Old 05-24-2012, 12:21 PM   #1
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
More LTX M/S tire pressure?
I normally tow with a gas-guzzling, vintage Suburban with big ole E load range tires. I'm comfortable towing with 44 psi front, and 65 psi rear.
Economics has forced me to use my wife's '09 Yukon for the next trip due to the amount of miles we have to cover.
The door sticker wants 32 psi tire pressure all around, and makes no distinction about tire pressures for towing.
Today's test ride had little bit of a "tail wagging the dog" feel about it.
The Michelin LTX M/S tires I just had mounted have a max pressure rating of 44 psi. I'm thinking about boosting the all-around pressure to either 38 or 40 psi for a better tow. Any thoughts?
Tom
Old 05-24-2012, 12:29 PM   #2
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Sounds like those are Load Range C tires. The sticker on the door gives pressures for an unloaded vehicle—a couple of passengers and a few other items. I'd put 44 psi in them for towing, but you can check tire charts for the pressure recommended for the weight of the truck axles and specific tires. Some tire store chains have charts online or Tire Rack does too.
Gene
Old 05-24-2012, 01:46 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I do not think there is any real advantage to running them less than the full 44 lbs max. for towing.
Old 05-24-2012, 04:29 PM   #4
SteveH's Avatar
Common Sense , Texas
Run the rear tires especially at 44. The front you can run at 35. That will reduce the tendancy to sway, but if you run all four of them at 44, it probably will not.
Old 05-24-2012, 04:43 PM   #5
TomW's Avatar
1967 26' Overlander
I do not consider it "sway"
Originally Posted by SteveH View Post
... That will reduce the tendancy to sway, but ...
Thanks, SteveH, for the response. Sway, in the sense of being bothered by wind or passing trucks, was not the issue on the test ride. My observation was squirrelness in general.
I kinda lean towards pumping all the tires up to the same pressure since much time (and a few dollars) were spent dialing in the Airstream's Reese Dual-Cam to distribute the tongue weight to all four wheels.
Tom
Old 05-24-2012, 04:49 PM   #6
SteveH's Avatar
I know what you are saying, Tom, but try it both ways. With the front aired up the same as the rear, the stearing response will seem too fast, and actually add to the squirrlyness you experienced, it has been my experience.
Old 05-24-2012, 09:03 PM   #7
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Tom W, I run mine at 40psi
Ahab is offline   Reply With Quote
Old 05-24-2012, 10:23 PM   #8
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Michelin did not put 44psi on the sidewall without considerable thought.
And, that is 44psi cold.
Load range C is not a lot of tire when you are in trouble.
wingfoot321 is offline   Reply With Quote
Old 06-02-2012, 06:06 AM   #9
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Load and pressure must match. And stay "within" vehicle manufacturer guidelines for FF/RR bias (see owners manual).
The tire dealer can check the data he has to help dial in the pressure.
Again, a scale ticket from a weight scale is your friend: With and without trailer to find the individual axle average.
Too much pressure reduces the tire contact patch and this is NOT the right way to achieve best handling & braking. Too little heats the tire unnecessarily and shortens life.
I have a set of pressure values to use for my truck:
1] solo/empty,
2] solo/loaded; and
3] solo/loaded + towing.
According to tire engineer Barry Smith the ideal pressure on the TV is the one where
after an hour of steady state driving, the pressure rises no more than 3-5 psi from the cold measured value.
(Raise or lower in 5-psi increments and test again until ideal number is achieved).
Example: where DODGE tells me that 50-psi is correct, a morning drive will reveal if the pressure rise is spot on. If not, then I can move to 55-psi and repeat test. But I cannot go below 50-psi even though MICHELIN shows this as acceptable per weight scale reading . . it violates the DODGE number (which is acquired through extensive testing on their part).
In a sense, I want the lowest number, but no lower. Higher offers no benefit.
As a second insight, the truck industry spends an enormous amount of money on tires. Pressure according to load is the mantra. Each trucking company works with one or more tire service representative to come up with the ideal value for their trucks. One company down the street from another doing the same work can arrive at different numbers even where the tractor & trailer are nearly identical (as are loads). One may call for 105-psi and the other 95-psi.
There is a great deal of time and money involved in setting those values. For RV'ers we are, IMO, well advised to follow the example of so high, but no higher for longest life and best performance.
The best TPMS is also a good idea.
slowmover is online now   Reply With Quote
Old 06-02-2012, 08:48 AM   #10
SteveH's Avatar
The required tire pressure while towing is as much about stability as it is about load carrying capacity.
First, your vehicle must be able to carry the additional weight the trailer puts on it, and second, it's extreemly important your vehicle has the stability to manage the trailer.
The tire pressure that will carry the weight (from the tire spec charts), may not be enough pressure to make the tire stable enough to manage the trailer. That pressure must be found thru experimenting while towing the trailer, it has been my experience.
Old 06-02-2012, 09:06 AM   #11
TomW's Avatar
1967 26' Overlander
Thanks, everyone, for the responses.
Getting the Yukon ready for the trip took more effort than I thought it would. The biggest surprise was the new shank (black part in picture) that had to be purchased to accommodate an unusually high receiver.
Fortunately, it only took two iterations of setting up hitch height/pitch to get the same amount of drop at the Yukon's fenders with the Overlander riding level. I used 550-lb bars with the Airstream's Reese Dual-Cam. The bars were more than sufficient: Sway was NOT an issue.
I went with Ahab's post of 40 psi all around, and never felt any reason to change it. The truck's on-board tire pressure monitor let me see that the front tires heated to 44 psi, and the rear to around 46 over the course of the 2000 mile vacation.
While 10.4 mpg was a little lower than hoped for, it sure beat the Burb's 5-8 mpg on mid-grade gas for such a long trip.
Looks like we will be using the Yukon more for towing.
Tom
Old 06-02-2012, 09:30 AM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Tom,
Sounds like you've got the TP thing squared away. When it's time I would consider a load D LT replacement.
Noticed in your pic....I would run your umbilical over the top of the A-frame thru a D-lock pin.
Name:	06 BURB SHAKEDOWN TRIP 018.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-02-2012, 09:47 AM   #13
TomW's Avatar
1967 26' Overlander
Bob,
Airstream originally provided a nice, grommeted hole in the top of the Marvel coupler for the umbilical.
I didn't forget to do it the right way, I just didn't remember...
Tom
Old 06-02-2012, 10:19 AM   #14
Thumbs up
Originally Posted by TomW View Post
Bob,
Tom
I hate when that happens....I spend time with my morning coffee deciding what I need to forget that day to make room for what I may need to remember.
PFC
"Tahawus"
RLC
John Prine
