02-16-2016, 12:51 PM
#21
2013 30' Classic
Greenwood
, Mississippi
Take it for a drive around town and out into the countryside to see how effective sway control is when 18 wheelers pass.
If you don't feel pushed around by 18 wheelers, no further adjustments needed-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
02-16-2016, 01:13 PM
#22
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
Ultimately it's is a personal decision on how much is enough and driving around the block and on the highway are good suggestions.
As I mentioned above, 1000# bars on our 2500 Suburban made the hitch way too stiff. With the WD bars cinched the hitch became almost like a solid member. With the 1000# bars I could jump up and down on the hitch and it moved very little. The 600# bars still transfer the weight to the front of the vehicle but the hitch connection has more compliance and the ride is definitely better.
Here's the information for our 2500 Suburban using 600# bars.
Our rise in the front was only 1/4" when attached without WD and we got all of that back with WD.
Our sag in the rear was 1" without WD and only 3/8" with WD.
The bottom of your shank does sound close to the ground but it's difficult to know for certain without seeing a picture. Ours is probably on the order of 8" from the ground so not a whole lot higher. We don't drag very often. After getting the hitch dialed in I used a reciprocating saw to remove a few inches from the bottom of the shank to gain some ground clearance. I was probably only 5 - 6" off the ground originally.
on edit:
I spent the better part of a day working with the hitch head angle, number of chain links, etc. to get mine dialed in the first time. After that I still made adjustments. When we purchased a second tow vehicle things went much more smoothly and I spent a few hours at most dialing the new hitch in. We recently installed new axles on the trailer and that raised the trailer nearly 2" so I had to dial in the hitches again - this time only spent an hour or so making the adjustments. Each time is a little quicker and you'll gain a better appreciation for how each parameter affects the outcome.
If you don't already have a large box end wrench to fit your hitch bolts you may want to consider buying a set. A cheater bar of some sort may be needed too.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
02-16-2016, 01:16 PM
#23
2019 27' Globetrotter
Edmonton
, Alberta
We have the same trailer and truck and noticed definite sway when travelling down steep hills and during strong cross winds using the generic WDH that the dealer sold us. I bought a Pro Pride with 1000 lb bars and the difference was incredible. We travel light as well and notice we are about 150 lbs over on our payload capacity of 1673 lbs. The PP hitch is heavier but I suspect the advertised tongue weight is too low.
02-16-2016, 02:08 PM
#24
2008 25' Classic
Full Time
Drive it to a level parking lot and take some photos of the truck and trailer together and the close up of the hitch head. Try to exit your driveway at an angle to avoid hitting the shank.
Kelvin
02-16-2016, 02:09 PM
#25
2016 23' Flying Cloud
Dallas
RFP-My TV is the same as yours except 2013. My manual says half way between the "high and low" measurement and the Equal-i-zer hitch manual says "at least half way". With the hitch at approximately 17.5 inches, your shank is sitting way too low and you are going to drag a lot.
Kittyfeet-
I hope this day to have the opportunity to help someone in need.
02-16-2016, 02:36 PM
#26
2014 23' International
Hurst
Kelvin
Kelvin... unloaded, the shank is about 8" from the concrete, hitched up that drops to less than 6" ... I can't get out of the driveway without making some serious noise; and maybe worse, I'm concerned about what dragging the shank might damage.
Oh, yes... a LOT!
I'm afraid that air bags may be in my future.
02-16-2016, 03:05 PM
#27
Oswego
Originally Posted by m.hony
Tongue weight is a starting point anyway.
I have 1,000# bars for my Classic 30-
Still have a hard time transferring enough weight back to front axle.
I think the reason for that is I have a half ton truck.
I wonder if 600# bars would make it even more difficult to transfer weight to front axle...
Agreed, but I believe it depends on the bars.
Cold rolled steel or spring steel? (good luck getting that question answered!)
How is manufacturer rating them? (good luck getting an answer to that question!)
I have 1000# bars for my Hensley because...well that is the smallest rating they have. I'd prefer them to have more flex, BUT they have a lot more flex than the 1000# EQ bars I originally had.
When I used my Reese DC, I had 600# bars and had no problem returning appropriate weight to the front axle....with a variety of 1/2 and 3/4 ton trucks and SUVs.
Pics are of a Denali with auto level control dis-engaged for WD adjustment.
I'm not saying all 600# bars are equal among manufacturers, but this was the best riding setup I have experienced to date. Wish Hensley had bushings and bars at 800#s.
BTW, my TW is 850# to 950# depending whether bikes and rack are on the tongue. 30' Classic.
-Rich-
02-16-2016, 03:14 PM
#28
2016 30' Classic
Livingston
Rob: seems like your truck is pretty close to level with the 800 lb spring bars. More important is the drag on the shank. 6 inches seems way too low to me. Do you have a rise or drop on the hitch?
02-16-2016, 03:34 PM
#29
Hurst
No, I don't... but going back to my original post, may I remind everybody that I'm not going to use this hitch. I will replace it with a hitch with more 'spring' to the bars (tapered, probably).
So, a couple more date points:
When I level the trailer to the driveway, the top of the ball receiver is at about 17" from the concrete. On the truck, the top of the ball is about 18" from the driveway. I'm thinking that there should be more like a 2" difference.
I hope I'm not being a nuisance with this... this is all new to me. With our Casita, I was hooked up and gone in about the time it took me to type this reply!
