Old 01-22-2014, 09:37 AM   #1
Tallahassee , Florida
M-b gl450
We have a 2013 M-B GL450 and decided on a 19' Airstream. When the vehicle was purchased we had the M-B dealer install the M-B hitch. We know we will need to have a brake controller installed. We don't know enough to know which one will give us most satisfactory service.
AND, our tow vehicle has as standard equipment M-B's proprietary Electronic Stability Program which includes "Trailer Stability Assistance". The vehicle also has the standard equipment "Airmatic Suspension" which equalizes front/rear
ride heights, compensating for increased cargo or load. Do we need a weight distributing or equalizing hitch or whatever I should be naming it?
phm31750 is offline   Reply With Quote
Old 01-22-2014, 10:27 AM   #2
1974 Argosy 20
Kooskia , Idaho
Yes, you need a weight distributing hitch, even with the air suspension. The system you have is the same, or very similar to the one I have on my Jeep Grand Cherokee. It will keep the vehicle level, but will not move some of the hitch weight of the trailer to the front steer axle, which is necessary. Most WD hitches also have some kind of sway control built in to reduce or eliminate sway from the get go. The electronic sway control you have is also on my GC, but it works only after the fact and is not a substitute for a good system in the hitch to begin with. The electronic system is a good addition, but not a substitute for hitch sway control.
Your 19' is a small and stable trailer to begin with, but still needs a good WD hitch.
Old 01-22-2014, 01:36 PM   #3
Wayward's Avatar
Cary , North Carolina
I am not sure there is a whole lot of difference in brake controllers so long as you go with a brand name like Prodigy or Tekonsha. You will probably want a MB harness adapter that mates to the unit. Some adapters are ready to plug in the vehicle, others are just pigtails. Your mechanic will figure that out.
They are pretty much setup and forget, but you want to be able to glance over and check the setting or test the manual override now and then. They are about the size of a radar detector. Give some thought as to where you want it mounted. e.g convenient access to adjust or override , but not obtrusive.
They are not exactly pretty and Mercedes certainly thinks through every square inch of their cockpit with design and function, so you may want a controller that is easy to remove/replace when not towing.
With 500lbs tongue weight, a short overhang and air suspension, I'd just hook it up and take a careful test drive before choosing a weight distribution and/or anti-sway - but most folks here would give the same advice on a weight distribution system as IDROBA did.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 01-22-2014, 02:01 PM   #4
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
I towed my old 23FB with a MB GL 450. Had/have a Reese Dual Cam WDH with a Reese Sway bar. I towed the 23, 40 miles to the dealer without the sway bar hooked up. Never did that again; a gust of wind and you've got issue to contend with.
Like the others say, a WD hitch makes good sense. Also that Sway Bar.
There's a Service Bulletin T-B-31.19/07d. Your mechanic can put that to good use.
Here's a MB forum thread that's also relevant;
trailer brake controller - Mercedes-Benz Forum
Good luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 01-22-2014, 02:07 PM   #5
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The easiest to set up is the Tekonsha RfF Prodigy with no direct connection to car wiring harness. The seven pin trailer plug goes into the MB socket but interrupts the brake wires in the black box that mounted on the trailer frame. Hand held device size of a pack of cigarettes plugs into car power in ash tray and sends radio control signals to black box. Worked well with our ML320 diesel and the 25FB international serenity
Used a Hensley hitch with 1,000 pound bars.
Old 01-22-2014, 02:18 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Towed for years with an ML500 and a 20' Safari using Reese DualCam and a Prodigy. No complaints.
I've replaced the ML with a Dodge Durango (same platform at the GL, minus Airmatic). Again, no complaints.
