Old 07-29-2012, 09:53 PM   #1
2011 25' FB Flying Cloud
chalk hill , Pennsylvania
Is the front of my AS too low?
Just took the Airstream for it's first shakedown ride with the new to me F-250. Looks like the stinger for the Hensley I got with the trailer has too much of a drop. Opinions please. I heard Hensley will exchange these for you, is that true? Also, how much do you tighten the bars on each side, just hand tight?
thanks,
Dave
ID:	164159   Click image for larger version
Getahobby is offline   Reply With Quote
Old 07-29-2012, 10:21 PM   #2
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
It sure looks that way to me. Im sure you will bottom out when approaching a driveway or speed bump. Seems like too much drop on that stinger.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 07-29-2012, 10:56 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Getahobby. I don't know if you are on level ground or not, but if you are, I see a lot. Your hitch looks like it's about to drag on the ground, the rear of your truck looks low, and the front wheels on your trailer are closer to the wheel well than the rear wheels. First thing I would do is to crank up the bars until the truck levels out, then check to see how much adjustment you need to level out your trailer. Then replace the stinger, if necessary.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-30-2012, 12:23 AM   #4
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
In most Canadian provinces, the motor vehicle act does not allow any part of the vehicle to be lower to the ground than the bottom of the rims... ie, if you took all your tires off, all 4 wheels would still touch the ground.
What you have here does not appear to be legal, so you need to address at least that aspect of it...
Friday is offline   Reply With Quote
Old 07-30-2012, 04:22 AM   #5
1981 31' Excella II
New Market , Alabama
It looks a few inches low. It also looks like your load bars don't have much tension on them which will make it low in the front.
Perry
Old 07-30-2012, 06:32 AM   #6
Thanks guys..
Calling Hensley this morning for a new stinger and a manual for the hitch. I hope to be camping soon!
Dave
Old 07-30-2012, 07:05 AM   #7
dznf0g's Avatar
Oswego , Illinois
Before you do that, give us the distance from the top of the truck receiver opening to the ground with the truck unhitched and unladen.
It looks like the truck is sagging and you may not have enough tension on the spring bars.
In my experience with a HAHA:
23" = a 8" drop
21" = a 6" drop
19" = a 4" drop
17" = a 2" drop
15" = a straight stinger
13" = a 2" rise (my Chevy van is actually that low, with the receiver under the bumper)
-Rich-
Old 08-05-2012, 10:59 PM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
23" = a 8" drop
21" = a 6" drop
19" = a 4" drop
17" = a 2" drop
Hey, good job with that reference set! Added it to the HAHA thread? I've been needing to exchange the stinger since I am carrying an additional 600-lbs in the truck bed and have replaced the hitch receiver with a different piece that "lowers" the hitch opening. Been thinking 2" drop, but will check a few more times after I nail down the tire pressures (and possibly exchange a few things from truck to SS trunk) . . a straight piece might be the one to go with. An SS trailer is different, but ball height is ball height. Thanks for the chart.
And agreed that the OP was correct to post and ask advice. The trailer needs to be level once hitched up properly.
Old 08-06-2012, 05:40 AM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You can download and print the manual from this page:
User Manual Downloads | Hensley Hitch Towable Products
I use a 4" drop with my F250 and Hensley.
Old 08-06-2012, 06:09 AM   #10
Looks like I'm about 19.5". I cranked up the jacks and I look pretty level now with the 6 inch drop, but 4" would be ideal. Hensley won't exchange the stingers if you don't have the lifetime warranty. They're $210 plus shipping. Anyone looking for a 6 inch drop at a discount?
Dave
Old 08-06-2012, 07:18 AM   #11
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Just installed a new hitch yesterday and all this is in mind when I look at your photos. Looks you have plenty of TV to do the job.
First, as you are indicating make sure the drop/stinger is at the proper height. Without this, you are off to a very bad start. Once you get that nailed down, you can dial in the WD effect to get the proper loading on the front of the truck.
Best of luck.
Alphonse is offline   Reply With Quote
Old 08-06-2012, 07:41 AM   #12
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
23" = a 8" drop
21" = a 6" drop
19" = a 4" drop
17" = a 2" drop
Are these measurements to lower edge of receiver?
If so, looks like a pretty good reference. I'm at 18.25" (lower inside surface) with a 2" drop, seen here:
That's what level looks like.
boondockdad is offline   Reply With Quote
