Old 11-18-2014, 04:48 PM   #1
Houston , Texas
Mercedes Sprinter 4x4 Tow Vehicle
I'm considering purchasing a 2015 Mercedes Sprinter cargo van as a tow vehicle for a Flying Cloud 28. The Sprinter is a 4x4 diesel V-6 with 7500 lb towing capacity, and will only have a couple kayaks, a moped and two passengers inside. The Cloud's base weight is 5979 lbs and I don't expect it to go above 7000 total weight. I'll be traveling mostly in the south, southeast, and mid-west, and not likely to go over the Rockies.
Any one see a problem with this combination, or have a better alternative?
ibwo is offline   Reply With Quote
Old 11-18-2014, 05:05 PM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
I've seen many Sprinters towing the past few years. FEDEX fills them to the ceiling with freight; Airstream and others 'Interstate' them.
I haven't reviewed the numbers, but can't see why they wouldn't make excellent TVs.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 11-18-2014, 05:36 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Are you buying an aftermarket 4 X 4 conversion? If not, where are you sourcing the Sprinter? I do not think that Mercedes if offering their 4 wheel drive Sprinter in the US yet, as I heard 2016 or 2017 as the target date.
Old 11-18-2014, 05:46 PM   #4
TinTin's Avatar
Canmore , Alberta
Lew, 4x4 is available in 2015 models in Canada. A long way from Houston mind you.
Bob and Nancy
Old 11-18-2014, 05:50 PM   #5
Houston , Texas
Production of 4x4 Sprinters for the US market starts in January 2015. I believe they are manufactured in Germany, shipped as a kit and assembled in the US. I read that there are only 1700 shipping next year. I think pre-orders started Nov 1. My local Mercedes salesman says he is only allocated eight and has already sold half of them. No discount off msrp. They're expensive, but are the only 4x4 cargo van without aftermarket conversion. I think one will work well as a toyhauler TV, but at about twenty feet, it is going to make for a pretty long rig.
Old 11-18-2014, 06:23 PM   #6
lewster's Avatar
Thanks for the update!!!! Very cool indeed!!!!!!!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 11-19-2014, 11:40 AM   #7
Mission Viejo , California
Are these the shorties with the low top? I could go for one like that.
Bill Lynch is offline   Reply With Quote
Old 11-19-2014, 12:29 PM   #8
Houston , Texas
Shorter or longer. Low cargo deck on either, and a higher roof if you want it.
Mercedes-Benz Sprinter: Build & Equip
Old 11-19-2014, 02:01 PM   #9
slpiotro's Avatar
2007 23' Safari SE
Madison , Wisconsin
Send a message via ICQ to slpiotro
mercedes tow v.
I have been towing my 23 Safari SE with the Mercedes ML350 Diesel for almost six years now. Absolutely beautiful as a tow vehicle. Had one series of problems with an electrical system fault from water leakage, but the same diesel and transmission as the sprinter with the same load capacities. Never any issues with power, etc etc. Love the set up, great comfort, lots of space for hauling stuff, and just nice to drive.
"Honor those who serve by listening to them and caring. Parades end, caring needs to be there every day."
slpiotro is offline   Reply With Quote
Old 11-19-2014, 03:15 PM   #10
andreasduess's Avatar
1984 34' International
Toronto , Ontario
I drove a Sprinter in Europe. They are excellent vehicles and should serve you extremely well.
andreasduess is offline   Reply With Quote
Old 11-20-2014, 02:21 PM   #11
Houston , Texas
Thanks for the feed back, all. I think I'll go ahead and place the order before it is too late for this year.
Old 01-01-2015, 02:38 PM   #12
Anaheim , California
I have a 2013 Sprinter 144 with a high roof and am towing a 23 Flying Cloud front bed. The van pulls the trailer very well and is amazingly stable with the anti sway bar attached. Before attaching the sway bar, on the freeway the van would "wiggle" slightly and quickly set off the anti skid sensor and put the engine into a safety power mode. My dealer did not recognize the code on the dash so it took me a while to figure out the problem.
I would like to get the 4x4 option someday so let us know how yours works out.
smorefield is offline   Reply With Quote
Old 01-06-2015, 12:42 PM   #13
walk0080's Avatar
Toronto , Ontario
There is an aftermarket hitch for the Sprinter that apparently can handle 1,000#/10,000# using a weight distribution hitch... Curtis maybe? But only 5,000 without W/D.
So glad the Sprinter will be available as 4x4 - finally. Added bonus in CAnada we don't have the Chicken Tax so they are shipped assembled from GErmany. By the looks of it even the 3500 Dually models will be available 4x4. And low range is only $300 extra.
walk0080 is offline   Reply With Quote
Old 01-24-2015, 03:43 PM   #14
Ayr , Ontario
The one thing you need to watch out for is that this is a newly designed engine. You don't want the old one. I have an 08 and this engine is strong but unreliable. There are inherent design issues with it. The engine develops an oil cooler leak after a while which is very expensive to repair. In addition the Intake port shutoff motor is a known failure (or swirl motor). Not to mention that the flaps in the intake that this motor controls are known to get completely clogged with carbon causing the flaps to break off and wedge into the engine. I know I am at this point now. Thousands to repair. Thanks MB! I won't be purchasing another one.
These issues are known issues for all euro diesels, since they share common parts and designs.
If you don't mind spending thousands to repair the vehicle makes for a very nice TV. The seats are great and so is the ride. But.......
gator.bigfoot is offline   Reply With Quote
Tow vehicle needed: 4x4 truck jornvango Tow Vehicles 50 12-23-2013 12:39 PM
Which is better to have 4x2 or 4x4 as Tow Vehicle? carl2591 On The Road... 146 01-02-2013 02:54 PM
4x4 versus 4x2 Tow Vehicle BeBop Tow Vehicles 40 11-24-2007 04:57 PM
Sprinter as Tow Vehicle heretolearna Tow Vehicles 8 12-02-2006 07:51 AM
4x4 tow vehicle... or not? Cheryl Tow Vehicles 11 08-22-2002 11:00 PM
