Old 07-08-2016, 03:24 PM   #1
Grand Rapids , Michigan
Life expectancy of my Siverado TV?
So how long can I expect my Silverado to last?
2012 "Texas" towing package. 5.8L 3.42 rear. Tranny cooler. 6-sp trans.
Towing ~3000# carrying ~800# inc passengers. About 60% 0f miles towing.
Meticulously maintained according to factory recommendations.
Currently at 80,000 miles. How many can I expect before replacing it?
John
crampshaw is offline   Reply With Quote
Old 07-08-2016, 03:39 PM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
5.8?
Are you sure it isn't 5.3?
We have many GM pickups and vans in the fleet with 4.3 V6 gas, 4.8 V8 gas, 5.0 V8 gas, 5.3 V8 gas, 5.7 V8 gas, 6.0 V8 gas, 6.2 V8 gas, and 6.6 V8 diesel with way over 80,000 miles, the highest mileage being 553,000 miles.
The gassers all have either the 4L60E, 4L80E, or new 6 speed transmission. The diesels have the Allison 6 speed. They vary from 1/2 ton, 3/4 ton, and 1 ton. There are several different rear end gear ratios, depending on engine and GVW of the vehicle.
There are 2 with over 500,000 miles.
There are 12 with over 400,000 miles.
There are 53 with over 300,000 miles.
There are 146 with over 200,000 miles.
There are 92 with over 100,000 miles.
That is 305 of our fleet of 358 with more miles than your truck.
I'd say keep your Silverado for a really long time-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-08-2016, 05:10 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Keep your oil clean and drive it. Our late model 1999 has 250,000. Runs great.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 07-08-2016, 05:59 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The LS V8 gassers will run, and run, and run.
On average, 88K on one of these is not even 1/3 used up on a bad day.
Superat stultitia.
J. Morgan is online now   Reply With Quote
Old 07-08-2016, 06:15 PM   #5
2015 30' FB FC Bunk
Ayer , Massachusetts
With enough love and money, any relationship can last forever.
Ted S. is offline   Reply With Quote
Old 07-09-2016, 01:56 AM   #6
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
10-12 year window on spare parts availability. Dealers and chains have an age limit on what they carry. Not that one can't find things, but it starts to become more difficult or expensive.
Used to be 15-years.
I'd always recommend brand new parts, never rebuilt (unless it's on the verge of being sold).
Stay well ahead of service limits as to time. Miles aren't so important.
And resist the urge to downgrade service, parts or other as it ages. What it would sell for is irrelevant compared to reliable first class service.
Old 07-09-2016, 02:36 AM   #7
Seattle , USA
With 80,000 mostly towing miles, you probably have another 30,000 miles before your tranny dies.
Towing, even with a cooler, is a tranny killer. Especially a GM tranny.
But like the old timers used to say, you haven't really made it to the top of the hill 'til you've blown a tranny.
RareStream is offline   Reply With Quote
Old 07-09-2016, 03:21 AM   #8
m.hony's Avatar
2013 30' Classic
12 years on OE parts-
After 12 years you may find "new old stock" OE parts still hanging around for another 5 or so years.
After that, you may still find aftermarket parts indefinitely.
The 12 year parts availability is based on a body style run.
For instance, my 1999 Nissan Pathfinder:
The basic body style ran from 1996-2004 with a cosmetic refresh in 1999 and an engine refresh in 2000.
Other than that, minor cosmetic changes-
In 2016 parts are very scarce but available for my 1999 with a 3.3 V6.
When I bought a new distributor in March there were 4 OE distributors available in the US.
If I still have the car in 2033 when I need another distributor it will be aftermarket if available at all...
TAC #MS-10
Airforums #70955
Old 07-09-2016, 03:36 AM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
My last automatic transmission failure was on a 25 year old GM truck.
Superat stultitia.
Old 07-09-2016, 08:36 AM   #10
m.hony's Avatar
2013 30' Classic
The GM 4L60E, 4L80E, and newer 6-speed routinely wear out- at between 200,000 miles and 300,000 miles.
A few wear a little sooner.
A few wear a little longer.
That is honestly a good useful life.
TAC #MS-10
Airforums #70955
Old 07-09-2016, 11:27 AM   #11
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You will probably get tired of it before it wears out...
Old 07-09-2016, 12:05 PM   #12
1975 Argosy 22
Eugene , Oregon
I have a 2003 Sierra w/ the Duramax/Allison combination and 175,000 on it. I'm planning on 500,000 or to death do us part (my death). Treat it right re: oil & filters and you should be good until you get tired of it.
mrdfred is offline   Reply With Quote
Old 07-09-2016, 12:43 PM   #13
1994 30' Excella
Livingston , Texas
Send a message via AIM to spclkaz
Keep on Haulin'
I have a 1999 GMC 3/4 ton Extended Cab with a long bed, 6.0L gasser with a tranny cooler.
I only have about 98,000 miles on it as I use it mostly for towing my 30ft. Airstream. Here in the heat of Arizona, you do have replace the tires and wipers and other hoses, belts, etc which wear out more quickly. I am religious about oil and other fluid changes.
About six months ago, my mechanic did a top to bottom tune up. It cost me over $2K.. that may sound like alot, but remember I have not had a truck payment in over 15 years. I immediately took it on a 3500 mile road trip and it ran better than new the whole way.
Every time I take it in, my mechanic wants to buy it. He says these engines can last 300,000 miles or more with proper care.
So ... with good care, it WILL last until you get tired of it. But know what ?....I never get tired of not having a truck payment every month.
SPCLKAZ
94 30" Excella
99 GMC 3/4 Ton 6.0L
spclkaz is offline   Reply With Quote
Old 07-09-2016, 01:06 PM   #14
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I am sure you will have hardly any issues before 200,000 miles, then just a few to 400,000. Find a good local shop to work with if you want to go to 400,000. Back in 1961 I drove a truck with 500,000 miles on it. Had to do some fixing, but it never left me walking.
larryglarson is offline   Reply With Quote
2003 Life Expectancy philipsinewe General Repair Forum 3 06-16-2016 08:02 PM
Short life expectancy of LEDs beerrun'r Lights - Interior & Exterior 15 09-21-2013 09:46 AM
Spare Tire - Life Expectancy Frank&Mike Tires 23 11-22-2011 03:28 PM
life expectancy of an Airstream? osolow Our Community 21 09-15-2008 08:45 PM
Brake magnet life expectancy? TomW Brakes & Brake Controllers 4 07-29-2004 03:25 PM
