Old 06-27-2014, 03:27 PM   #1
2012 25' FB Flying Cloud
albany , Georgia
Italian style scooter on back.
Hello from a new Airstream owner.
I have a 20 ft Flying Cloud, I was told that the frame of an Airstream would not hold a Motorbike but my Scooter only weighs in at just under 200 lbs, looking under the back of the Airstream the frame that extends to the bumper, is no lightweight in thickness. A huge Harley will weigh in the 1000 lb plus area, so I can understand why they can not be added onto the back of an Airstream but this scooter is light.
I had thought that I could put a hitch on the front of my Tahoe but on reading around, some Police in some States are inclined to give warnings and tickets for a bike on the front of a truck.
I am a rather good welder and see no reason that a hitch could not be welded between the two ends of the frame that would support a small scooter and it's carrying rack.
So my question is, is there anyone reading this post that has some knowledge on this idea of mine.
Cheers in advance,
James.
jmpgino is offline   Reply With Quote
Old 06-27-2014, 03:59 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Anything hung off the back end will have it's effect on the frame magnified as it bounces up and down going down the road because it is so far back from the axle. 200lbs is a lot of weight! I had a vintage Bambi that had a spare tire and a tool box mounted on the rear frame, and it was enough weight to cause rear separation between the shell and the body - I could look under the kitchen cabinet and see daylight coming through.
I think you would be better off to figure a way to mount it to the tongue or carry it in the truck. I wouldn't put anything on the back bumper.
Stephanie
Old 06-27-2014, 04:21 PM   #3
aquinob's Avatar
Portsmouth , Virginia
Sorry, but not a good idea to hang anything off the rear bumper. Anything aft of the rear wheels is unsupported weight. Take the 200 lbs and the distance from the rearmost axle and multiply them together to get an idea of the amount of torque you will be putting on the frame every time you go over a bump. (200lbs X 10' = 2000 ft/lbs) as an example.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 06-27-2014, 04:51 PM   #4
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
James, good advice from Stephanie and Bob.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 06-27-2014, 05:14 PM   #5
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
There are a couple options. I do not have a Vespa but a Honda PCX150 that I ride everywhere. It weighs 268lbs or so. If it is a 50 CC you may be able to put in on a mat inside the door, see width. The truck bed is another option and one I use.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 06-27-2014, 05:30 PM   #6
dznf0g's Avatar
Oswego , Illinois
My Yamaha Riva 125cc goes in the truck bed. Wouldn't even consider anywhere on or in the AS.
-Rich-
Old 06-27-2014, 05:50 PM   #7
2006 25' Safari
Images: 8
If I still had my little Vino I would put it in there, ride it up and down the isle- yeah!
oh, I would need a slide out model I guess for that!
Old 06-27-2014, 05:52 PM   #8
1971 31' Sovereign
Lake Minnetonka , Minnesota
This is a good example of what not to do.
bakes is offline   Reply With Quote
Old 06-27-2014, 05:53 PM   #9
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
If a certain individual can make people believe that a vehicle with a 2000lb max tow rating can safely tow 10k lbs why can an Airstream not be modified to carry a 200lb scooter?
MICHAEL
Old 06-28-2014, 09:51 AM   #10
1976 Argosy 24
Michael,
Because we are not talking about the same thing. Andrew T can explain that for you!
Sergei
Old 06-28-2014, 03:51 PM   #11
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Maybe I'm just not creative enough, but I cannot imagine any reason you would want a ball welded to the back of your trailer.
Stephanie
Old 06-28-2014, 04:04 PM   #12
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I would add a slight correction. The torque you describe is what the scooter would be putting on the system CONSTANTLY. The force would be much higher going over a bump.
David
Old 06-28-2014, 04:56 PM   #13
Gainesville , Florida
Airstream frames are not designers for that. My Avion would have no problem except really shifting weight off the tongue. Jim
Old 06-28-2014, 07:10 PM   #14
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
So exactly how does telling everybody how a completely different trailer has no problem doing something have anything whatsoever to do with whether or not the trailer being discussed can?
SMEV Italian Ovens/ sinks/ cooktops AeryCorp Commercial Listings 23 10-24-2011 05:18 AM
how do I load my Vespa scooter into the back of my PU? Swingking Our Community 31 10-22-2007 01:02 PM
Custom Italian-designed Airstream... bredlo General Interior Topics 24 01-30-2006 05:37 PM
Scooter transport rdm General Motorhome Topics 19 11-30-2005 07:26 PM
