02-18-2016, 02:51 PM
#61
Oswego
Imagine replacing the rear springs in a 1/2 ton truck, which support the rear of the TV fine and at an appropriate height, with a spring pack off a 1 ton dually. It still supports the same weight at the same height (theoretical assumption).
Now drive down the road. Which one flexes and smooths out the bumps better?
WD bars are SPRINGS. They are supposed to support weight. They do it by supporting that weight in different vectors than a rear leaf spring, but they are in essence the same thing.
Now, given a certain TW and load, which smooths out the undulations and dips and peaks in the road...the 800# spring bar or the 1400# spring bar?
-Rich-
02-18-2016, 03:55 PM
#62
2012 27' Flying Cloud
W
, New England
I'm tempted to say the 1400# springs because it would take more force to compress them - and yet, I'm preparing for that to be the wrong answer 😃
02-18-2016, 04:03 PM
#63
Oswego
Guess it depends if you prefer a Cadillac ride or a Corvette set to track mode ride for you and your AS/tv
-Rich-
02-18-2016, 04:23 PM
#64
W
, New England
Is it wrong to imagine the WD jacks on a HAHA/PP change the dynamics of the spring that is the WD bars?
02-18-2016, 04:29 PM
#65
2014 23' International
Hurst
Can't remember when I was in a Cadillac last... but my Corvette (Z51) would beat you to death. However, the 'Vette seems downright comfy compared to this beauty...
he he... hijacked my own thread!
R
#66
Oswego
No, but that only changes the "load" on the spring not the flexibility of the spring. Refer to the graph in Inland Andy's graph and compare the curve of the EQ 1000# bar and the Reese 1000# bar. They flex differently with a given load.
-Rich-
02-18-2016, 04:37 PM
#67
W
, New England
Aha! So you've got spring A which is able to handle 800# and spring B which is able to handle 1400# - the argument is that if you put the same amount of load on them (say 500#) spring A would react to that old more smoothly than spring B (as spring B is presumably "stiffer") - is that the thinking?
02-18-2016, 04:42 PM
#68
Oswego
Yes , if I understand you correctly. The drawback is more amplitude of porpoising on those sections of road prone to create it. BUT, just like I didn't buy a 2500 Duramax solely for the 5% of miles I'll drive in the mountains, I don't hitch for the 1% of roads that'll cause porpoising.
-Rich-
02-18-2016, 05:08 PM
#69
2012 25' FB Eddie Bauer
Southwestern Ontario
, Ontario Canada
R
Depends on the Caddy
02-18-2016, 05:14 PM
#70
Oswego
True, I thought of the V series after I posted, but I think you get my drift.
-Rich-
02-18-2016, 05:30 PM
#71
W
, New England
😃 look - I don't know if I understand myself correctly! 😳😃
As I've displayed in this and all threads in which I've participated, I'm not an engineer and I have no understanding of physics. I'm trying to parse what those who understand those disciplines say for my own simple consumption.
If heavier springs/WD bars are "stiffer" they could contribute to a harsher ride. Yet they would also be capable of levering more weight to the axles. So in my case - with 1100# entering the hitch receiver, 1000# bars would not be able to move 100% of the load. The good news is, they wouldn't have to do that as only 500# actually come off the front axle. BUT - wouldn't I have to flex that 1000# spring harder to move 500# (half of the bars' capability back to the front axle) than the 1400# spring (just over a third of their capability)?
In my experience, I had to crank the WD jacks to almost 7" to get 50% FALR with 1000# bars on my PP and now I crank to 6" for 100% FALR with my 1400# bars. The higher capacity bars aren't so "tightly sprung/taxed" to push the weight - so doesn't that make it a "springer/softer" ride?
Dagnabbit! It's like listening to a language you don't speak 😃
02-18-2016, 05:31 PM
#72
W
, New England
Isn't that the CadVette?
02-18-2016, 05:42 PM
#73
2012 25' Flying Cloud
Battle Lake
Good thread.
The next puzzle in my mind. Which has more flexibility left for undulations on the road, 800# bars fully loaded or 1400# bars partially loaded?
Doug and Cheryl
02-18-2016, 05:46 PM
#74
Oswego
Originally Posted by dkottum
Good thread.
In my experience, the 800# bar. All this discussion assumes we are not OVER stressing the spring bar.
-Rich-
02-18-2016, 05:52 PM
#75
Oswego
I disagree that the lighter bar wasn't capable of moving equal weight. It will just have more bow at a given preload than the higher rated bar. This is accomplished on a conventional hitch by applying more head tilt.
You bring up a drawback of PPP hitches. The head must be on a horizontal plane. Thus, you must take up the greater bow solely with Jack height.
My vision of a lighter bar for PPP would be at 800# with about a 105 - 115 degree bend at the head end, instead of 90 degrees. Alas, there is no such animal.
-Rich-
02-18-2016, 06:49 PM
#76
W
, New England
So at the end of the day, RFP sets up hefty bars. Is the test the "bounce test" to see if there's some flexibility, a ride on a washboard road and post-rivet count or something else to determine to stick with them or go to the 800# bars?
And is a trip to the scales required to conduct the experiment to calculate tongue weight and know for sure how much is getting transferred to the TV front and TT axles?
Very fascinating discussion!! Thanks for your patience while I tag along, RFP!
#77
Battle Lake
The PPP hitch bars operate farther back from the truck's rear axle than a conventional hitch, because of the longer design to accommodate the linkage. It is my understanding that this greater distance requires a higher rated bar to get the same w.d. as bars used with a conventional w.d. hitch?
I described our Ram 1500 and FC 25 Airstream with Sean at ProPride and asked for 1,000 lb bars. He said no, we need 1400# bars or would have difficulty transferring enough weight.
Another related topic. Does the head of the PPP hitch need to be level, and why? As you may know, Can-Am likes to tilt the w.d. bars downward to the rear stating this helps with handling and returning the trailer to center. With the PPP hitches this helps prevent the "Hensley bump". I put in all the washers the rivet will hold in ours and still would like to see more tilt. CanAm achieves more tilt by bending the PPP stinger downward slightly on these.
Doug and Cheryl
02-18-2016, 06:53 PM
#78
W
, New England
Doug. Colobial added washers for that reason to mine. It sort of points the stinger down so even though the head is at 90* that downward slope sort of forces the head (and a-frame I suppose) upward - like having the handles of a wheel barrow angled downward so you have to bend your knees to get the handles and as you straighten your knees, your already pushing the weight on to the wheel.
Again - what the heck do I know? 😂
I do love the improvement in feel!
02-18-2016, 07:03 PM
#79
Battle Lake
Steve, Inland Andy (Inland Airstream) has been in the Airstream business a thousand years and he says the "bounce test" is a good test. Others scoff at it. We trust the judgement of experience in this case; he's repaired a lot of broken Airstreams.
We can't realistically run back and forth to the scales, too far away. So we use wheel well measurements to set up our hitch before each major trip. A great convenience of the Hensley/ProPride is the weight distribution screw jacks for tweaking the w.d. to each particular load, turn the screw jacks and the load moves.
Doug and Cheryl
02-18-2016, 07:12 PM
#80
Oswego
That tilt that CanAm welds into haha, and the tilt with more washers in PP accounts for the receiver slop and brings the head back to level. When it is tilted up, the upper head "runs downhill " when off center, aggravating the hensley bump. That's why I have a PP made adjustable stinger for haha that Sean made.
-Rich-
