Old 10-31-2014, 09:23 AM   #1
Wild Robot's Avatar
Washington , D.C.
Minivan Towing
I was told there are folks here towing with Minivans, but the search feature on this forum returns some odd results so I'm starting a new thread.
My plan is (was) to go for the 16' Sport (or something with equivalent weight ratings) as my first Airstream. It suits my needs well and would be paired with my 2012 Dodge Grand Caravan R/T with tow package (bigger brakes, upgraded rear shocks etc.).
While the tow ratings for what I can pull and tongue weight work out I ran into a snag...the GCWR of my van is 7000lbs
Curb Weight of van is 4510 + Base weight of Bambi 2810 = 7310
There's nothing left for payload.
I get people using reinforced hitches but how does that overcome the GCWR ratings of these 'smaller' vehicles? I've been looking into what people are towing with and the numbers don't add up.
I'm not buying a truck.
I'm looking for feedback and suggestions. Is what I want to do possible with an Airstream? I'll be pulling mostly up and down the east coast with the occasional jaunt over to the midwest.
Thanks a bunch!
Wild Robot is offline   Reply With Quote
Old 10-31-2014, 09:30 AM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
There are people on here towing with a Toyota Sienna and a Honda Odyssey.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-31-2014, 09:39 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
There's a lot of folks towing with vans and doing well. Here's the Airstream dealer who specializes in combinations of this type, contact them:
Can-Am RV :: T & C Van towing 28 Airstream
There will always be a lot of people telling you why you can't do it but you may be more interested in those telling you how you might. Do the research, then you can decide for yourself.
You can't just hook up and go, it takes a specialized setup by those few who know what they are doing.
Doug and Cheryl
Old 10-31-2014, 10:11 AM   #4
SteveH's Avatar
Common Sense , Texas
Thanks a bunch!
Yes, there are people doing it, and successfully. They are mostly in Canada and set up by the dealer in London, Ontario.
But to try and answer your question of how does the hitch reinforcement overcome the GCWR ratings, I think if you dig deep enough, and ask those who do it, they will tell you either that the engineers that determined that spec know nothing so therefore the spec means nothing, or, some of the most honest ones will tell you they simply ignore it.
Good luck with your setup, and I personally believe you will have no trouble towing a 16 footer with that vehicle, and that is based on some of the things I've seen people do on this forum.
Regards,
Steve
Old 10-31-2014, 10:15 AM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
There is a fellow on this forum whose screen name is MrUKToad who tows a 25 or 27' AS with a minivan. I suggest you contact him directly in case he is not monitoring the forum. He lives in Ontario and I suspect got his setup at CanAm.
Bob Martel
WBCCI# 5766
Old 10-31-2014, 11:05 AM   #6
Gainesville , Florida
Unless I missed it, what engine in the van?
Old 10-31-2014, 11:41 AM   #7
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
No problem
You'll be fine.
Not long ago, a thread including this subject was closed because it became ugly. Evidently towing with a mini-van infuriates the faction that approves only of towing with Big Butt crew cab Diesel Dually or a minimum ¾ ton and/or pro-pride/hensley. It was stated that the only way that you can tow with a mini-van is to have it "dusted by a Fairy".
My Fairy was sorry to see that thread closed, as she had dusted our '07 Dodge Caravan about four years ago, and We've been towing thousands of comfortable miles without incident.
Among other things, she dusted Our mini-van with a set of Michelin LTXs, tossed the back seats, and added a Reese class three hitch and Reese mini-lite 350 anti-sway/weight distribution.
My service manual says not to exceed 40sf of trailer frontal area. It does not assign that frontal area to any particular speed, which makes that figure appear somewhat arbitrary. Fairy says that puts all the towing spec's in question, and to trust her... Most 200 horsepower 4000 pound American cars can be set up to safely tow a 3000 pound trailer.
Hitched up, in camp-able condition, we cross the scales at 6,900 pounds. Travelin' light... and it handles as well as my old 1LE Camaro.
