Old 09-13-2018, 07:01 PM   #43
2016 28' International
Sioux Falls , SD
Originally Posted by runtime View Post
Was checking out the Propride 3P on the Propride site and saw the guarantee I pasted below. At $2,000 cheaper I'm temped to try the Reese Staight line /duel cam sway first before dropping the $$$ on the P3. Any first hand experience withe the Reese straight line... Out there?
Purchase Reese hitches with confidence backed by the ProPride Towing Comfort Guarantee!
If the Reese Straight Line Hitch with Dual Cam Sway Control does not provide you with the towing stability you desire you can apply 100% of the purchase price toward purchasing a ProPride 3P. We have you covered for total towing comfort and stability.
They are betting you will not know the difference, most wonít.
Only if you have towed with them BOTH will you know.
I have towed with them and will not tow without my ProPride.
When comparing products / bids. The cheapest will ALWAYS be the most expensive in the end.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 09-13-2018, 07:07 PM   #44
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Reese on my 2006 25' AS worked fine 2.5 years we towed. 2008 25' AS had an Equalizer which broke while backing; one of the stabilizer bars twisted. Dealer in Phoenix had a SwayPro from BlueOX in stock so I went with that. Worked great for the 2 years we had that AS. With our new 2014 25' AS, we went with SwayPro again...no issues for the 3 years we had that AS. I was very happy with the performance over 3 years, keeping the 25' AS in line even in very scary swerving maneuver caused by "wreck-less" driver changing lanes and trying to pass me on the right; I was going 65mph...the SwayPro did it's job along with the F150 sway control; maintained control.
Fast forward; we have had our 2017 28' AS 15 months now with a SwayPro...very happy with the ride and stability. Lots of choices out there...I like the BlueOx. You need to understand the set up and how it works compared to other WDH with sway control options...there are many choices, as you may know; also lots of opinions.....
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 09-13-2018, 08:25 PM   #45
runtime's Avatar
2004 28' International CCD
Isn't the Reese Hitch a Propride Product o r am I mistaken?
runtime is offline   Reply With Quote
Old 09-14-2018, 10:10 AM   #46
2007 22' International CCD
Need advice on the best anti-sway hitch.
Reese and ProPride are two totally different companies.
I have a ProPride and flat will not tow anything with an A-frame and ball hitch configuration without one.
Old 09-15-2018, 03:20 AM   #47
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I had a Hensley......it was sold with the trailer.....I went to Reese duel cam , I like it much better...13 31í Classic with a 17 ram 2500...6.7..coils on the rear
Old 09-16-2018, 05:29 AM   #48
Hans Grim's Avatar
1993 29' Excella
Brighton , Ontario
Iíve got a Hensley on my 29í and am interested in what you like better about the Reese. I find with the Hensley, the WD doesnít make much difference as it did on the smaller Ford Explorer that I used to pull with.
Hans Grim
1993 29' Excella
2011 GMC Sierra 2500 HD 6.0L
Hensley Arrow
Hans Grim is offline   Reply With Quote
Old 09-17-2018, 05:15 AM   #49
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
.....for one thing with the Hensley, you had to be at the same level ,sideways and length ways...to hook up..real often I had to drive the pickup up on blocks. on one side to be level .....we park at a lot of places where the ground is unlevel every which way..now at a fairgrounds...it is unlevel every direction..no problem hooking up with the Reese..we have 7800 on the axles and 10050 on the ball...17 2500 ram...6.7...went to Nova Scotia, 3200 miles now drifting home....
Old 09-17-2018, 10:32 PM   #50
Hans Grim's Avatar
1993 29' Excella
Brighton , Ontario
I had problems with it originally, then got used to using the tensioners on each side to twist the head left, right, up and down. Usually worked, although there were a couple times I had to get pretty radical, including one time totally dismantling the hitch to attach it to the TV. It is a lot different from hooking up my boat trailer. Thanks for your insight. The HAHA is original to the AS so 25 years old, so looking. Hope you enjoyed NS. Drift careful.
Hans Grim
1993 29' Excella
Hensley Arrow
Best Weight Distribution with Anti-sway cazual6 Hitches, Couplers & Balls 59 04-24-2019 08:53 AM
Anti-Sway Bar or WD with Anti-Sway for 19' FC? CanonFan Towing, Tow Vehicles & Hitches 32 09-20-2016 05:29 AM
Best Anti-Sway Hitch? kswelsh Hitches, Couplers & Balls 19 08-27-2012 11:27 PM
Anti Sway Hitch? TG Twinkie Hitches, Couplers & Balls 10 09-07-2010 08:33 AM
Best combo WD anti-sway hitch wacnstac Hitches, Couplers & Balls 6 03-03-2006 02:59 PM
