Old 02-03-2017, 02:22 PM   #1
2015 25' FB Flying Cloud
Meadow Vista , California
Jack Pad interfering with Pro-Pride?
Considering a Pro-Pride and wondering about an issue I saw on a You Tube video on hooking up the hitch. In a severe angle situation the jack pad was blocked by the WD bars. My question is, has any one experienced this and is the jack pad on the Classic removable?
Thanks for your responses!
SS
SilverSinbad is offline   Reply With Quote
Old 02-03-2017, 02:36 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hi there. I've noticed you've asked a lot of questions about the ProPride. If you haven't seen it - there's a HUGE thread on all things ProPride here: http://www.airforums.com/forums/f464...ide-57179.html
It's a bit to sort through but some really excellent insight there.
I've never used anything else so I have nothing to compare it to. But I've run in to all the problems you hear about and with some time for the learning curve - I get it now. It was all user error
Good luck and happy camping!
Old 02-03-2017, 02:50 PM   #3
Thanks for your response. I did look at that thread and it is overwhelming at 104 pages. I am hoping someone will help me skip ahead.
Old 02-03-2017, 03:09 PM   #4
Cave Creek , Arizona
I have run into the issue. There are spots, including my driveway where the TV/trailer angle is off and it doesn't take much to cause an interference with sway bars and the trailer jack pad. There is never an interference with the jack ram itself on my Trailer. The situation can be improved by pulling forward slightly after backing up because the PP will naturally straighten out somewhat. Also adjusting the sway bar jacks until the bars are loose gives some flexibility.
However it has caused enough problems that I ordered a removable extended Jack foot from Atwood (#82660) that I plan to install this weekend in place of the welded extension foot that came with the trailer. With it I hope to have an easily removable pad to get around the sway bars. I will let you know how well it works.
Pete B55
2017 Classic
2017 F-250
Pete B55 is offline   Reply With Quote
Old 02-03-2017, 03:10 PM   #5
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Unbolt the pad and use a separate foot that you can slide on or off the jack post.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-03-2017, 03:20 PM   #6
I have a 2017 Classic which came with a welded foot on a 1 foot extension that is lynch-pinned inside the ram. When you are at the site and there is interference, it can't be removed because the sway bars prevent sliding it out. The only recourse is to either straighten the TV/trailer angle or remove the extension ( not easy) before backing in. It will definitely help to switch to a removable foot
Pete B55
2017 Classic
2017 F-250
Old 02-03-2017, 03:29 PM   #7
Please let me know how it works out for you!
Old 02-03-2017, 03:48 PM   #8
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My 2002 Classic bought last January used did not have a jack foot at all. I had an extended foot I bought for my 25 which I use by drilling the jack ram and pinning it. On both trailers the extended foot is pretty low, so I always take it off when towing.
I'm looking at getting a Propride now so it sounds like my normal operations will be fine.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 02-03-2017, 05:30 PM   #9
Frederica , Delaware
You know, there are not many complaints about the PP or the Hensley other than price. You can worry about the little things with this hitch. Practically talk yourself out of this hitch, buy another hitch and worry or scare yourself every trip thereafter. I have 3 different top rated hitches and will not tow with any of them again.
Overloaded is offline   Reply With Quote
Old 02-03-2017, 05:39 PM   #10
2015 30' FB FC Bunk
Ayer , Massachusetts
Since we camp in tight spots, we've run into it several times. I am working on modifying the connection from the spring bar to the weight jack to a quick disconnect. In the event of a conflict, just swing the bars away.
Ted S. is offline   Reply With Quote
Old 02-03-2017, 06:35 PM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
If you back at angle into any site, and you will, you will want a removable, or no, foot. We have had a few different ones, the best is the one we use now, a 10" piece of 4 x 6 wood block that I set under the bare jack post when lowering it. Never interferes with anything, and if I take off and leave it at the campsite we don't lose anything.
Doug and Cheryl
Old 02-03-2017, 06:55 PM   #12
You make a good point. My thoughts are, if you can't lower the jack because of the pad, how can you expect to remove to pad. Well mine pad goes inside the the jack tube as it is adjustable. Other pads may be different.
Old 02-03-2017, 07:42 PM   #13
2007 22' International CCD
My setup has a jack foot that is not attached. I simply retract the ram all the way, and pick up the foot for storage in the TV. No interference even at extreme angles.
Old 02-04-2017, 09:42 AM   #14
Quoted the wrong post yesterday, please let me know how the change works for you.
SS
Pro-pride (Hensley) Hitch for sale Schilling Airstream Classifieds 0 06-06-2014 08:56 AM
Pro Pride or Hensley with F350 4X4 Crew Cab vetdr Hitches, Couplers & Balls 20 04-01-2012 10:24 PM
Pro Pride Arrived Today! AirHeadRik Hitches, Couplers & Balls 3 12-03-2010 07:18 AM
First Pro Pride tow Aviator Hitches, Couplers & Balls 3 06-06-2010 10:34 PM
Pro pride hitch/weight distribution question dkottum Hitches, Couplers & Balls 19 03-03-2010 09:42 PM