I questioned her about the missing six hubcaps, and got a dissertation on un-sprung weight and brake cooling... I suspect that she may have stolen them and spent the money on dust.
Love her anyway...
Name:	caravan fairy.jpg
ALUMINUMINUM is offline   Reply With Quote
Old 10-31-2014, 11:55 AM   #8
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
As close as that is to the posted limit of your van, I would not say "don't", but I would say "with some exceptions." Definitely talk to the CanAm folks. My main suggestions are (and I bet CanAm will say this also)..... get a good hitch setup, and make sure you have VERY good cooling for your transmission. I'm sure there are larger coolers that can be added to your van, from non-fan-cooled to fan-cooled. If a fan-cooled version is available, I would go with that one if it means more heat capacity. Then, keep up with your transmission fluid/filter changes. Don't hesitate to change it before the owner's manual says it's needed. That is cheap insurance as far as I'm concerned. Then, keep in mind that you are on the high side of your limits, pack accordingly, then ENJOY YOUR AIRSTREAM!
(You might even consider some sort of heavier-duty cooling for the engine, from the radiator to maybe even an oil cooler. Some might think it's overkill, but HEAT is a big killer of engines and transmissions.)
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 10-31-2014, 04:45 PM   #9
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I towed a 3,200 lb popup all over the western US with a 1989 Grand Caravan (140 hp), and all without any weigh distribution and full load in the van. Didn't know any better and never had a problem.
kscherzi is online now   Reply With Quote
Old 10-31-2014, 05:23 PM   #10
jcl
Vancouver , British Columbia
It didn't make sense to me that the GCWR you quote was so low. So I looked up the 2012 Grand Caravan, and found the same 4510 lb curb weight you note, but the Chrysler document stated that the GCWR is 8750 lbs. Where did you get the 7000 lb figure from? Are there different figures published for with and without trailer brakes?
I got the owner's manual with the 8750 lb figure here:
My Dodge: Dodge Owners Service Manuals - Dodge Cars, Minivans, SUVs
Jeff
jcl is offline   Reply With Quote
Old 10-31-2014, 06:34 PM   #11
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Yes- it can be done safely. We tow our as yet unfinished Bambi II with a 2004 Ford Freestar with a 4.2 and weight distribution hitch. We were set up in London, Ontario.
We are very happy so far.
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is online now   Reply With Quote
Old 10-31-2014, 07:22 PM   #12
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
Properly Equipped you can tow the Bambi 16' with an high output 4-cylinder car. You may not win any drag races passing past 65MPH though.
With the minivan and or car with somewhat recent V6, many more options open up.
Talk to Andy.
timhortons is offline   Reply With Quote
Old 10-31-2014, 10:51 PM   #13
Wild Robot's Avatar
Washington , D.C.
3.6L V-6 283 HP engine
260 lb.-ft torque
3.16 ratio
Old 10-31-2014, 11:05 PM   #14
Wild Robot's Avatar
Washington , D.C.
Jeff
Well a big THANKS to you sir. You are exactly right. I was using Cars.com and Edmunds for my research specs. I intended to get the manual but I live alone and I'm recovering from recent surgery so couldn't walk to elevator and then garage in my building.
Anyway, thank you for pointing that out to me. It certainly changes the math.
With a GCWR of 8750
Curb Weight of van 4510 + Base weight of Bambi 2810 = 7320
1430lbs of combined payload works for me so my plan is still on track....but think I'll take a gander at a capable SUV just for the fun of it anyway.
Thanks again.
Sprinter one-ton towing/non-towing hwy mpg? gecko Tow Vehicles 18 08-02-2014 10:57 PM
Can 1982 280 Turbo Diesel tow a minivan? swanky Tow Vehicles 20 07-12-2009 08:20 PM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Anybody towing with a minivan? beachbox Tow Vehicles 21 09-26-2007 03:56 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
