Old 02-08-2016, 09:22 AM   #29
Road Ruler's Avatar
Images: 38
Originally Posted by Andrew T View Post
29 years ago when we first fastened the front of the receiver to a rubber isolated suspension cradle we were really concerned. We did it thinking this won't work but lets just try it and see what happens. There was no affect at all on road noise or vibration, at least nothing detectable. Since then we have done this on a couple of thousand vehicles.
The ones that concerned me more are vehicles like my Jag or Road Rulers Infinity where the Suspension Cradle is aluminum so far though not an issue on either after several years.
Andrew T
Correct re our Infiniti. There is no transmitted road noise from Andy's mods or attachment points and after 200hrs of towing the aluminum suspension cradle is fine. The G35 is now 13 years old and has 255,000klm's on it.
PS.... just the other day we test drove a 2010 Jaguar XF sedan. Very nice V8 vehicle with lots of power.
Old 02-08-2016, 11:22 AM   #30
Tuco's Avatar
1988 32' Excella
Ojai , California
29 years ago when we first fastened the front of the receiver to a rubber isolated suspension cradle we were really concerned. We did it thinking this won't work but lets just try it and see what happens. There was no affect at all on road noise or vibration, at least nothing detectable. Since then we have done this on a couple of thousand vehicles. We had one Hyundai SUV about 10 years ago that had a bit 0f a rumble afterwards but that is the only one.
I think due to the length of the receiver tube and the width of the stock receiver there is enough flex in the hitch to absorb the movement of the axle carrier. When the weight distribution is done up it actually takes a little pressure off of the bushings. We have not seen any accelerated wear of the bushings.
The great thing about the axle carrier is it distributes the downward force to 4 or 6 separated body points. Since we are fastening between the wheels as opposed to behind them on a live axle vehicle it makes a very strong installation.
The R Class in the pictures on Page 1 is friend of ours and it never had any issues. They have replaced it with a newer one while they could still get one but have 110,000 miles on the old one.
I have driven several hundred miles with their 34 Classic and I have to say it is likely the best tow vehicle I have ever driven. Absolutely rock solid on the road but with a very nice ride at the same time.
Andrew T
29 years ago you knew that this was not the correct way to solve the problem. Yet for almost three decades you continued to do the same thing? All this talk about road noise would be moot if the reinforcement was attached to the uni-body and not the carrier. I don't understand why in all that time a proper engineering solution couldn't be found. "Because we have always done it that way" is not the answer. People are trusting and paying you to do it right.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline   Reply With Quote
Old 02-08-2016, 12:07 PM   #31
cameront120's Avatar
1972 25' Tradewind
And those same people have been trusting them for over 40 years. Andy must be doing something right.
What contributions to towing are are you making? If you can do it better, step up.
North Vancouver, BC
Old 02-08-2016, 12:27 PM   #32
Tuco's Avatar
1988 32' Excella
Ojai , California
Been there and done that. I have already given two examples of how to tie the reinforcement to the uni-body with and without the carrier being involved. Both of them complete the reinforcement triangle. Please try and stay with the rest of us...thanks.
Dave & MJ
Old 02-08-2016, 12:40 PM   #33
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Noise and vibration are either transmitted or dampened depending on the mass and strength of a structure. Wonder if the large thickness of tube used to strengthen a hitch and the significant mass of most hitch structures might well dampen out the road noise transmission.
While it is easy to see up and down vertical loading of the suspension, it is hard to see an upward force from the front of the torque arm unless the trailer drops significantly lower than the tow vehicle or the WD preload is exceeded. But maybe it's just a blind spot in my logic. Retirement must turn off those brain cells. Pat
Old 02-08-2016, 12:49 PM   #34
PKI
PKI's Avatar
Tuco, are those two suggestions in another thread? I am only finding your suggestion to tie into the unibody in this thread. Trying to keep up. Pat
Old 02-08-2016, 12:57 PM   #35
Tuco's Avatar
1988 32' Excella
Ojai , California
Yes they were.
http://www.airforums.com/forums/f463...-138296-5.html
Question, you are not running any reinforcement on your X5 correct?
Update: Interesting who posted right after my first suggestion...
Dave & MJ
Old 02-08-2016, 01:15 PM   #36
PKI
PKI's Avatar
That was interesting reading. Thanks for the reminder. Pat
Old 02-08-2016, 02:28 PM   #37
jcl
I disagree with your characterization that this is not the right way to solve the problem. 29 years ago the approach was tried, and there were initial concerns about noise transmission. Testing showed that it wasn't a problem. This is a valid approach, particularly considering the number of times this design of brace has been installed, and we can all learn from it.
All this talk about road noise appears to actually be moot given the occurrence of issues reported after installing many of these types of reinforcements.
You don't actually know what noise would be transmitted and perceived by occupants in the cabin (particularly the rear seats) with the receiver hitch solidly connected to the unibody right under the rear seats.
