The idea of jacking the trailer with another jack may be a first attempt. Take the load off the trailer jack and attempt to lower the trailer jack with the electric switch.
What has happened is you have jammed the shaft in the jack and the motor is forcing against it and releasing against the safety clutch. By removing the weight load on the jack it may be enough to allow the motor to move the jack shaft.
2004 Excursion 4x4