02-16-2016, 04:19 PM
#30
2016 30' Classic
Livingston
Rob: Where are you measuring the hitch receiver from? Assuming everything is level, measure from top of receiver and not top of ball. Measure coupler from top of ball and subtract ball size. If the former is higher than the latter, you need a drop by the difference but if latter is greater than former, you need a rise by the difference. My strong suggestion is that you reach out to Reese for my assistance since the 6 inch clearance on a F150 seems way too little. Good luck.
02-16-2016, 08:50 PM
#31
2012 23' FB International
Woodstock
, Ontario
My experience is that you need bars rated higher than the tongue weight ..obviously, but if you go too light then the bars get bent severely and that puts a strain on everything. I would try bars rated about 100 lbs heavier than your tongue weight. The bars should not be flexed too severely when the rig is pulled up level; if they are then they are too light.
JCW
02-16-2016, 08:53 PM
#32
Oswego
JCW
I don't believe it to be obvious. If the bars are cold rolled, you may be right. If they are spring steel, flexing is what they are supposed to do.
-Rich-
02-17-2016, 07:32 AM
#33
Woodstock
, Ontario
dznfOg. You're right, but my point is that if the bars have to be pulled up so far that they look like a BOW, then they are too light. I had 750# on my 25' '89 pulling with my Dakota. The bars were flexed into a very pronounced curve. I added helper springs to the truck raising the rear wheel well about 1.5" and the 750s were fine. I estimated the tongue weight at about 700+ lbs using a bathroom scale and lever arrangement.
JCW
02-17-2016, 07:45 AM
#34
Oswego
JCW
See my pics above....and look at the Blue Ox ad in this month's trailer life (good clear pic). They both show a proper amount of flex in a well set up system.
I believe that MOST tapered bars are spring steel, but can't be sure. I am pretty confident that Blue Ox sway Pro and Reese DC are spring steel. My Hensley is a bit tapered, but I am not confident that they are spring steel and not cold rolled. They are 1000# bars, and do flex a tiny amount, but not much. BTW, in my conversation with Hensley some time ago, they indicated that most all round bars are made by the same supplier and hitch manufacturers use common bars, with some dimensional differences.
Of course, even spring steel can be stretched beyond its limits, but I maintain, a healthy bow is a good thing in WD spring bars.
-Rich-
02-17-2016, 07:55 AM
#35
Oswego
Here's a pretty decent shot stolen from the Sway Pro website, but the one in TL is taken on a flatter horizontal plane:
-Rich-
02-18-2016, 08:08 AM
#36
Woodstock
, Ontario
[QUOTE=dznf0g;1750733]Here's a pretty decent shot stolen from the Sway Pro website, but the one in TL is taken on a flatter horizontal plane:
Those appear to be spring steel since they are lighter than the ones on my '89. I sold the trailer and hitch to a guy with a Honda Ridgeline. The bars were much more bowed than the photo when he drove away. The hitch was a Reese. I think if you have to jack the trailer up so high it 'hurts' , just to be able to lever the cam-locks into place then the bars are too light. That was certainly the case with my Dakota until I added an extra leaf and helpers to the rear springs. My current set up is a Hensley and the bars are 1000#. Can't relate them to my Reese since the Hensley doesn't use the cam-locks.
JCW
02-18-2016, 08:23 AM
#37
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We used the Hensley Arrow 1,000 pound bars on our 2013 25FB International Serenity that had a literature tongue weight of 833 pounds. The real number when we picked it up with only full tanks (water & propane) and the street and rear awnings installed by the dealership was 1,150 pounds. We towed with a 2007 Mercedes ML320 CDI diesel with air suspension. When loaded for camping, the tongue weight was now 1,175 pounds and the Mercedes was overloaded on the axles. We upgraded to a 2012 Ram 2500HD diesel.
The 25FB became a 2014 31' Classic that is towed by the Ram.
The 2015 23D International Serenity has a literature tongue weight of 720 pounds. After all the modifications, the tongue weight camping ready is 968 pounds. We are still using the Hensley Arrow 1,000 pound bars and towing with the same Mercedes.
02-18-2016, 08:40 AM
#38
Oswego
This from Hensley....bar rating should be below actual TW:
http://blog.hensleymfg.com/Safe-Towi...itch-Selection
They state that the bar rating should be matched to the amount of weight needing transferring with a loaded trailer and TV...NOT the rated max tongue weight of the trailer.
I can't find any other manufacturer that states anything. I think links and factual quotes from manufacturers should be the direction of this thread. Maybe some of you are better net searchers than I. Let's see what we can find.
(I suspect we will find many variations between manufacturers and how they rate their bars)
I reiterate, I wish Hensley would provide lighter bars, per their recommendation...I don't need to transfer 1000#s on my 950# (max actual weighed TW....sometimes less). I need to transfer, at most 500#s.
-Rich-
02-18-2016, 08:51 AM
#39
Oswego
And...Reese says to match to the total weight of the load...cargo plus Actual TW. Contradiction to Hensley.
http://hitchworldinc.com/catalog/section6.pdf
IMO, this method disregards WHERE your load is in the truck and has no correlation to HOW MUCH weight you need to transfer.
-Rich-
#40
2013 27' FB International
El Dorado Hills
Switz makes a good point about tongue weight. The Airstream claimed factory weights are notoriously low. My 27FB 730 lb factory specification weight was closer to 900 lbs when weighed using a Sureline scale. You may actually need heavier bars than you think.
