04-06-2013, 07:01 PM
Mill Valley
Looking for a Tow Vehicle for a 19' International Bambi
I just purchased my first Airstream and I'm currently looking for a tow vehicle. I'm leaning towards the the Jeep Grand Cherokee. If anyone has experience with this (2012 or later model) I'd be interested in hearing your insights. Many thanks!
04-06-2013, 08:15 PM
2017 25' International
Los Osos
Make sure that the tow vehicle's Gross Vehicle Weight Rating(lbs.) is at least 4500 lbs. You'd be best to pad that a bit, maybe go to 5500.
Make sure it has a substantial transmission cooler. Also a Class 3 hitch with a 2 5/16" ball. I'm using a Prodigy 2 brake controller.
04-06-2013, 08:22 PM
1966 24' Tradewind
1995 34' Excella
Lynchburg
Congrats on your new Airstream
I think that the 2012 Grand Cherokee would make a great tow vehicle. Make sure that it is equipped with the tow package. I would also look at the Dodge Durango. It is a similar vehicle, but has a longer wheelbase. This would make it more stable for towing.
Good Luck, Dan
04-06-2013, 09:08 PM
2002 19' Bambi
Lafayette
The present Jeep Grand Cherokee is a terrific tow vehicle. We have a 2011 (essentially the same as the 2012) with the 5.7l V8 and use it to tow our 2002 19' Bambi, which is much like, in terms of weight and towing, the trailer you just bought.
This is the third model of Grand Cherokee we have used to tow our trainer, all using a Hensley hitch. Our two former models had shorter wheelbases than the 2011 - 2013 models and, perhaps thanks to the Hensley, we have never noticed any effect of the nominally short wheelbases.
The present Grand Cherokee, at least when equipped with the towing package, has integrated anti-sway. The air suspension is a nice thing to have for towing. It is not, however, a substitute for weight distribution.
Tim
04-06-2013, 09:24 PM
1974 Argosy 20
Kooskia
, Idaho
I also have a 2012 Grand Cherokee with the V8 and all the bells and whistles. It is a great tow vehicle for my Caravel or Argosy. The Argosy is 4200# with a 720# hitch weight. Tows exceptionally well with the Jeep. The Pentastar V6 is also a very very good engine, and I believe would to your 19' AS just fine, and give you a little better solo milage. Towing milage does not seem to vary much with the 6 or 8, both about 12.5 to 14 mpg. This is my 5th Grand Cherokee, and I have had 6's and 8's. The 2012 that I have is the best of all of them.
Just be sure to get the tow package.
04-06-2013, 09:30 PM
1968 17' Caravel
Battle Ground
idroba, what kind of hitch do you use with your cherokee?
Stephanie
04-06-2013, 09:38 PM
1974 Argosy 20
Kooskia
, Idaho
I have the Andersen hitch, and like it very very much. Unfortunately now Andersen says that the Atwood coupler I just had replaced on the Argosy is not recommended to use with the Andersen.
The Grand Cherokee hitch box is quite high, and I had to have the Andersen drop shank to make my rig level out properly. And that is with new axles on the Argosy and 16' wheels and tires.
My GC has the full air suspension system, which I like too. You do have to know how to turn it off to do the initial setup of any WD hitch system. And the Air Suspension sometimes seems to have a mind of it's own leveling for "cosmetic" reasons. Kind of fun actually.
04-07-2013, 02:00 AM
1978 31' Excella 500
Genoa
, Nevada
Sway Control
Be sure they put on a sway control device. We almost lost one our cherished members on her maiden voyage with her brand new Bambi and Cherokee, the dealer didn't put on a sway bar. She did darn good to regain control.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
04-07-2013, 12:04 PM
2002 19' Bambi
Lafayette
Was it a Cherokee or Grand Cherokee and what year? By "sway bar," do you mean sway control in its many forms as offered with any number of hitches?
