Old 08-19-2013, 02:18 PM   #21
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Just returned from a 4,000 mile two week trip from PA, (Pittsburgh) to North Sydney NS with stops in NY, MA, ME, New Brunswick and Nova Scotia on way up and similar on way back with last day 660 miles in one shot towing a 30' Flying Cloud. While towing averaged 13.5 MPG with a 2012 Ford F250 6.7 Diesel and 3.55 rear end, Crew Cab, 6-3/4' bed. Diesel performed better than anticipated with one exception - used over 4 gallons of DEF. Not a big deal, just a surprise. Also, if anyone is making the trip from the US, when you see an Ultra Low Sulfur fuel stop - stop. At times they are few and far between.
SAFE TRAVELS
Bud
Starting to Look (AGAIN) Number 5 Hopefully
USAF Training Instructor (TI) - 68-72
Old 08-19-2013, 03:51 PM   #22
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The biggest factor in fuel usage when towing is wind resistance, and frontal area of different size airstreams doesn't vary a lot. Headwinds/tailwinds matter. Allow 13 mpg no matter what you use (diesel will do better but has higher fuel, additive, and maintenance costs), sometimes better or worse, and you'll be pretty close.
doug
Old 08-19-2013, 05:41 PM   #23
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The rule of thumb is to deduct 30-40% from solo mpg at the same speed.
A TV or TT with poor hitch rigging, bad bearing or brake adjustments, alignment, etc (such as offroad tires and lift kit) will simply pay a higher price every mile; a 40% deduction or worse (given other factors remain constant).
A 30% increase in fuel burn for my pickup would be 16.8-mpg. That's currently a goal for the average (non-mountainsous). But wtihin reason.
Once vehicle spec is set, it is is not amenable to lower fuel burn outside of gearing and aerodynamic improvements.
Driver skill (read, planning and discipline) remains the bellwether for improvements. "Smart spec", first, and "smart use" second.
Old 08-19-2013, 06:47 PM   #24
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
2012 F250 Crewcab, 2012 30' International. 13.5- 15.5 going the speed limit.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 08-19-2013, 07:04 PM   #25
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
doug
Just back from an 1800 mile round trip to Boston and Quebec City. Most of the way to the coast we had the strong wind behind us and achieved a daily best of 13.4 mpg. Coming back down the autoroute between Quebec City and Gananoque in Ontario into the teeth of a wicked head wind I could only get 10.4 mpg with the automatic transmission staying in 5th rather than 6th for most of that day's trip. Wind is a killer.
We tow a 2011 International with a 3.5l V6 Sienna minivan, which will get 28 mpg when not towing (with the wind behind me!).
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 08-24-2013, 04:28 AM   #26
Airstreamer67's Avatar
With my 1996 F250 with the 7.3 diesel engine I can depend on 14 mpg towing through a combo of prairies and mountains.
Airstreamer67 is offline   Reply With Quote
Old 08-29-2013, 09:59 AM   #27
Whizzo's Avatar
2014 23' FB Flying Cloud
San Antonio , Texas
Images: 18
Towing the same Sport 22 trailer (loaded weight about 3580 lbs) with two different medium-sized SUVs, we experienced MPG ranges of:
Ford Explorer 4.6L V8: 12-14 MPG
BMW X5 3.0L I6 Diesel: 14-18 MPG
The Sport line was intended for smaller TVs, and we've found that a properly matched medium-sized SUV works well to balance towing performance and daily driving, if you can't or don't have a full-sized pickup for dedicated towing.
2014 Flying Cloud 23FB
2015 Ram 1500 EcoDiesel
Whizzo is offline   Reply With Quote
Old 09-03-2013, 11:16 AM   #28
2014 27' FB International
Kalispell , Montana
13.5 avg from Kalispell MT to West Yellowstone. 27FB International. Started at about 3000 feet and ended up at around 6200 feet..
AlphaInfinit is offline   Reply With Quote
Old 09-03-2013, 12:08 PM   #29
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
13mpg with the 2005 V8 Tundra and 23ft Safari, 18-20mpg solo
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Airstream parkway 2006 2500 mpg with toad? Jgjimgrn Sprinter and B-van Forum 3 03-03-2012 12:03 PM
Argosy 20' motorhome 350 MPG and towing? ViewRVs Argosy Motorhomes 6 01-19-2012 08:13 PM
2011 Tundra Double Cab TV mpg Goal15 Tow Vehicles 3 08-06-2011 11:11 AM
Truck Shells and MPG Secguru Tow Vehicles 25 02-20-2011 04:57 AM
