Old 04-17-2016, 05:33 PM   #43
2015 23' FB Flying Cloud
Lima , Ohio
I just started towing my 23' with a Jeep GC diesel. Power is great and braking seems adequate. The only problem I have experienced is when traveling down a long'ish grade then into a curve. Twice on the way down to Florida and three times on the way back (from Ohio) we experienced significant swaying. Think "white knuckles on the steering wheel". It was enough that I will be trading this Jeep soon for a pickup like a Tundra (smallest) or Denali diesel as we are planning an extended trip out west late this summer. Live and learn.
AirJackson is offline   Reply With Quote
Old 04-17-2016, 06:09 PM   #44
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Too bad about the nasty sway experience, especially on a downhill curve which is an extremely vulnerable situation. I have never had a similar experience with any of my Jeep tow vehicles but I have benefited from some help from the good techs at CanAm who have ensured that my setup is optimized. Sounds like it was the right thing to do. Jim
Jim Flower is offline   Reply With Quote
Old 04-17-2016, 11:32 PM   #45
SEA2014's Avatar
Seattle , Washington
I tow my 20 foot 2014 Flying Cloud with a 2015 Jeep Grand Cherokee Limited using an Equalizer weight distribution. It's a V6 and does a nice job towing. The Jeep's paddle shifters are great for traveling over mountain passes.
SEA2014 is offline   Reply With Quote
Old 04-20-2016, 07:43 AM   #46
andreasduess's Avatar
1984 34' International
Toronto , Ontario
Trading for a different tow vehicle will not solve your problem if your setup is in need of optimization. I don't know enough about your rig to offer an informed opinion, but sway in a turn should not happen with a perfectly set up hitch.
As far as braking is concerned, if the trailer doesn't brake itself, then your brake controller isn't optimized. A perfectly dialed in rig should come to a stop just as well as a vehicle travelling alone.
andreasduess is offline   Reply With Quote
Old 05-04-2016, 02:11 PM   #47
2014 25' FB Flying Cloud
Kingston , Massachusetts
Jeep Grand Cherokee Tow Vehicle
I have had 3 Grand Cherokees with v-8's. The current one is a hemi. All have done very well towing a 25' AS.
Everyone is surprised that it tows the 25', which is equipped with a weight distribution, anti- sway hitch. They feel that I need a truck!
I get between 10 and 12.5mpg depending on terrain.
I recommend it!
isabel is offline   Reply With Quote
Old 05-14-2016, 11:05 AM   #48
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Jeep boondock in Sudbury Walmart on Wednesday, Terrace Bay on Thursday, and an actual Campground, Town & Country, in Winnipeg on Friday. Nasty head wind and snow today, only 13 mpg. Sunny +1.
Name:   ImageUploadedByAirstream Forums1463245436.452603.jpg
Name:	ImageUploadedByAirstream Forums1463245456.831449.jpg
ID:	262517Click image for larger version
Name:	ImageUploadedByAirstream Forums1463245473.598630.jpg
Another Airstream in the background in Winnipeg.
Old 05-16-2016, 12:38 AM   #49
2016 19' International
Carlsbad , California
I have a 2015 JGC Limited diesel and 19' AS International. Love it! The Jeep diesel is a comfortable, perfect match for the 19' AS. Fuel mileage with trailer averages 18 = 20 mpg. My only complaint is the Jeep navigation. It's mistakenly "guided" me down dead end roads and gravel fire roads. Google maps works much better. And their subscription services that use your cell phone minutes are a waste of money. Wish they would just offer a firmware update for Apple CarPlay; but not holding my breath on this one.
WKPwildlife is offline   Reply With Quote
Old 05-16-2016, 09:21 AM   #50
2016 30' Classic
Sandpoint , Idaho
I have an early build 2014 Overland Ecodiesel I purchased new in 2013. I used it to pull my 6600 lb (actual wt.) 25' FB Classic for over 4000 miles throughout the west. I've since moved on to a 2015 Duramax and here's why:
1. The Jeep was max'ed out weight wise with two adults, no onboard cargo, and a lightly loaded Airstream (again, per the CAT scales). Maybe it's just my aviation background talking, but I've seen the accelerated wear and tear on aircraft brought on by flying at max gross weight. Likewise, if I wanted to bring the generator, the BBQ, the extra lawn chairs, the canopy, etc..., it just wasn't an option.
2. The Jeep handled the trailer beautifully with the ProPride hitch and Direclink setup. I never had sway issues or felt like "the tail was wagging the dog." However, climbing some grades required slowing to 45 mph to keep the coolant temp under control. At times I ended up in the slow lane behind a semi creeping up the hill at 25 mph with traffic in the left lane whizzing by at 75 mph.
