02-15-2016, 10:31 AM
#41
2015 16' Sport
Pineola
, North Carolina
As I posted earlier on this thread the Class IV Airsafe made s HUGE difference on the smoothness of our rig. Much more comfortable in the cab of our truck and much less movement of stuff in our 16 Sport Bambi. It just makes common sense that this is less stress on the trailer components. Since we do not need WD with our rig I can only speak about use of the air safe alone. I would not tow what we have now without it.
"Certainty on any matter is not one of the human attitudes the Gods admire or tolerate."
A. Cross
02-16-2016, 05:00 AM
#42
Vintage Kin
Fort Worth
Is Addition of Air Safe Hitch Substantially Worthwhile?
Work the Steer Axke weight, first. 100% FALR, as a start. Then, more. Then, less.
TV tire pressure is what needs attention most with these changes.
I might see 20 AS trailers on the road for every one that has covered the most basic hitch requirement, that of a level trailer.
Plenty of meat on that bone.
Use a scale, get it right (see Andrew Thomsons Hitch Hint articles) and then
Maybe
An Air Safe is worth considering.
With a 9k Dodge CTD and a trailer at 9k with TW of 1,100-lbs, I can't find evidence of harshness.
Work the hitch settings. And TV tire pressure.
02-29-2016, 03:21 PM
#43
I bought my Class V AirSafe back in 2006. I had been reading on these forums the problems related to using heavily sprung pickup trucks like my F250 diesel to tow Airstreams. Namely, the heavy trucks were said to be complicit in overworking and shocking Airstreams' frames and superstructures to the point of damage. Posts especially by Andy were quite compelling to read. He said the Airstreams were better suited for being pulled by soft-sprung sedans rather than heavy pickups.
Because I seemed to be suffering from this problem, with popped rivets, cabinet doors swung open, the interior often found in a flux and even some torn/cracked aluminum panels in a couple of spots, I bought the AirSafe. Since the day I put it on, all these "shaken trailer" symptoms have disappeared.
I've used this AirSafe from coast-to-coast for the past 10 years. As the state of our nation's roads have deteriorated during those years, the value of the AirSafe has increased. It is an investment I'm happy I made back then. It's still paying me dividends every time I take the rig out on our crumbling infrastructure.
As the saying goes, I won't leave home without it.
01-16-2018, 12:28 PM
#44
2018 33' Classic
Medway
, Massachusetts
I can see the value of the AirSafe but do not see how you accomplish either weight distribution or sway control with it. Do you ignore these aspects? I will pick up a 2018 33' Classic in the spring with out new F250 diesel with full tow packages, etc and am trying to determine what would be the best system to connect the two. Thanks. M
01-17-2018, 08:02 AM
#45
2016 27' Flying Cloud
Olympia
MAHofer wrote: "I can see the value of the AirSafe but do not see how you accomplish either weight distribution or sway control with it."
______________________
Short answer: You don't get either weight distribution or sway control with an AirSafe --- it's only function is as a vertical shock absorber.
To get weight control and sway control, you must add that to the system. With my AirSafe, I added my old Blue Ox system to provide both.
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
