Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 05-30-2006, 06:00 PM   #1
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Lubricating the hitch jack?
Have any of you done "maintenance" on your H & H electric tongue/hitch jack?
I found the directions and think I can get the cover off. I understand that I am to use Lithium based gear grease.
Is it simple? Simple is best for me.
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is online now   Reply With Quote
Old 05-30-2006, 06:06 PM   #2
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
If it's like ours, you just unscrew the 6 machine screws that hold on the cover, and add a daub of grease. Put the cover back on, and you're finished.
You repair things with tools. You fix things with a hammer.
AIR#2611
overlander63 is online now   Reply With Quote
Old 05-30-2006, 06:11 PM   #3
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Kistler,
If it's the newer style that A/S is using, like the one on my CCD, there are onlu 2-5/16" hex heads, one on either side of the plastic cover holding it on. Remove and lift the cover and the gears are right there. That's it!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 05-30-2006, 06:26 PM   #4
Kistler's Avatar
Thank you, fellows.
Kistler
Old 05-30-2006, 07:15 PM   #5
Huh?
Ultradog's Avatar
Profile:  1975 27' Overlander
Minneapolis , Minnesota
Images: 8
Never taken my jack apart yet but...
I have fiddled around with two similar jack/screw items before.
One was the jacks on my old slide in pickup camper and the other was the leveling adjuster on the three point hitch on my tractor.
Bear with me...
I learned about them from having both of them fail.
All of these jacks use a crank (or motor and gears) to turn a threaded rod which is mated to a special nut which does the acutal raising and lowering. On both of the items I mentioned it was not the gears that failed but the nut on the threaded rod.
Lack of grease on the rod caused the threads to wear out out in the nut.
It failed. On one occasion dropping one corner of my camper and on the other causing my plow to drop. Both could have been disasters.
If and when I get around to greasing my Airstream Jack you can be assured I will do more than pop some little cover off and add grease to the gears.
I will also take it apart far enough to allow me to grease the threaded rod and nut. Because that nut is the Holy Grail of the jack
Ultradog is offline   Reply With Quote
Pingbacks are On
voltage for electric jack maznblu Towing, Tow Vehicles & Hitches 3 04-16-2004 08:32 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Hitch problem wyhjr Hitches 8 07-22-2002 05:29 PM
Hitch inspections 83Excella Hitches 3 07-09-2002 03:05 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
