Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 04-27-2019, 08:57 AM   #1
Clive , Iowa
Jack tilt
I have rescently installed a Propride P3 hitch. Things seemed to go OK, except the torsion jacks tip out instead of staying straight. Tightening the 1/2 bolt thru the spacer against the frame, makes condition worse, and spacer gets loose. I have used the extra 1/2 nuts that came with the unit to tighten up against the frame to help lock in place. Has anyone else dealt with this issue.?
jpaine4 is offline   Reply With Quote
Old 04-27-2019, 09:02 AM   #2
2007 22' International CCD
Jack tilt
Did you get a set of shims with the jacks? Are the U-bolts installed first and tightened properly?
On my trailer, I’ve never had the jacks tilt at all.
If not, contact Sean at ProPride for assistance. He should also be able to answer any questions on install problems or provide parts to solve any issues.
Some pictures would also help.
Old 04-27-2019, 09:13 AM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Im trying to remember exactly how I installed the shims (you have those right? Like 1/2” steel plates?). I’m not at the trailer but will try to get a pic this weekend if I can. Once I installed them, they haven’t moved and they keep the towers perfectly straight.
Need 8"x29.75" tilt-out Creation window glass for 1999 Safari 27' roscher Windows, Doors, Locks & Vents 1 09-29-2015 03:04 AM
Hehr vs. Full tilt windows. Soyboy Windows & Screens 28 03-17-2012 07:55 AM
Tilt-a-rack . Advice needed. Thanks Octane General Motorhome Topics 9 09-09-2011 03:19 PM
Tilt Switch source? pwhittle Mechanics Corner - Engines, Transmission & More... 2 04-22-2009 07:38 AM
Tilt Mechanism - Lookout Blinds xengineer Upholstery, Blinds, Walls & Interior Finishes 0 09-01-2008 05:09 PM
