Old 02-04-2017, 09:58 AM   #15
Llando88's Avatar
2016 30' Flying Cloud
Jack Pad interfering with Pro-Pride?
So far, with using the PP on two ASs since Nov 15, across the US a couple times for 6-7 months total, I've not had a situation where I can't pull forward slightly, or turn the truck, to deploy the jack foot past the bars.
It might be due to our AS size (we've had a 27' and a 30', both FCs). Since we're not exactly squeezing into little spots, I seem to have enough room.
This includes a very narrow spot between trees in Lake Altoona GA, and a site in Tempe AZ where the campground host was having a heart attack as I backed past her light pole. By 6".
If there is a situation where I *do* have a problem, my approach is going to be to use my bottle jack under the PP hitch unit to take the weight off the truck. I'd drive out as normal, the swing the hitch so I could deploy the foot normally. I've not had to do this yet though.
Given the advantages of a PPP hitch design (PP or HAHA), I'd frankly not tow with anything else. 'Buy once cry once' as they say.
2016 30' Flying Cloud / 2016 Ram 2500 Diesel 4x4
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Llando88 is offline   Reply With Quote
Old 02-04-2017, 11:16 AM   #16
DoublTrouble's Avatar
2015 27' FB International
Carlsbad , California
Like MOJO, we took off the circular OEM foot. BAL tongue twister is the way to go.
DoublTrouble is offline   Reply With Quote
Old 02-04-2017, 12:45 PM   #17
2018 33' Classic
Newport , Pennsylvania
Appears to be a lot of work to u hitch and hitch. .??
EarlM is offline   Reply With Quote
Old 02-04-2017, 02:06 PM   #18
WaLee's Avatar
Nevada City , California
Not really once you learn.
WaLee is offline   Reply With Quote
Old 02-05-2017, 01:27 PM   #19
Cave Creek , Arizona
Originally Posted by SilverSinbad View Post
Considering a Pro-Pride and wondering about an issue I saw on a You Tube video on hooking up the hitch. In a severe angle situation the jack pad was blocked by the WD bars. My question is, has any one experienced this and is the jack pad on the Classic removable?
Thanks for your responses!
SS
I swapped out the ram extension (that came with the pad welded) using an Atwood 82660 extension pad on my 2017 Classic. It fits like a glove on the ram and is perfect length. With this now my propride can be at any angle and I can get past the sway bars.
I recommend it. $16 bucks on Amazon
Pete B55
2017 Classic
2017 F-250
Pete B55 is offline   Reply With Quote
Old 02-05-2017, 03:50 PM   #20
Llando88's Avatar
I am looking at that on Amazon, but am having trouble picturing how that helps?
Do you only install it when lowering the jack foot?
Old 02-05-2017, 05:21 PM   #21
2015 25' FB Flying Cloud
Meadow Vista , California
How did you get the original one off?
SS
SilverSinbad is offline   Reply With Quote
Old 02-05-2017, 10:27 PM   #22
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
If worried get or build your own jack foot. Here is one..
http://shop.redneck-trailer.com/p-83...in-140070.aspx
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-06-2017, 10:38 AM   #23
SS- yes - here is a picture of it
Pete B55
2017 Classic
2017 F-250
Old 02-06-2017, 11:27 AM   #24
SS- yes - here is a picture of itAttachment 279303
Pete,
Thans for the picture. How did you get the old one off? Did it just slide off and you slide the new one on when cranking down the jack? I am confused, I thought the original foot was welded on somehow???
Thanks for your help!
SS
Old 02-06-2017, 11:30 AM   #25
2007 22' International CCD
Jack Pad
I think some of them are held on the ram with a single bolt up from the bottom. Mine was loose when I got the AS, and I never bothered to look to see what might have held it on.
I just keep it in the TV when I'm not using the jack...
Old 02-06-2017, 02:39 PM   #26
Pete,
SS
My 2017 Classic had a 12 inch extension with a welded pad that slid inside the ram. All I had to do was hitch up the trailer, pull the extension pin, pull out the old extension, and add the new extension with pad. The main difference is the new part does not pin into the ram and the ram slides into the pad/extension. When you hitch up and retract the ram, the pad/extension disconnects. When you unhitch, extend the ram with the pad/extension on the ground. At no time will it interfere with the propride sway bars, no matter what the angle of the hitch.
The Atwood is very stable on the ram and is rated for 6000#
You may get by with just an Atwood pad (as opposed to this one with an extension) however the travel of the ram may not be sufficient depending on the slope of a site. I think this part is optimum length
Pete B55
2017 Classic
2017 F-250
Old 02-06-2017, 03:02 PM   #27
Pete,
SS
Also to help you visualize- the Airstream supplied extension slid snug inside the ram, required to be pinned to one of six lengths, and U need a hammer to remove - too much at every hitchup/hitchoff.
The new part slides outside the ram but loosely- so removal is easy, has stops for a fixed 7" extension, does not require a pin ( but you could add one if you wanted). This is much more flexible and quick when hitching and unhitching. You just need to carry it with you because it wont stay on the trailer like the original did.
Pete B55
2017 Classic
2017 F-250
Old 02-06-2017, 03:32 PM   #28
Thanks Pete you have been very helpful! I am interested in the ability to use the pin. I am concerned my storage yard may misplace the foot. So your solution would give me the ability add a pin at the times I felt I needed it (storage or service) and then leave it off at other times? I am assuming it would use the original holes in the Atwood to pin through?
Thanks so much! Picking up our Classic in two weeks and leaving within a day or two, so trying to be prepared to make that change right away.
Best,
SS
Pro-pride (Hensley) Hitch for sale Schilling Airstream Classifieds 0 06-06-2014 08:56 AM
Pro Pride or Hensley with F350 4X4 Crew Cab vetdr Hitches, Couplers & Balls 20 04-01-2012 10:24 PM
Pro Pride Arrived Today! AirHeadRik Hitches, Couplers & Balls 3 12-03-2010 07:18 AM
First Pro Pride tow Aviator Hitches, Couplers & Balls 3 06-06-2010 10:34 PM
Pro pride hitch/weight distribution question dkottum Hitches, Couplers & Balls 19 03-03-2010 09:42 PM
