Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 11-04-2009, 11:29 AM   #1
2airishuman's Avatar
Profile:
Originally Posted by finalcutjoe View Post
... (note: I intend to run our ‘track’ with the sensor in the different mules- I think quartile feedback with those numbers will give us a more understandable scale of the acceleration data)
At this point, the numbers don’t lie...[/I]
good idea fc' and u might try the track loop with the sensor INSIDE the stream too.
doesn't need to be done at the same time as the tow vehicle and if done on the SAME loop and conditions...
each tv/trailer combo would be interesting info...
_____________
i agree there are low amplitude high frequency vibes being transmitted into the unit...
from the road via the tires/axles primarily and perhaps SOME via the hitch...
your data suggests NOT VERY MUCH via the hitch/a frame, ON YOUR 30 SLIDE...
i think ONE of the issues is this...
? is it better for a stream to move UP/DOWN somewhat level on all axles while connected (adequate w/d is needed here)...
? or is better for a stream to ROCK/roll like a teeter on soft sloppy w/d with loads shifting on the front/rear axles ??
following behind i've seen firm/flat units move very little UP/down,
while soft/sloppy units have rears that go WAY UP then way down...
where's that picture of plumber's crack?
___________________
Originally Posted by Maryw164 View Post
...What load bars should we be using?...
no offense mary but THIS thread is really about measuring forces and trying to make sense of the data.
it's NOT about how to set up any ONE rig (except maybe fc's rig)
so u might wanna START a thread on your needs and questions, or READ some of the 100s of threads on towing combos...
there are several folks here towing with 1 ton drw trucks who can offer help on tires, w/d bars, hitches and so on...
check out some of those threads in the tow vehicle/hitches section, good stuff is OUT there.
___________________
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Measuring Sofa dannyo General Interior Topics 0 03-28-2008 09:27 AM
market forces... airstream prices... finalcutjoe Trailer Values 4 09-28-2007 08:38 AM
Measuring inverter output guy99 Electrical - Systems, Generators, Batteries & Solar 8 01-04-2007 08:24 PM
measuring propane pressure emanon25 LP Gas, Piping, Tanks & Regulators 2 09-27-2004 06:48 PM
propane, measuring pressure emanon25 LP Gas, Piping, Tanks & Regulators 4 09-20-2004 12:46 PM
