Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 02-26-2004, 07:03 AM   #1
dhe9
Profile:
MPG with camper shell
thinking of installing a cab high camper shell that weighs in at 175 lbs on my truck. i would think that my MPG while towing my bambi will improve some because of no drag in the back of my truck. anyone see an improvement with the addition of a camper shell?
thanks,
david h
'03 19' bambi
2005 CTD DIESEL
SEMPER FI
RETIRED USMC
dhe9 is offline   Reply With Quote
Old 02-26-2004, 09:23 AM   #2
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
Some time ago, a university research team put a truck in a wind tunnel, and tested various methods of reducing its drag. The results were published on their university web site. I can't find that any more.
The tonneau cover came out on top in drag reduction. IIRC, dropping the tailgate and a net only helped a little, and a camper shell actually increased drag.
The results certainly might be different with an Airstream drafting up close behind the truck, but I wouldnt' say for sure.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 02-26-2004, 09:35 AM   #3
ke4pk
ke4pk's Avatar
Profile:
Images: 8
Smile
I HAD A FRIEND WHO ADDED A COVER AND HE NOTICED NO DIFFERENCE.
ke4pk is offline   Reply With Quote
Old 02-26-2004, 10:22 AM   #4
j54mark
Profile:
I've towed ours with the same truck both with and without and the difference is too small to measure.
Mark
Old 02-26-2004, 11:17 AM   #5
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Simple airodynamics. If you want something to go fast it is tear drop shaped. It parts the wind and then guides the air back so it can slip through.
With and abrupt end to the body then the air creates vacuum on the back of the vehicle. That's a much larger area with a raised top shell. Car manufactures have know this for years. Take a 70's Suburban or even GM and Ford vans. They are their widest and highest at the B-piller on ALL of them and all three taper down to the rear. That taper, that is not even noticable to the average person, was worth a few points in drag CO.
Yeah the raised camper shell may help with towing a vehicle taller then the tow rig but on a Airstream I doublt it will provide any noticable improvment simply because the rounded leading edge of the Coach already does this.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
