1400lb WD bars, a bit too stiff for the AS, so I changed to 1000lb bars.
Next the OEM receiver. It required way too much flex on the 1000lb bars to transfer the required weight. The Class 5 Reese Tow Beast solved that problem, it's frame mount flanges were considerably longer than the OEM unit giving it the necessary leverage to transfer the weight with the 'softer' bars. Plus the added load carrying capacity of the class 5 hitch gave me the wiggle room I'm comfortable with.
Everyones rig is different and all of us should invest the time, effort and sometimes $$$$ to get it right.
It helps us and our fellow travelers.
Share Your Real World Tongue Weights & Trailer Weights BoldAdventure Towing, Tow Vehicles & Hitches 182 06-23-2015 06:10 AM
Need help understanding elec. Components Landrum Electrical - Systems, Generators, Batteries & Solar 3 05-08-2014 06:42 PM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
Help in understanding trailer weights Silvertwinkie Our Community 6 08-08-2003 08:47 PM
Trailer weights, hitch heights & more... ameeker Airstream Trailer Forums 1 06-25-2002 04:42 PM
