Old 03-09-2014, 09:11 AM   #1
1966 22' Safari
tucson , Arizona
Just a 2" ball!
Hello there!
I'm restoring a "66" Safari that has nothing more than the 2" ball hitch and the two safety chains. As you know it's a 22' trailer and it will be pulled with Tacoma. Will I need an "anti sway bar" or some other add-on when I tow it?
There is a small (maybe 1" dia.) ball & plate bolted to the front of the "A" close to trailer. Any thoughts?
1966air is offline   Reply With Quote
Old 03-09-2014, 09:20 AM   #2
1977 Argosy 24
Milltown , Wisconsin
That ball was for a friction anti sway device. There would be another same size ball on the hitch of the tow vehicle and the sway control mounted between them. I had a 21 foot Avion that I towed with no sway control or weight distribution hitch, and it towed just fine.
ventport is offline   Reply With Quote
Old 03-09-2014, 10:28 AM   #3
SteveH's Avatar
Common Sense , Texas
Just my opinion here, but with a Tacoma I'd want at least a small light weight WD hitch towing that trailer. The factory tongue weight spec is 377lbs, and loaded will most likely go a lot higher than that.
I tow a 17' Casita with an FJ Cruiser, and the little Casita's tongue weight is over 400lbs. I would not be without the Andersen WD hitch towing with the FJ.
Regards,
Steve
Old 03-09-2014, 10:31 AM   #4
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Originally Posted by 1966air View Post
Hello there!
The hitch head and ball being 2" was standard on these trailers for many years and is adequate for the trailer. You can replace it with a larger hitch head on the "A" frame and go to a larger ball if it makes you feel better. In my opinion weight distribution would be more effective than sway control on a smaller trailer. Unless you are traveling under windy conditions or in mountainous areas. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 03-09-2014, 05:06 PM   #5
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Hello there!
Hi we are almost neighbors. Your "66" is a lot lighter than our "08". I do not use either WD or sway. If you want more info PM me.
Ahab is offline   Reply With Quote
Is there a standard size ball for smaller trailers? RhinoWW Hitches, Couplers & Balls 4 02-03-2014 09:57 AM
Ball Height Issue, 16' International mico75 Hitches, Couplers & Balls 5 01-09-2012 07:25 PM
2" coupler to 2 5/8 ALANSD Hitches, Couplers & Balls 5 10-17-2011 12:59 PM
Hitch Ball for a Reese flyingcloud Hitches, Couplers & Balls 16 05-29-2011 09:28 AM
