Old 10-29-2015, 05:08 PM   #1
2016 26' Flying Cloud
Bastrop , Texas
Question Mercedes GL 450 as a Tow Vehicle
Looking for some advice. After spending a lot of time reading Air Forums think I'm in the right place. The GL 450 has a maximum trailer load is 7,500 lbs and the maximum tongue weight is 600 lb. The AS 26U is 7600 lbs GVWR (although don't see us towing it any way near the max) and a max hitch weight weight of 900 lbs. Have been told the E2 Equalizer hitch will increase tongue weight to 1000 lbs so it should be well within the range.
Has anyone had any experience towing a 26/27 AS with a GL450 and any advice on load and hitch weight would be appreciated.
Tarcoola is offline   Reply With Quote
Old 10-29-2015, 05:53 PM   #2
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
My AS 25 is actually 25'11" so I guess it's ok to call it a 26 ft trailer. I too use the equalizer WD hitch set up & with my truck it's a perfect match. Now to your question, the ball assembly is extremely heavy & along with the bars & brackets it adds close to 100 lbs, do the math and you're correct.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 10-29-2015, 08:28 PM   #3
Bastrop , Texas
Hi Mrjkq, thanks for the response. Wow!! those hitches are heavy. So if I add the hitch weight to the trailer tongue weight I'm over the limit? Is that how it's calculated?
Old 10-29-2015, 09:06 PM   #4
Mrjkq's Avatar
Venice , Florida
Technically yes but proper loading of you AS can overcome that meaning put heavy stuff in the rear of your trailer keeping the front light and that counter balances a heavy tongue. Not the perfect solution but for just a hundred pounds it works.
Personally I feel towing anything over 25 ft with a short wheel based vehicle can be risky depending on the vehicle & hitch set up. A Hensley or ProPride hitch would serve you well & make the tow safe.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
Old 10-31-2015, 05:38 PM   #5
Milwaukee , Wisconsin
Right or wrong, I stopped adding in the weight of WDH hitches because most of their added weight is distributed. I didn't realize how much until I hit the scales multiple times with various loading.
Most typical WDH hitches weigh 70-100lbs.
The Henley and Propride weigh a tick over 200lbs.
Here's how the Hensley breaks down precisely;
Head unit = 99lbs (boxed)
Hitch bar = 71lbs (boxed, and can vary by drop distance)
WDH bars = 54lbs (boxed)
RinconVTR is offline   Reply With Quote
Old 10-31-2015, 06:11 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Excellent tow vehicle according to many.
http://www.airforums.com/forums/f238...50-134454.html
Doug and Cheryl
Old 10-31-2015, 07:35 PM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I tow a 25' with a Dodge Durango which is the same platform as the GL. I'm very happy with it.
2012 Dodge Durango Hemi/AWD
Old 11-01-2015, 07:20 AM   #8
Bastrop , Texas
Great feedback, appreciated. Also the link to the previous GL 450 thread really helped. Missed that during a previous search. My 2011 GL has a 335HP 4.6L V8, not sure how that compares to the 2015 360HP 3.0L V6 in that thread. Pointing me towards Hensley and Propride hitches was great. Sounds like a call Andy at Can-Am would also be a good use of time. I pull trailers and fertilizer spreaders around the ranch with my 2003 Tahoe (200K miles) but a 26U AS on the open road is so much more complicated. Lot to learn before me move ahead with the AS purchase.
Old 11-02-2015, 07:55 AM   #9
sroach's Avatar
2012 23' FB International
Warrington , Pennsylvania
Tarcoola,
I tow a International 23FB with the ML350 (2015) same towing capacities and I don't have issues. I use a reese WD hitch and it works great. I wish there was a better long term mirror solution. I use the strap on mirrors and they get by, but I wish I had pull out mirror like most pickup trucks have.
My trailer is 6000lbs and again no issues at all.
sroach is offline   Reply With Quote
Old 11-02-2015, 08:06 AM   #10
dkottum's Avatar
sroach, we just made a long cross-country trip with Milenco Aero tow mirrors and they are the cat's meow. Steady, excellent visibility and takes about a minute to put them both on or remove them. I was going to put on factory tow mirrors but wouldn't waste the extra money after seeing these work.
Doug and Cheryl
Old 11-02-2015, 08:16 AM   #11
sroach's Avatar
Hmmm.. I will go google those now. Also, I didn't know you could buy factory tow mirrors.
Old 11-02-2015, 08:24 AM   #12
dkottum's Avatar
Should have said we put the Milenco Aero tow mirrors on our Ram 1500 truck rather than the much more expensive factory tow mirrors.
Doug and Cheryl
Old 11-02-2015, 09:29 AM   #13
N/A , N/A
Tarcoola,
sroach,
Per recommendation of a forum member (SafariSS), we use REPUSEL towing mirrors on our GL 350 and are happy with it.
http://www.amazon.com/REPUSEL-univer...towing+mirrors
I also agree that integrated tow mirrors on trucks are much more convenient than strap on mirrors. Unfortunately, that option is not available. The "tow package" for German diesel SUVs lacks a brake controller.
rostam is offline   Reply With Quote
Old 11-02-2015, 11:13 AM   #14
bono's Avatar
Mountain View , California
I would check whether there is any OEM / OE option for towing mirrors for GL in Europe. I am buying towing mirrors for BMW X5, which are not available in the US. These are manufactured by EMUK and you can save some money buying EMUK brand vs. BMW sticker on EMUK product.
bono is offline   Reply With Quote
Towing with Mercedes GL 450 BP1 Towing, Tow Vehicles & Hitches 8 08-07-2014 06:09 PM
Towing a 2004 International CCD 28' with Lexus 450 airstramfilm Tow Vehicles 7 08-12-2010 08:12 PM
