Old 05-05-2015, 05:45 AM   #1
2015 25' FB International
Lexington , Kentucky
Need help - Stabilizing hitch for AS 25FB
Good morning everyone. I just purchased a 2015 25 FB and pick it up next Friday. My TV is a 2015 Ram 1500 Limited. I am brand new to the AS world and have no idea what stabilizing hitch to get. Can someone please advise?
Thanks Al
Talon405 is offline   Reply With Quote
Old 05-05-2015, 06:23 AM   #2
SteveH's Avatar
Common Sense , Texas
They are all good, and with the exception of the $3K +,- pivot point projection Hensley and ProPride, they all work basically the same. Hitches seem to be an explosive topic on here, and don't be surprised if an argument starts over which is better.
I will only say you need to get the proper size hitch (in weight rating) for your trailer, and going over sized is bad, especially with the square bar type hitches. The setup is way more important than the brand of hitch you get, so enlist some help from an experienced person for the setup.
Good luck, have fun, and welcome to the forum.
Regards,
Steve
Old 05-05-2015, 07:06 AM   #3
silverlabs's Avatar
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie , Texas
I will second Steve's comments that what is most important is proper set up. On my 25FC i used an Equalizer hitch and it performed very well. It will squeak and crack a little bit, so you won't make a quiet exit in the early morning but it performs well. On my 28 I went to a ProPride and love it. I need to sell the Equalizer but haven't tried to yet. Don't think I could get it to you by Friday. There are several threads here on the forum if you look under the Towing and Hitches thread. Best of luck and enjoy your new Airstream.
silverlabs is offline   Reply With Quote
Old 05-05-2015, 07:38 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes do your homework. Historically WD hitches were designed with weight transfer as the principle function and sway control as a secondary function. That was necessary when most RV s were pulled by softly sprung cars and there was a need to get the front end of the car back down to where the driver could see over the hood. Currently the majority of RVs are towed with some from of truck, almost all of which have significantly stronger spring sets.
Many of us that have towed having used the full range of TV, 1957 VW dung buggy to 2500 diesels, now look at sway control as the more important function of our hitch. That experience history caused me to change to the Andersen system 3 years ago. It was designed as a new approach to the current needs and it does the job.
What ever you decide let me add one more comment. 90%+ of the dealer out there have no idea in the world as how to set up a WD system correctly. To do it right it takes far more time than they are willing to spend and thus many use some urban myth that a given number of chain links is the answer.
I am sure many more will jump in on this so sit back for a bit and take it in.
2004 Excursion 4x4
Old 05-05-2015, 07:41 AM   #5
ckottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We have a 25' Flying Cloud and Ram 1500, have used the Equal-I-Zer and ProPride hitches. They both work well to distribute the hitch weight of the Airstream.
The greatest everyday difference is on interstate highways with heavy sidewinds, or when semi's pass. Our pickup and trailer were moved around by the buffeting air with Equalizer, barely noticeable with the ProPride. That driving comfort makes for a relaxed day of travel; the substantial price difference an excellent buy.
cheryl
ckottum is offline   Reply With Quote
Old 05-05-2015, 07:43 AM   #6
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
I'm sure your Airstream dealer sells at least one brand of hitches. You might start your search with that brand since they can install it for you. I'm not suggesting you get whatever hitch they sell, but research that brand first and see if it sounds/looks good. There would be an obvious convenience to getting the hitch from them (but be prepared to fine tune the hitch setup yourself at home).
Landrum is offline   Reply With Quote
Old 05-05-2015, 07:58 AM   #7
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
When I bought my 2008 Classic 25fb preowned from the dealer they installed the Equalizer with 1000lb bars. I've added the bracket jackets to the A frame brackets and keeping the hitch head moving parts lubed reduces the noise. I negotiated the WDH with the deal. I tow with a 2010 Tundra and the hitch has worked well so far. I haven't experienced any issues with semis passing me using my hitch but I only drive 60mph. I haven't been towing in very strong crosswinds either.
I'm a little payload restricted to afford the extra weight of a Propride/Hensely hitch solution.
Kelvin
Old 05-05-2015, 08:00 AM   #8
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Talon, I have the same 1500 RAM & 25ft Airstream (on order). I plan to use the Equalizer 10K WD Hitch. I had an Equalizer a few years ago on a different trailer & liked it a lot, it does the job quite well and it's very easy to attach & detach.
Mrjkq is offline   Reply With Quote
Old 05-05-2015, 08:35 AM   #9
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Talon, I picked up a 2014 International Serenity 25FB from our Portland dealer and they installed a Blue Ox WD/Sway Pro. My TV is a 2008 Range Rover so I am close to maximum capacity. We have only 600 miles so far and very satisfied with the tow stability.
Go to the Towing & Hitches threads, there is a ton of information and opinions on hitches, WD and sway control. Welcome to the forum and congratulations on your new AS!
NWRVR is offline   Reply With Quote
Old 05-05-2015, 10:06 AM   #10
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
The 25FB's are a bit tongue heavy. You'll want to add a couple hundred lbs to the Airstream factory spec weight to account loaded for camping. Then add in weight of the hitch. You may find your up against your trucks factory receiver weight limit. This issue drove my decision. I got an equalizer hitch.
kscherzi is offline   Reply With Quote
Old 05-05-2015, 10:19 AM   #11
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
As noted, there are some very lengthy, emotionally charged, threads on this subject. We have had 3 25' AS over past 7 years...hitches have included Reese, Equalizer, and replaced our Equalizer with a BlueOx on our 08' 25 Safari, when it broke during a trip; that was all the dealer had in stock. Last year, we purchased a new BlueOx again with the new 2014 FC and have been very happy with our experience. Price was good and no issues. We were able to find best price on Amazon and our service dept. manager matched the price and dealer sales got it installed for no charge. (you might call your service manager and ask if he will price match.) Pulling to/from CA, MT, TX average about 6-7K miles last year.
Old 05-05-2015, 10:29 AM   #12
Refugee from Napa, CA
Photobum's Avatar
2015 25' FB Flying Cloud
Madison , South Dakota
I have a 2015 AS 25FB, and I tow it with a F150, using an Equalizer hitch. Just keep it lubed and you will be quite happy....
www.vincentgoetz.com
Instagram. Alluminator
Photobum is offline   Reply With Quote
Old 05-05-2015, 01:17 PM   #13
Stanwood , Washington
We have a 25' Safari and tow it with a 2015 Silverado 1500 and an Equalizer hitch, seems to work really well. Happy Camping!
dfschultz is offline   Reply With Quote
Old 05-05-2015, 01:44 PM   #14
1996 25' Excella
Tillsonburg , Ontario
A Good Dealer will make sure your equalizer bars are the right capacity. I had trouble with 750 lb bars on my '89 with the Dakota...way too much force to pull the rig up level. They should have been 1000 lb. But I solved the problem with an extra leaf and re-curved springs. So your Ram 1500 should do just fine with any good brand
JCW
JCWDCW is offline   Reply With Quote
HELP! Our stabilizing jack is stuck down!! shelagh Jacks, Stabilizers, Lifting and Leveling 2 06-25-2014 07:25 AM
69 Stabilizing jack Dan Roach Commercial Listings 2 10-27-2005 07:38 PM
stabilizing jacks emanon25 Jacks, Stabilizers, Lifting and Leveling 0 09-04-2004 09:53 AM
Side Couch/Bed Stabilizing Argsy26 All Argosy Trailers 2 08-03-2004 08:29 AM
Stabilizing Jack Choice COArgosy78 Jacks, Stabilizers, Lifting and Leveling 17 03-11-2003 12:00 PM