3. Hopefully, the emissions issue has been fixed by now (I had to have my system replaced at 38,000 miles). I now have over 58,000 miles on the Jeep with no issues, but at the time I did not want to end up in the middle of nowhere with a Jeep limited to 4 mph due to an emissions system issue.
4. Lastly, related to my first reason, was the potential high cost of maintenance. For example, the ZF transmission, FCA markets it as a "lifetime maintenance free" unit. However, the ZF factory recommends changing the fluid and filter at 60,000 miles if used for towing and/or off-road operations. The filter is integral to the pan and must be changed as a unit. It sells for around $300.00. The ZF uses 8 qts of special fluid that sells for around $40.00 a quart. You're looking at over $600.00 not including labor for a fluid and filter change.
I do like my Ecodiesel as a daily driver. I'm averaging 28 mpg combined city/hwy and hope to put 100,000+ plus on it. I really like my 2015 Duramax for towing. I've since moved on to a 30' Classic and it easily handles it with room and weight to spare.
terryg is offline   Reply With Quote
Old 05-17-2016, 06:12 AM   #51
Lima , Ohio
Follow up
Hi All,
Thanks for the great suggestions and replys! After doing much study I believe my problem centered around two issues: 1) I did not have enough weight moved forward on to the vehicle using the hitch, and 2) I was overloaded in the vehicle. After reading the many posts I did the homework and corrected both issues and have found the towing to be much improved. My issue now is trying to decide what I can pack and what stays home as I do not want to be overloaded again. For me, the pack rat, a pickup truck may still be the better option due to heavier payload rating. Thanks for the help!
Old 05-18-2016, 05:33 PM   #52
2015 25' FB Flying Cloud
2016 27' Flying Cloud
santa fe , New Mexico
I have the 2015 GC ecodiesel limited and recently changed out my EZY Lift w/1000 lb bars to the Reese Dual Cam w/800 lb bars and a lower shank. I now have about 600 miles on this setup. I prefer the Reese although there is not a great difference. I think the 800 lb bars provide a softer ride. The Reese was not the easiest thing to install by myself. The cam bars are heavy to hold in place but the hardest part was drilling 11/16 holes for the rivets by hand. I never had any major sway problems with either hitch.
I love the Jeep and got 18.5 mpg on both legs of a trip (400 mi round trip) to Salida, CO from Santa Fe, NM. I had no problems coming and going over Poncha Pass @ 9,000 ft passing semi's on the way up. The only thing I don't like is the shifter which I believe there is a recall on.
Tom
Name:	untitled (1 of 1).jpg
tmcguffy is offline   Reply With Quote
Old 05-22-2016, 10:12 AM   #53
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Hi Tom, I echo your comments on the Ezy Lift and wish that I had my old Reese Dual Cam that my son is currently using. The Reese is much easier to use, lacking all the paraphernalia that accompanies the Ezy Lift with 2 friction anti sway bars. I had to give up on my Hensley since it kept breaking. The Jeep Diesel continues to perform flawlessly and I am pleased that it performs better than my previous generation Jeep Diesel which was also a great tow vehicle. I just returned from a 5,000 k trip over the north shore of Superior and got 15.7 average mpg, Airstream about 7400 lbs. Jim
Old 06-04-2016, 04:20 PM   #54
Stow , Ohio
Own a 2016 Grand Cherokee Overland
Looking to do the same thing, but possibly tow a 23FB International.
Been told by dealer that I'm well below 6200lb that the Jeep can pull
BK2016 is offline   Reply With Quote
Old 06-04-2016, 04:54 PM   #55
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
The Eco diesel can tow 7,200 lbs
tcrum is offline   Reply With Quote
Old 06-04-2016, 05:55 PM   #56
AirstreamJim's Avatar
2007 25' Safari FB SE
Lake Worth Beach , Florida
The 3.6L Pentastar has a max tow capacity of 6,200 lbs (6,000 if you have 4 wheel drive). The International 23 FB weighs 4,746 empty with a tongue weight of 467. Even when you find out what the real weights are (Airstream's numbers are always very optimistic), you should be fine. Enjoy your new Jeep and your Airstream!
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2007 Airstream Safari SE LS 25FB
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
AirstreamJim is offline   Reply With Quote
Jeep Grand Cherokee Tow Capability gvsummer Tow Vehicles 16 09-11-2015 09:58 PM
2011 Jeep Grand Cherokee Overland w/Tow Pkg, Extended Warranty, Loaded KristinS Airstream Classifieds 0 09-06-2014 04:38 PM
Tow Rating for 2000 Jeep Grand Cherokee Laredo? haulinhp Tow Vehicles 16 09-16-2010 09:28 PM
Jeep Grand Cherokee CR Diesel Nicksut Tow Vehicles 19 10-19-2007 08:07 AM
2004 Jeep Grand Cherokee V8 and a 20' Safari? Roger S Tow Vehicles 10 04-15-2007 03:04 PM
