Old 04-05-2014, 08:32 AM   #29
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
LizGK,
Hope it is simple and an easy fix.
While you're focused on your brakes, pretty sure I read that you have disc brakes. Right?
Did the PO tell you if this trailer had the recall repair for the brake hoses?
Info is in a stickie in the brakes forum.
Those Dexter discs are darn good when all working the way they can work.
Good luck.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 04-05-2014, 08:49 AM   #30
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Have the tech ensure the brake trigger feed goes to the correct ( switched ) side of the brake light switch. If you are using the factory harness this should not be an issue.
Old 04-05-2014, 08:51 AM   #31
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Again I suggest a prodigy 2 or 3 and be on your way home. They are both essentially the same with one being sexier than the other....
Old 04-05-2014, 10:31 AM   #32
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I used the Prodigy RF trailer brake controller on my early 2007 Mercedes ML320 CDI built in October 2006 as the trailer brake wire harness could not be connected without pulling the interior out of the car. Three months later the wiring harness was put in the proper place in the vehicles on the Mercedes assembly line. Nuts!
So be sure the controller you select has an option for a hydraulic disc brake pump and controller!
switz is online now   Reply With Quote
Old 04-05-2014, 10:57 AM   #33
2006 30' Classic
Milton , Florida
Brake Controller
Originally Posted by LizGK View Post
Ford 250. Let me find out about the acti-brake unit.
What model year is your Ford F250?
Does the truck have, or did it ever have, the Ford integrated trailer brake controller?
Has the Airstream recall work been performed on the brake hoses for the Dexter hydraulic brake system?
Has the recall work been performed on the ActiBrake E/H actuator?
The answers to these questions may help the shop to troubleshoot the problem.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 04-05-2014, 11:13 AM   #34
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
At a complete stop pressing the brake pedal does not engage the actuator but sliding the manual bar on the controller will activate the brakes. I know this because I recently bled my trailer brake system this way. The Ford integrated brake controller should work fine. Mine is set at 7. I suspect your brakes are working fine. It agree that you should get rid of the actibrake actuator that has been recalled.
4RXLA is offline   Reply With Quote
Old 04-05-2014, 02:10 PM   #35
LizGK's Avatar
2008 31' Classic
Rochester , New York
After spending the day on this problem it appears we have a faulty Genesis brake controller. At least we now know the problem and can work on the solution. Regrettably it will require a return trip from Rochester to Cincinnati.
Tested it out in a parking lot and breaks just don't engage. Tried different positions of the Brake controller and it would engage some times and not others. Worked great if you just shook it!! But with 500 miles to drive I doubt that's a sensible solution.
I so appreciate all of the advice and support today. Thank you.
LizGK is offline   Reply With Quote
Old 04-05-2014, 02:12 PM   #36
4RXLA's Avatar
Images: 33
That's too bad and also unfortunate that the integrated controller that came with the truck is also not functioning.
Old 04-05-2014, 02:21 PM   #37
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
So why not buy a new controller take 3 minutes to wire it in and drive your new Stream home? You'll save 1500 miles of fuel!
We can talk on the phone and I can talk you through the process....
Really its 3-4 minutes!
Like I told you.... all of those are faulty... replacements will also be faulty.
Help Need Towing Advice for my Nissan with no brake controller dmcinfo Tow Vehicles 9 07-07-2010 05:21 PM
Need some brake source info ASAP 1974ARGOSY26 Brakes & Brake Controllers 12 02-27-2010 08:18 AM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
need to replace window for '83 airstream limited asap, please help! johnnyfl Windows & Screens 0 08-07-2008 07:39 PM
Need an Inspector in Tucson, Arizona ASAP, please! sierrajb Our Community 11 11-05-2006 04:25 PM
