Old 06-12-2014, 07:49 PM   #1
Totoro's Avatar
Huntington , West Virginia
Lower center of gravity
I only start this thread because we recently changed our towing setup, and even my wife commented on the fact that we couldn't feel the semi's on the sides anymore. I can't help but wonder if it is the low profile axles (original equipment), and TV (jeep commander) which doesn't sit that high either.
On a side note, I also use bias ply tires. Sounds crazy, but I have towed with radials, and the bias ply have always seemed to track better IMO.
Totoro is offline   Reply With Quote
Old 06-12-2014, 08:39 PM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I tend to agree with the bias tires on trailers. The sidewalls are more firm, the tires don't lay down so much with lateral loading.
Old 06-13-2014, 08:13 PM   #3
Ottawa , ON
Hi there. So, what exactly did you change?
Old 06-13-2014, 09:04 PM   #4
Totoro's Avatar
New low profile axles and switched from a Dodge Ram to a Jeep Commander. TV and trailer are lower.
Old 06-13-2014, 09:14 PM   #5
r carl's Avatar
Lin , Ne
And they wont tear up your wheel wells. Don't under estimate bias ply st tires.
Old 06-14-2014, 04:48 AM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Bias ply tires lack the steel belt that acts as a shredder in a failure. There is just the tread carcass attached with a ribbon of nylon.
A blowout cannot be as disastrous to the wheelwell or skins. I think I'm going with bias ply 15" next season on my 34' classic. Coker tire is just one place with a wide variety.
Old 06-14-2014, 05:16 AM   #7
Road Ruler's Avatar
Images: 38
Radials VS Bias
I believe these have been talked about and compared before. There "right" radial is going to be your better performing tire.
Also agree. Lower COG with TV and trailer is also going to handle better.
Old 06-14-2014, 05:51 AM   #8
CapriRacer
CapriRacer's Avatar
I'm in the , US
I hope Atomic will not think I am picking on him just because I chose his quote to reply to. There's a lot of mis-understanding being expressed in this thread and his is just the last one.
First, the difference between a bias tire (sometimes called a cross ply or a diagonal) and a radial tire is the direction of the ply cords. In radial tires, the cords are at basically a 90° angle to the circumference of the tire (the "radial" direction), while bias tires are at a substantial angle - 30° to 40°. This makes the casing of a radial tire much more flexible as the plies do not fight each other when the tire is distorted - all other things being equal. (however, things aren't equal and I will explain that in a moment.)
Some tires have belts - a layer of cord (typically 2 steel wire layers) in the tread area - that stiffens this area and improves the wear and traction of the tire. However, that comes at the sacrifice of ride quality.
When a belt is added to a bias ply tire, it becomes a bias-belted tire. Because radial tires don't work without a belt, not only will you not find non-belted radial tires, but it is common just to call them "Radials" - and assume they are also belted.
Tire stiffness? Inflation pressure has much more affect on tire stiffness that does the tire itself. So a person may be able to sense the difference in stiffness in an uninflated tire, but that difference is overwhelmed by affect inflation pressure has.
Besides, in a radial (belted) tire, you can stiffen a particular part of the sidewall so much, while leaving another part quite flexible, that the overall stiffness is greatly increased, but it seems more flexible when picked up because if that very flexible portion. You can do the same thing to a bias or bias belted tire, but in practice bias and bias belted tires aren't stiffened in this way.
So be careful. Tire stiffness is complex and there is overlap.
Blowout? First, the term is used for 2 quite different failure modes.
1) A rapid release of inflation pressure. This is usually caused by encountering an object such that the casing is damaged (by cutting, tearing, or breaking cords) This escaping air can cause a lot of damage, and there have been fatalities just from exploding tires.
This is the correct use of the term - although people analyzing tire failures never use it. They generally use a description that points to the cause.
2) Incorrectly, the term is also used to describe a "belt separation", where the belt and the tread rubber over the belt, separate as a unit from the rest of the casing. There are several kinds, but the most common is a "belt-leaving-belt separation". In the separation sequence, the normal hoop-like configuration of the belt is split between belt wires and a flap is created by the centrifugal forces. This flap can damage anything near the failing tire.
Normally, the rest of the casing is undamaged and would still be inflated, but because the casing would be exposed to road debris, it is not usual for the casing to be damaged in the failure sequence. This makes distinguishing between this kind of failure and #1 above much more difficult.
Since bias tires do not have belts, they can not have this kind of failure. However, they do have an analogous failure where the tread comes off, but usually, this is in smaller chunks and the damage is more isolated and less severe.
CapriRacer is offline   Reply With Quote
Old 06-14-2014, 06:00 AM   #9
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Thanks for picking on me. That is good info. I like bias ply on a trailer any way, bias ply do a better job at just going in a straight line. This is what I want my tires to do, just go straight then explode with less damage....
Old 06-14-2014, 06:46 AM   #10
Totoro's Avatar
Bias vs radial is a hot topic on the forums. Way to many "look what happened to my trailer" posts for me to switch back to radials.
Old Carlson gravity heater floor Zion Zev Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-13-2014 02:54 AM
Replacement gravity fill cover usuallyalex Fresh Water Systems 3 05-28-2013 11:11 PM
Convert water gravity tank to outside pressure robwok General Interior Topics 15 02-11-2011 12:00 PM
gravity fed from a ram pump cnsilver Fresh Water Systems 5 09-11-2008 06:27 PM
Measuring specific gravity of battery electrolyte guy99 Batteries, Univolts, Converters & Inverters 6 01-20-2008 07:31 AM