Wayne&Sam is online now   Reply With Quote
Old 01-22-2014, 05:06 PM   #7
N/A , N/A
http://www.benzworld.org/forums/x-16...tallation.html
Here is how I had the controller installed. No interference with knee airbag, No need to drill the dash, and the controller can be removed when not used.
rostam is offline   Reply With Quote
Old 01-23-2014, 04:58 AM   #8
jmcarter's Avatar
2010 28' International
Richmond Hill , Georgia
Towing our International Serenity 28ft with a 2013 GL350, went with the ProPride simply to move more weight forward and get my axle weights well within limits. Don't think you need the expense and heft of PP but a simple WD/sway control hitch is prudent. For controller I bought a Prodigy RF, mounted the box to the frame, paired it to the MB and was done. Recommend the RF route.
jmcarter is offline   Reply With Quote
Old 01-25-2014, 01:39 PM   #9
kellykellyi's Avatar
1952 15' Cruisette
1967 20' Globetrotter
2010 19' International
La Caņada Flintridge , California
I just bought a 25FB and love hearing that someone is towing an AS with similar specs with a MB GL350. I am considering a GL450 as my new tow vehicle. Any modifications made to your TV?
kellykellyi is offline   Reply With Quote
Old 01-25-2014, 02:26 PM   #10
StokerDoc's Avatar
2013 28' International
Victoria , British Columbia
RF brake controller
We were informed that our 2014 GL 350 BlueTec has a production date of Feb 26. Hoping for a mid-late Mar delivery. I have been on the fence about brake controllers as I am not interested in cutting or screwing into the dash. The RF system seems like the way to go.
A couple of questions for you, is there a specific position the controller in the vehicle needs to be? Can it sit in any orientation? Have you had issues while driving where it became unpaired with the trailer?
I am very excited about the new TV. Don't get me wrong, our current Tundra is a nice truck as trucks go. We are planning ahead for when we are both retired and will drop to one vehicle that hopefully will do everything for us from groceries, to the odd run to the compost yard, to ferrying a bunch of kids on a field trip for school, to towing our 28ft Serenity, all in comfort with better manoeuvrability and hopefully with a bit better fuel economy.
StokerDoc is offline   Reply With Quote
Old 01-25-2014, 02:47 PM   #11
N/A , N/A
The only (minor) issue with RF controllers is when you want to tow another trailer -- You need to un-install the module from your trailer's A-frame and install it on the new trailer. RF break controllers are great for when you have a single trailer and multiple tow vehicles -- All TVs can all operate with a single controller.
I put a link above on how I installed a break controller without drilling the dash. Here is a photo.
Old 01-25-2014, 02:52 PM   #12
N/A , N/A
oops! forgot the photo.
Old 01-25-2014, 04:30 PM   #13
Branson , Missouri
Towing, using the MB GL, regardless of engine, needs to be thoroughly thought out, IMO.
I had two GLs, one a diesel, and the other a 450. The GL is designed to handle a hitch weight of 750 lbs. The specs. on the towing rating can be easily Googled.
However, in my opinion, the most significant thing that's constantly overlooked is the toll the longer/heavier Airstreams take on the vehicle's transmission.
That's a reality that I experienced.
2013 Suburban 2500
2011 23 FC FB
Old 01-25-2014, 04:53 PM   #14
jmcarter's Avatar
Our Prodigy RF has come unpaired once. I knew it immediately because the controller display immediately started flashing " n c " (not connected) and I pulled over and repaired it (you still have trailer brakes even if the controller is showing not connected). The hand controller sits anywhere in the console area (frequently it sits in my lap during bad traffic or going down steep grades. The cord just plugs into a 12V outlet and I've included a pic. I'm particularly partial to the diesel 350 because of the great mileage, range and the monster torque is so low in the RPM range that you're always in the sweet spot and downshifts only occur on the steepest grades. You can buy a connector that overcomes the MB not recognizing LED trailer lights which is common with the German SUV's. Be glad to answer any questions on the TV or our setup.
Hadn't heard of any trans issues on the newer MB's beyond software but I got a great deal on an extended warranty and since I'm well within the rated specs I didn't hesitate. 2013 was the first year of the newest X166 GL's so the warranty was more a peace of mind thing.
