Old 02-05-2016, 07:12 PM   #21
N/A , N/A
Originally Posted by andreasduess View Post
Having said that, the "trucks have bigger brakes" line is yet another myth.
source: www.driverside.com
2016 Honda Odyssey
Front brake rotor diameter: 12.6"
Rear brake rotor diameter: 13.1"
2016 F150 (per Ford website)
Front brake rotor diameter: 13.8"
Rear brake rotor diameter: 13.7"
May there is some truth to this "myth" after all.
rostam is offline   Reply With Quote
Old 02-05-2016, 09:26 PM   #22
bono's Avatar
Mountain View , California
2015 F150
60-0 mph 129 feet
2015 Honda Odyssey*
60-0 mph 126 feet
Kia Sedona
60-0 mph 118 feet
(*The Odyssey tied the Quest and Town & Country for the longest 60-0 mph stopping distance, needing 126 feet.)
http://www.motortrend.com/news/the-b...2015-minivans/
bono is offline   Reply With Quote
Old 02-06-2016, 08:39 PM   #23
tcrum's Avatar
1978 31' Sovereign
Cookeville , Tennessee
2015 Jeep Grand Cherokee overland with heavy duty brakes 60-0= 116 ft
tcrum is offline   Reply With Quote
Old 02-10-2016, 08:52 PM   #24
tcrum's Avatar
1978 31' Sovereign
Just towed my 31' Sovereign 650 miles from TN to FL. 15.5 mpg 2015 diesel overland. Couldn't be happier.
Old 02-10-2016, 10:08 PM   #25
DonnyK's Avatar
1973 23' Safari
Buffalo , New York
It will easily pull it. Wheel base is my only complaint about towing with GC, but still not a deal breaker.
I pull a 1973 Safari with 2008 gas GC equipped with Equal-i-zer sway control system.
Originally Posted by Carmel-Jon View Post
Considering a 2015 Diesel Grand Cherokee TV for 19' International Serenity.
Tired of driving a truck.
Anyone out there pulling with a grand Cherokee?
How would it handle a 4500# trailer?
Carmel-Jon
DonnyK is offline   Reply With Quote
Old 02-11-2016, 07:29 PM   #26
tcrum's Avatar
1978 31' Sovereign
When we drove to FL it was extremely windy, and snowed for the first 200 miles. If I compare the stability to my suburban the suburban does not move around as much in the wind. I will post results towing in normal conditions.
Old 02-12-2016, 09:19 AM   #27
Denis4x4's Avatar
Durango , Colorado
Parts bin sourcing is another way of saying that there are a lot of interchangeable parts, like brakes, within a manufacturer's product line. If I remember correctly, the Ram 1500 and GC with the tow package use the same brake components. I understand that there are people out there that cannot understand how or why one would use a vehicle with a 7200# tow capacity to tow a 6300# Airstream. Having towed my Safari 25 FB with a GMC 2500 HD and a '13 Grand Cherokee with the factory tow package, I'm here to tell you that it can be done safely with the GC. BTW, a short WB tow vehicle can be a real asset when camping in NFS campgrounds in the western mountain states.
If you don't go first class, your heirs will!
Denis4x4 is offline   Reply With Quote
Old 02-12-2016, 10:05 AM   #28
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Donny and Dennis - either of you towing with 6cyl ?
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 02-12-2016, 10:19 AM   #29
Denis4x4's Avatar
Durango , Colorado
No...5.7 Hemi with factory tow package, DirectLink brake controller and ProPryde hitch
Old 02-12-2016, 10:30 PM   #30
2015 23' FB Flying Cloud
Redmond , Washington
I'm not the Dennis you are asking the question of, but I do tow my 23 FB (measured on CAT scale at 5,500 lbs. loaded) with my 2014 6 cylinder (3 L) GC EcoDiesel. I have over 15,000 great miles including a 13,700 mile round trip from Seattle - St John's Newfoundland. This combination includes the factory tow package, Tekonsha P3 brake controller, and an Equalizer hitch. Absolutely steady at 65 mph with semi trucks passing either direction, up and down mountain passes and in all weather conditions. We appreciate the ability to unhitch and explore back roads.
