Old 10-17-2019, 08:05 AM   #1
ENFIELD , NS
looking for some advice on front weight
I have a 1973 overlander
i wanted to place a truck box and 2 d8 batteries 100lbs each as well as 2 50lb propane tanks
i would basically be adding around 250lbs extra to the very front of the trailer.
I wanted to keep these batteries outside the trailer.
what do we think?
joeybravo is offline   Reply With Quote
Old 10-17-2019, 08:32 AM   #2
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
It is possible that the extra weight at the rear of your tow vehicle could cause it to oversteer a little. No problem if the tow vehicle is large enough, or if you drive a little slower.
out of sight is offline   Reply With Quote
Old 10-17-2019, 08:32 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
My opinion: I would not do this.
The trailer frame on a '73, IMO, is too light for that much additional weight.
A truck box, if too large, might contact the tow vehicle during a sharp turn.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 10-17-2019, 09:52 AM   #4
ENFIELD , NS
No worries of turning into it wrong or anything, i think it will be ok, if i go to move it i will take the tanks off and reduce the weight by 100lbs. Just curious if anyone has done this or made a modification like that. A.s. Will be stationary more of the time so.
Old 10-17-2019, 10:03 AM   #5
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
I would inspect your A frame connection to the rest of the frame first, as recently an owner of a similar generation trailer had his A frame break off while on the road.
Another 250 lbs is a lot of weight IMHO without adding extra structural gussets to reinforce frame first.
http://www.airforums.com/forums/f464...ame-86302.html
Cheers
Sidekick Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 10-17-2019, 11:51 AM   #6
ENFIELD , NS
Originally Posted by isuzusweet View Post
i would inspect your a frame connection to the rest of the frame first, as recently an owner of a similar generation trailer had his a frame break off while on the road.
Another 250 lbs is a lot of weight imho without adding extra structural gussets to reinforce frame first.
cheers
sidekick tony
ok, so thank you for this reply, i will not be doing this based on what ive read.
Can you suggest a place to put these big batteries?
Over wheel well obvious?
Old 10-17-2019, 04:47 PM   #7
Dazed and Confused
Isuzusweet's Avatar
The only suggestion I have is to build your battery box on the front of the frame, along with the truck box; but since your trailer will be stationary most of the time, travel with the batteries, and contents of truck box inside the TV while on the move.
Your A frame should handle the propane, but I'd still inspect it.
Cheers
Sidekick Tony
Need some light weight advice Hanginokie Off Topic Forum 4 02-17-2013 04:05 PM
Looking for some veteran advice... Rosy68 Buyer Guidelines 5 03-28-2011 11:01 AM
Pro Series 600 lb tongue Weight?? Looking for some help Airstreamdmb Hitches, Couplers & Balls 5 10-24-2010 05:50 AM
Newbie looking for some advice on waste tanks and plumbimg in general. Sairaf Plumbing - Systems & Fixtures 2 07-30-2010 05:49 AM
Looking at an AS--Need some advice pls! JenandGC Member Introductions 5 09-23-2006 07:18 PM