If you want a full engineering solution someone will need to do a frequency analysis of the components, and probably mount the rig on a shaker table for an extended test. A test could be designed that accelerates the vibration effects, to see what fails first. It is expensive. And all you may have to do to fix a problem if one is found is to add or subtract mass or otherwise tune the system to change the frequency response. You probably wouldn't ever find something better able to handle a vertical load than the vehicle subframe with its multiple encapsulated mounts.
Conversely, we could try and learn from how it has been done and conclude that the damping inherent in the design handles the vibration just fine, and the four or more subframe mounts collectively handle the torque from the single brace adequately.
Jeff
jcl is offline   Reply With Quote
Old 02-08-2016, 05:47 PM   #38
Tuco's Avatar
1988 32' Excella
Ojai , California
Jeff
You have every right to disagree, but it does not make your point any more or less valid than mine. As usual you don't address my concerns but rather focus on the "noise issue". This is just more "Smoke and Mirrors" while falling back on the old and tired cliche "We've always done it this way".
The glaring design flaw is still there and has yet to be addressed. If the goal is to reinforce the hitch to handle more load and the forces applied by the WD setup, why are you attaching it to a component of the vehicle that moves independently of the uni-body and said hitch?
Dave & MJ
Old 02-08-2016, 07:04 PM   #39
jcl
Because the force that matters at the front of the torque strut is vertical, not in other planes. There is no need to create a triangle or box.
Because the rear subframe is designed to handle loads far in excess of the load applied by the torque strut.
Because the subframe doesn't move freely, it is constrained by encapsulated mounts, at least on the models I have worked on. It is vibration isolated, not soft mounted.
Because the standard deflection of the receiver, as determined from reports of some owners who were not able to restore front axle loads without the torque strut, is greater than the amount of associated subframe vertical movement that takes place at the front of the torque strut.
Because it is widely reported to work well.
Because despite the potential for transmitting noise, it doesn't appear to do so.
Because the strongest part of the rear unibody is where the rear subframe is attached. This approach takes advantage of that.
it seems to be a "design flaw" in some people's minds, more than in reality.
Jeff
Old 02-08-2016, 08:07 PM   #40
N/A , N/A
Jeff, please Google "BMW rear subframe failure". It seems several BMW sedans have had rear subframe failures in the years past, and that BMW settled a class action lawsuit with the owners. It seems the rear subframe is not as stout as you may think. Fixing the problem costs thousands of dollars.
To the OP: I suggest you buy a vehicle that can do the job right out of factory. If you want to stay with Mercedes, a 2011-2012 GL350 is a very good vehicle. Same engine and transmission as R, seats 7, and has a good hitch with tow package.
rostam is offline   Reply With Quote
Old 02-08-2016, 09:00 PM   #41
trekerboy's Avatar
1979 31' Excella 500
Charlevoix , Michigan
Wow, this discussion has turned far more technical than I thought it would! Thanks everyone for your input.
We're going to give it a go with the R class and see what happens. This whole thing is a giant experiment anyway; can we actually live out of an AS with 2 kids under 3? Can an R class be modified to reliably tow 31' of shining aluminum awesomeness? If it doesn't work, y'all will be the 1st to know (with pictures, I promise). But if it does work and you see an R class parked next to you at the next place you camp, come say hello.
trekerboy is offline   Reply With Quote
Old 02-08-2016, 09:33 PM   #42
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
You will do well to seek advice from the guy with 29 years and thousands of tow vehicle hitch setups similar to what you are doing. He's a second generation Airstream dealership owner and recognized hitching expert in North America. He has advised us personally and successfully in our last two Airstreams and hitch setups.
You are practically neighbors with Andrew Thompson at Can-Am Airstream in Ontario; that's your best bet to get your R class and Excella set up for best results.
As for your questions about traveling in your Airstream with the small family, the forum has many who are doing this. Post your specific questions and you will get help. We spend six months a year in our Airstream and enjoy it very much as retirees.
Doug and Cheryl
ML320 cdi for 25' Serenity? gary1burke Towing, Tow Vehicles & Hitches 7 01-22-2016 10:08 AM
Mercedes ML320 CDI bringing International Serenity 25FB home switz Tow Vehicles 3 10-24-2012 09:22 PM
Early 2007 Mercedes ML320 CDI Trailer Brake Controller Install Issue switz Tow Vehicles 0 10-17-2012 10:00 AM
Can I Tow with Mercedes E320 CDI diesel car? ss4869 Towing, Tow Vehicles & Hitches 7 04-20-2012 02:31 PM
L@K Airstream Mercedes Diesel Westfalia RV Class B OnaN SL@K Airstream Mercedes Diese eBay Watch Airstreams on eBay 0 03-28-2011 01:00 PM