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 02-13-2016, 05:22 PM   #31
Ken J's Avatar
Durango , Colorado
Images: 14
Nice !
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
Old 02-13-2016, 07:42 PM   #32
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Same stuff as WestieHouse except I use an Eaz-Lift hitch with 2 sway bars. Broke the Hensley. JimClick image for larger version
Name:	ImageUploadedByAirstream Forums1455417714.489327.jpg
Jim Flower is offline   Reply With Quote
Old 02-15-2016, 07:13 PM   #33
tcrum's Avatar
1978 31' Sovereign
Jim, are the sway bars the same for both sides or is there a drivers side and a curb side?
Old 02-16-2016, 02:16 PM   #34
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
In my case, The bars are the same for both sides. One is mounted right side up and the other upside down. This only impacts the ability to read the brand name. Jim
Old 02-16-2016, 02:20 PM   #35
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Found a photo. Click image for larger version
Name:	ImageUploadedByAirstream Forums1455657615.143473.jpg
Old 02-16-2016, 04:24 PM   #36
tcrum's Avatar
1978 31' Sovereign
I have that exact same setup. I have a second sway bar I'm going to add this weekend.
Old 04-16-2016, 04:24 PM   #37
2015 25' FB Flying Cloud
2016 27' Flying Cloud
santa fe , New Mexico
Jim,
I too am towing w/the JGC ecodiesel using the eaz lift hitch towing a AS 25' FC but using the standard shank which appears to be 1/2 to 5/8 too high. Did your towing improve with the lower shank?
Tom
tmcguffy is offline   Reply With Quote
Old 04-16-2016, 06:43 PM   #38
Prairie Schooner II
Jim Flower's Avatar
1997 25' Safari
Jeep Grand Cherokee Tow Vehicle
Yes it improved the handling but only slightly. The main benefit is that the Airstream is now level so I assume all the running gear will wear evenly. I just today returned from a 6,000 K round trip to Florida. Every thing worked perfectly. The latch for the hot water heater cover fell off so I stopped at Jackson Centre on the way by and bought a new one for $2.76. Jim
Old 04-17-2016, 08:13 AM   #39
2014 23' FB International
Melbourne , Florida
We are pulling our 23ft AS (GVW fully loaded 6,000lbs.) with a 2014 Jeep GC diesel. Great combination. Get about 17-19 mpg with trailer in tow, 29-31 without. Currently have about 28K miles on cherokee. Ours, of course, has the trailer towing pkg with oversized battery, etc specifically designed for towing.
ASOPA is offline   Reply With Quote
Old 04-17-2016, 02:57 PM   #40
jeep gc ecodiesel + eaz lift
Jim,
Thanks for your reply. I was hoping you would say it made a big difference. My eaz lift came with the trailer and I've towed with it about 2,000 miles. I've got the ball tilted @ 6 deg and the chains on the third link now. I'm trying to decide weather to keep it and get the lower shank or get a different hitch probably Reese dc.
Tom
Jeep Grand Cherokee Tow Capability gvsummer Tow Vehicles 16 09-11-2015 09:58 PM
2011 Jeep Grand Cherokee Overland w/Tow Pkg, Extended Warranty, Loaded KristinS Airstream Classifieds 0 09-06-2014 04:38 PM
Tow Rating for 2000 Jeep Grand Cherokee Laredo? haulinhp Tow Vehicles 16 09-16-2010 09:28 PM
Jeep Grand Cherokee CR Diesel Nicksut Tow Vehicles 19 10-19-2007 08:07 AM
2004 Jeep Grand Cherokee V8 and a 20' Safari? Roger S Tow Vehicles 10 04-15-2007 03:04 PM
