Old 10-12-2015, 09:57 AM   #1
bainbridge island , Washington
Jeep towing question
I have a 2007 Jeep Commander with a Hemi and tow package (group IV). Can I tow a 25' airstream assuming a proper weight distribution hitch?
smbonkowski is offline   Reply With Quote
Old 10-12-2015, 10:33 AM   #2
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Look on the driver side of your AS. There you will find the GVW (Gross Vehicle Weight) Then look on the door post drivers side of the Jeep and there you will find another plate OR sticker which will give the towing capacity of your Jeep. Those two should answer your questions.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 10-12-2015, 10:47 AM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
There are certainly plenty of opinions out there, and anecdotes about the miracles that can be worked with the proper "set-up," but ultimately, weight distribution does not change the mfg's max tow rating, and just because someone can tell you they did it without problems, doesn't mean you should.
Your best bet is to look up your Jeep's published "official" tow rating, and then to compare that with the published gross weight of a loaded trailer of your choice. When you see how the actual numbers compare you can then decide how much risk you are willing to take. Remember also, that it isn't always how much you can pull, it is also how much you can stop.
good luck!
Old 10-20-2015, 01:17 PM   #4
1978 25' Tradewind
Lake Havasu City , Arizona
I tow with a 2001 jeep Cherokee 4liter 6cyl no problem.
1bruno is offline   Reply With Quote
Towing a Jeep LKappenman General Motorhome Topics 5 02-22-2018 02:09 PM
Jeep Liberty towing question.. safari05-25 Tow Vehicles 20 07-22-2006 08:20 PM
Towing with a Jeep? Roger and Nancy Tow Vehicles 11 08-19-2003 08:47 AM
Towing 22 foot International CCD with a Jeep? kitsullivan Tow Vehicles 13 06-26-2003 12:01 PM
Towing A Jeep Behind 39' As Deisel TENX53 General Motorhome Topics 2 06-17-2003 08:55 AM
