Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 09-15-2005, 02:55 PM   #1
Devoman
Airstreamin and luvin it
Commercial Vendor
Devoman's Avatar
Profile:  2005 25' Safari
Panama City Beach , Florida
LED Trailer & Brake warning fix for Touaregs.
Here is a fix for the Touaregs out there that have the warning problem.It is just using a couple of resistors.I put in the 1 watt resistors and so far they are working well.
Blue Numbers and Signs
PURCHASE HERE
AIR#8855
Devoman is offline   Reply With Quote
Old 09-15-2005, 03:16 PM   #2
Devoman
Commercial Vendor
Devoman's Avatar
Sorry
Here are the pics.I just connected one wire to the bron and the other to the red one.I then connected the two together to one wire and grounded it and the warnings went away.Pretty cool.
ID:	14645  Click image for larger version
ID:	14647  Click image for larger version
PURCHASE HERE
AIR#8855
Old 09-15-2005, 03:25 PM   #3
Devoman
Commercial Vendor
Devoman's Avatar
Mod
I just got this from my Tech at the dealership.It seems VWOA has a fix for this and he e-mailed this to me.Here it is.No more warning signs anymore.
Here is the e-mail.
Daniel,
I hope that this helps. Remember that these resistors need to be metal oxide and from what engineering was telling VWoA these should be 3 watt. I know that we have used 1 watt type from Radio Shack and they work sufficiently in the past.
Please keep in mind that you have to identify what wires are what on your harness. They may vary depending on the manufacturer of the harness adaptor. I would assume that any LED light needs to be modified for correct operation. As I mentioned to you I would modify the adaptor "pig tail" harness so that the trailer would work properly on another vehicle and also that if you use another trailer with regular lights on this Touareg that it will also work properly.
If you need any more information about this fix, send me a e-mail and I will send you some more photos etc.
Here is the pic for how it is done.
Remember the resistor are 100 ohm 3 watt.
Name:	touareg trailer harness led mod.jpeg
PURCHASE HERE
AIR#8855
Old 09-21-2005, 03:35 PM   #4
platbr
platbr's Avatar
Profile:
Thanks for this fix Devo! After a week on the road with our Bambi + LEDs and our Touareg, I can't tell you how many times we woke up the baby with the Touareg LED light alarm!
platbr is offline   Reply With Quote
Old 09-21-2005, 04:10 PM   #5
Westfalia
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Evergreen , Colorado
Images: 33
I can't wait to wire mine for this, but I still don't have my Touareg to test it.
Plat and Devo, you should have also noticed the proper function of the trailer turn signal indicator on the speed face. Cool, ain't it?
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is online now   Reply With Quote
Old 09-21-2005, 06:03 PM   #6
Devoman
Commercial Vendor
Devoman's Avatar
Turn signal
Yea I did notice this after you had told me about it Aircooled.It is really cool to see the arrows flash to tell you it is working.I just love the way this vehicle works to tell you what is wrong wIth your car or trailer if something goes wrong.
PURCHASE HERE
AIR#8855
Old 09-21-2005, 06:42 PM   #7
platbr
platbr's Avatar
Profile:
I've not noticed this. Is this a nav-only feature? I assume this is something in the MFI?
Old 09-21-2005, 07:02 PM   #8
Westfalia
Westfalia's Avatar
Images: 33
It should be in the speedo face, on the upper right. It only flashes when the turn signal is activated. I'm not sure if this is a color/mono MFI issue or not. What year is your vehicle?
Old 09-21-2005, 07:48 PM   #9
Devoman
Commercial Vendor
Devoman's Avatar
Signal
Mine is on the lower left just under the speedo marker when i am not moving.You wont see this new blinker light until you put the resistors in place to take out the warnings.
PURCHASE HERE
AIR#8855
Old 09-22-2005, 12:09 AM   #10
platbr
platbr's Avatar
Profile:
We've got a 2004 V6 "stripper" + sound system I. We bought in December 2003 and have a vin in the low 20,000s. I'm sure Devo is right that we just need the resistors, as we've never towed with anything before the A/S.
LT versus ST tires on a trailer 76Argosy Tires 16 08-21-2002 06:15 AM
Vintage trailer rally 83Excella The Rally Zone 0 08-13-2002 09:27 PM
Electric Brake Wiring JW84345 Brakes & Brake Controllers 3 03-26-2002 09:40 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