Of course sway control is important and, as a followup to what I posted above, the following is included in the description of the towing package on the Grand Cherokee on the Jeep website:
"The Trailer Tow Group includes ... Trailer Sway Control (TSC)." "Trailer Sway Damping senses trailer sway and takes action by automatically applying the right amount of braking to maintain control."
Tim
04-07-2013, 12:25 PM
1974 Argosy 20
Kooskia
, Idaho
I have that Trailer Sway Control on my Grand Cherokee. It has never activated as far as I know, but then I have never had any sway control issues with my Reese, my Draw Tight, or my Andersen hitches.
But the Jeep System can only act on the Jeep, not the trailer. Although I am sure it may help things, it is not the final solution to sway issues.
From all my reading here, in many threads, it seems that trailer sway can be a result of many things, or combination of things and there is no one solution. The reports on the Hensley and Pro Pride do seem to indicate that they do truly eliminate sway, I have not had one and have never felt the need for one, but those who have them like them very much.
We do not want to turn this thread into one on sway control, that is for another thread, but right now I am unsure of the value of electronic vehicle sway control on the tow vehicle only. Time will tell I guess.
04-07-2013, 10:58 PM
Genoa
, Nevada
Whatever. To me it's the bars that attach to the side of the hitch that have friction to keep the trailer from swaying and skitching and developing into jackknifing the trailer in front of the tow vehicle and rolling the whole lot. Something a new owner might not know about to know the need to get it, no matter what model Truck or Suv she has. It catches experienced drivers, maybe as much as newbies. My 31' went to swaying on I-80 once, with sway bars, on a grooved pavement stretch.
I pm'd Bambi Lass to pm Bam and discus it all direct girl to girl.
NevadaGeo
04-09-2013, 08:27 AM
Puyallup
We have a FC19, did not want a 4 door SUV so we got a short bed crew cab pickup. Having the cab separated from the cargo area makes it quieter and the stuff in the back is under cover with a bakflip
04-21-2013, 01:13 PM
Los Osos
I you haven't already purchased a truck....I'd highly recommend the 2013 Dodge RAM 1500 5.7L Hemi Crew Cab Outdoorsman. We did the first tow with ours and love it. It's plenty of truck for our Bambi 19. It will tow 8800 pounds.....nice cushion.
It has a built-in brake controller and trailer sway control. Also uses coil springs instead of the leaf springs found on may other pickups. So...Bambi experiences a less harsh ride. Ours came with 20 inch wheels.....not sure if that is an advantage towing.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
04-21-2013, 02:27 PM
1991 29' Excella
Akron
Welcome!
Bambi Lass, welcome to the forum!
I'm just new to RV'ing and I'm reading...reading...reading! I too own a Jeep and am very interested in the new 2013 diesel Jeep GC. I'm waiting to hear about it when it comes out and some new users start to do things with it.
Here are a couple of threads that I have found interesting and very helpful:
http://www.airforums.com/forums/f463...el-103068.html
http://www.airforums.com/forums/f464...ide-57179.html
Enjoy!
Nancy and Paul..........TAC OH 34
Five Airedales and One Chocolate Lab
(no they don't all get to go in the AS at once!)
1991 Excella 29 foot w/ProPride 3P hitch
2006 Jeep Commander-V8 4.7L Tow package
04-21-2013, 03:06 PM
'06 75th Winick Prototype
2006 19' International CCD
1968 22' Safari
The Swamps of Hell
, Lousy-Anna
04-25-2013, 10:28 AM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
, *** Big Sky Country ***Western Montana
Our analysis as well when we had our FC20 ... keeps the smelly stuff out of the passenger compartment ...
04-25-2013, 02:08 PM
2016 30' Classic
Hinckley
I have a 2012 JGC 6 and it pulls my 2011 20' Safari well. It also get good gas milage. The diesel is very expensive and not worth the extra costs. Check out Car And Driver on line forums.
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
