Old 01-01-2019, 12:33 PM   #1
Providence , Rhode Island
Lining it up without a trailer caster
As a TT noob, I'm not new to towing....towed things like motorcycles, car trailers, boats etc... ALL of the things I've towed, the trailer always had a drop down caster wheel to "position" the trailer "over" the ball, drop....and off we went.
So I was thinking about the logistics and it dawned on me that the AS doesn't have this. My TV (2016 Yukon XL) has a backup camera I "think" that will make the job easy enough, does anyone ever "add" a caster wheel to help move it into position on a LEVEL surface? Does it make any sense to do such a thing for being able to simply drop the AS on the hitch instead of playing the back and forth left/right game with the TV?
Seems like that would be an "easier" option, but not exactly sure if it makes sense to add or not?
Search engine isn't as helpful as I'd thought, or I'm just looking or asking it the wrong thing...
Thoughts?
Chris
kittmaster is offline   Reply With Quote
Old 01-01-2019, 12:41 PM   #2
2007 27' International CCD FB
San Diego , California
Hi Chris.
The problem with a caster on the tongue jack is that you will have no effective brakes on the trailer. With anything other than completely level, that would be a huge liability.
Also consider that these larger trailers are upwards of 4k-9k lbs, with ~1k tongue weights. Casually pushing around the tongue to line things up is not going to happen.
Best practice is to play the TV back and forth game. Don't worry, you'll get very good in time, especially with a camera. Even better with a spotter.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
pteck is offline   Reply With Quote
Old 01-01-2019, 12:56 PM   #3
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
While a bak-up camera is great, the best option is a trusted copilot you can guide you back until the ball and hitch are aligned.
Just make sure you agree in advance as to the hand signals. 👈🏻 👉🏻 ✋🏻 🙌🏻 🙏🏻
az-streamer is offline   Reply With Quote
Old 01-01-2019, 12:57 PM   #4
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Camera should help. We don't currently have a camera so can't say for sure.
Not all spotters are the same - a spouse/significant other may do a good job as a spotter but you'll need to agree on hand signals so you can understand each other.
My method is to do it by myself - I back up, stop short, get out check the distance and whether I'm centered, back up a bit more, steer if needed, get out and check again, repeat as needed. I very seldom have to pull forward and start over.
As pteck mentioned, the wheel/caster on the jack is not a good idea.
Lucius and Danielle
1992 29' Excella Classic
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 01-01-2019, 01:10 PM   #5
Long Island , New York
^^^^^ x2
Well said, Lucius.
Once you have done it a few times, it gets easier, like riding a bike.
Very easy to over-think this . . .
Old 01-01-2019, 01:40 PM   #6
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I made an anti divorce device for hitching.
It’s a blind spot mirror on the tongue jack and I view it from truck rear view. Allows pretty good view when I’m about 4’ out and closer. Added yellow reflective tape on hitch components to help guide.
Still married.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 01-01-2019, 01:50 PM   #7
Images: 59
Originally Posted by nvestysly View Post
... My method is to do it by myself - I back up, stop short, get out check the distance and whether I'm centered, back up a bit more, steer if needed, get out and check again, repeat as needed. I very seldom have to pull forward and start over.
It's very easy to do it by yourself without cameras or help.
First, control your breathing and say your personal mantra.
Next, get a clear visual image of the hitch and coupler. Continue your slow breathing. Slowly place your vehicle in gear and loosely grip the steering wheel.
Repeat your mantra. Close your eyes. In your mind, reach out and touch the coupler. Be the coupler.
Slowly release the brakes. Visualize the hitch ball approaching the coupler.
You will know when the ball is perfectly positioned under the coupler. Set the brake and exit the vehicle.
Be sure to properly latch the coupler before driving forward.
Old 01-01-2019, 01:56 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I had a B/U camera on the Burb but the Hitch'n Rods work better for me...locates both the AS & the reciever.
Plus O' rings will help with the height 👍
ID:	330774   Click image for larger version
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 01-01-2019, 03:14 PM   #9
2018 28' International
Fayetteville , Georgia
You cannot move the tongue of an Airsyream around by hand. With the backup camera, you will be right on target. Simple.
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 01-01-2019, 03:52 PM   #10
Kevin245's Avatar
Zen and the art of trailer coupling!
We have a backup camera because I am not “One with the ball and coupler”. 🤣
Eleanor Roosevelt
Old 01-01-2019, 04:41 PM   #11
Seems pretty clear and a consensus, thanks to all for the feedback. Wife and I will work out the signaling and there will be plenty of practice....LOL.
Happy new year to all.
Chris
Old 01-01-2019, 04:49 PM   #12
CRH
1995 25' Excella
xxxxx , xxxxxx
I use the tennis ball on radio antenna looking things to hookup solo with no problems. Haven't dinged up a bumper, yet.
CRH is offline   Reply With Quote
Old 01-01-2019, 05:03 PM   #13
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Before back-up cameras I used the 2 magnetic poles to help with alignment. They worked pretty well but after doing it a few times I got pretty good of centering myself just using my side view mirrors. Now I just mean "pretty good". Most of the time It took me a few shots to get it right but I preferred doing it myself to a human guide. Haven't used the poles for many years. Now I have a back-up camera and that really takes the guesswork out of it. It's no FUN anymore took all the challenge out of it.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-01-2019, 06:26 PM   #14
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Chris!
I have towed my travel trailers solo since 1980, and found that I prefer to do the hitching solo. Over the years, I have had several magnetic, convex mirrors that attach to the "A-Frame" hitch and provide a view of the coupler and the trailer hitch that make it possible to line up the two with minimal trouble. The hitching mirror that I now utilize is quite similar to this one offered by Camping World.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
jack caster wheel on '54 wanderer lunartic Jacks, Stabilizers, Lifting and Leveling 3 08-06-2018 01:41 PM
Replacing Foot of Hitch With a Caster Vitaver Jacks, Stabilizers, Lifting and Leveling 6 02-09-2017 04:50 AM
jack wheel caster 2 inches (in Uk or Europe) Gaël Jacks, Stabilizers, Lifting and Leveling 4 08-08-2014 05:24 AM
