Old 08-20-2017, 01:46 PM   #1
Piggy Bank's Avatar
2017 25' Flying Cloud
2015 22' FB Sport
Kansas City , Missouri
McKesh Mirror strap noise-Fixes?
Hi,
We recently upgraded to a 25 RBT Flying Cloud from a 22 Sport. With the Sport the clip on plastic tow mirrors were OK. They were not wide enough for full rear visibility with the 25 since it's wider. We purchased some McKesh mirrors and spot mirrors from the Hensley website.
We like the McKesh mirrors very much. The visibility is just what we were looking for, especially with the spot mirrors. Only issue is some strap vibration noise, especially from the passenger door mirror strap. (Note the passenger door strap winds further away from the door surface due to the way the turnkey/click lock fits in at the top of the mirrors for adjustability).
What EXACTLY have users done to help with this noise? I have read some comments on a search about affixing foam, cable ties, etc, but I am not completely sure on what exactly to do. We have a rather long trip in a few weeks and I would like to resolve this before if possible.
Please help, and pictures all the better.
(If it matters, TV is a Tundra)
Thanks.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 08-20-2017, 02:10 PM   #2
Ayr , Ontario
I have the same issue with Canoe straps. To avoid the noise I just twist the straps and then tighten them. When they are round verses flat they don't vibrate.
gator.bigfoot is offline   Reply With Quote
Old 08-20-2017, 03:17 PM   #3
Frederica , Delaware
Get the Tundra tow mirrors cheapest place might be e bay. Easy enough to install. Just make sure new mirrors have at least the same options as the originals. Power, heated, lights these sorts of options
Overloaded is offline   Reply With Quote
Old 08-20-2017, 03:25 PM   #4
Mollysdad's Avatar
+1 on twist.
Boaters learned long ago that the bimini straps vibrate in the wind, so they put a twist in them to defeat the vibration.
Old 08-20-2017, 03:57 PM   #5
2002 19' Bambi
Lafayette , California
Having long used McKesh mirrors, we have pads of closed cell foam glued to magnetic sign material. The magnetic side is towards the vehicle door and the padding is against the mirror strap. The magnetic material holds the pads in place while tightening the straps and makes removable easy. The pads need to be thick enough to push against the straps.
We came to this solution after the vibrating and humming straps damaged door paint years ago.
Tim
Tim A. is offline   Reply With Quote
Old 08-20-2017, 05:43 PM   #6
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
A wad of upholstery foam jammed between the strap and the door will quiet most of it. Mine stayed in with friction alone, but I was jamming 2" foam into approximately 1" of space.
Old 08-20-2017, 06:02 PM   #7
Byron Center , Michigan
I've used the twisting trick, too. Another trick is to tape a piece of pipe insulation (the slitted type you put around copper pipe) around the strap. It defeats the airflow that causes the oscillation. "Pool noodles" work well for big straps in a pick-up bed. The oldest uses that trick with his motorcycles when they're strapped into a bed or on a trailer. Cheap and easy; easily replaced if needed.
YippieKiYa is offline   Reply With Quote
Old 08-20-2017, 07:05 PM   #8
Piggy Bank's Avatar
2015 22' FB Sport
We already purchased the McKesh and will be using them. We looked at the Tundra mirrors but they were both expensive and secondly wider than I wanted to manage for something permanent that would be present every day.
Wish that the Tundra mirrors weren't so spendy and weren't so big. Right now I don't have to fold my mirrors to park in my garage. With the Tundra tow mirrors I would have to do that.
Piggy Bank
Old 08-20-2017, 07:10 PM   #9
Piggy Bank's Avatar
2015 22' FB Sport
Tim
Tim,
Did you have paint damage on passenger side door or both? I ask because it appears that we are only having excess vibration on the passenger door.
Wondering if I need to address both doors.
Piggy Bank
Old 08-20-2017, 07:11 PM   #10
Piggy Bank's Avatar
2015 22' FB Sport
Thanks for letting me know how much foam to use.
Piggy Bank
Old 08-20-2017, 07:12 PM   #11
Piggy Bank's Avatar
2015 22' FB Sport
Thanks I can probably grab some pipe insulation at work.
Piggy Bank
Old 08-20-2017, 07:15 PM   #12
Piggy Bank's Avatar
2015 22' FB Sport
Gator and Molly's Dad,
We tried the twist last weekend and it helped a whole lot, but didn't totally eliminate the problem.
I think that I will have to do more.
Piggy Bank
Old 08-20-2017, 08:37 PM   #13
2002 19' Bambi
Originally Posted by Piggy Bank View Post
Tim,
In our case, it was both doors. We have used various models of Jeep Grand Cherokee to tow our 2002 19' and the paint damage was only on the first. All of them have had places on the doors where the strap is not directly against the door metal and that is where the vibration occurs without the padding. Our foam pads are 1" thick at the thickest, but are closed cell foam and don't compress much.
I think I should add that we love our McKesh mirrors.
Tim
Old 08-21-2017, 01:46 PM   #14
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Twisting works!
MelGoddard is offline   Reply With Quote
Mirror / Mirror what type of Mirror? Jeep GC dlkershaw Towing, Tow Vehicles & Hitches 9 12-10-2015 04:14 PM
McKesh Trailer Mirrors tahurt2 Airstream Classifieds 0 02-12-2014 01:53 PM
Mirror, mirror off the wall! Pudentane General Repair Forum 2 08-09-2009 08:28 PM
Mirror Mirror on the wall early General Interior Topics 2 11-20-2005 10:13 PM
Mirror Mirror on the wall.... GT1963 The Pet Forum 9 03-15-2004 09:42 AM
