09-15-2014, 06:31 PM
1967 28' Ambassador
Gatlinburg
, Tennessee
Is a weight distribution hitch necessary?
I have a Dodge 3500 diesel dually & was wondering if a Hensley hitch is needed? I towed my project trailer 100 miles or so on just the Reese receiver hitch. (67 28' Ambassador)
I almost have it ready for the road & if I do need a hitch, can someone send a link to a good reliable one?
I've read a few threads on this subject, but with all the opinions & equipment available, it's very confusing.
thanks in advance,
Jerry
09-15-2014, 06:54 PM
1993 34' Excella
York
, South Carolina
I am sure you will get a variety of answers to your question. Probably all good answers.
I can tell you that I pull my '34 with a 1 ton DWR and don't leave home without my Reese Dual Cam set up. I don't pull it up particularly tight, just enough to allow the sway control part to work without making the ride even more stiff for the trailer.
There are many opinions going both ways. Personally, I would err on the side of caution and use WD/sway control. Been running my Reese set up 25 years. Works great.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
09-15-2014, 06:55 PM
1993 34' Excella
York
, South Carolina
I probably should add that I run #750 bars. John
John
09-16-2014, 08:35 AM
1981 31' Excella II
New Market
, Alabama
You might want to consider an Airsafe hitch as well. Those big trucks with the stiff suspension tend to shake Airstreams to death.
Perry
09-16-2014, 08:54 AM
Princeton
, New Jersey
You do not need a WD system with that truck. You may want to consider a sway control system though.
I would suggest you look at the Andersen. While the Andersen is sold as a WD hitch it stronger consideration is it's sway control and simplicity of usage.
2004 Excursion 4x4
09-16-2014, 11:16 AM
2014 30' FB FC Bunk
Hoover
, Alabama
My 3/4 ton truck with 30fb bunkhouse needs WD in my opinion
I adjusted my hitch a couple times with very little WD applied to see if ride improved - but greatly noticed a difference in my steering
With a 1 ton perhaps it would be imperceptible? Depends on what and how much you load on the truck I suppose?
Many hitches do both sway control and anti sway so to that extent it's moot...
As far as which hitch there are a lot if opinions and personal experience voiced in here as well as some in other sites like RV.net - read till your heart is content - or you get dizzy and or nauseous
09-16-2014, 11:27 AM
Corona
Is a seat belt necessary?
09-16-2014, 11:34 AM
2012 25' Flying Cloud
Battle Lake
I would have some concerns about that truck beating up your 28' Airstream. You might look into AirSafe to isolate the trailer from the rough truck suspension and a simple sway control setup.
Or a light truck. Best to match the truck to the Airstream, then an appropriate w.d. hitch with sway control.
Doug and Cheryl
09-16-2014, 11:46 AM
2014 30' FB FC Bunk
Hoover
, Alabama
If you have that thang loaded down a lot then I assume it would be not as rough - but if only a relatively small payload it would be rough
09-16-2014, 12:04 PM
1981 31' Excella II
New Market
, Alabama
Those 1 tons have progressive springs on them. They don't tend to move much even with 2000 lbs in the bed. PharmGeek's probably has twice the tongue weight of that 67.
Perry
09-16-2014, 12:10 PM
2014 30' FB FC Bunk
Hoover
, Alabama
Oh I missed that this is a 67.....
09-16-2014, 12:18 PM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
You can certainly tow it without a WD hitch however it will be more pleasant with one. Probably lighter bars would be fine. Certainly no need for a Hensley though unless you really want to go that way. Reese or similiar will do a fine job
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
09-16-2014, 12:45 PM
St. Catharines
, South Western Ontario
Jerry, in reality you have the perfect TV for a nice, big, heavy triple axle 5er.
For your Airstream a good match would be a half ton pick up, SUV's, or a car.
Any chance you have one of those as a 2nd vehicle?? That way you could save the dually for the heavy duty jobs.
09-22-2014, 05:24 AM
1967 28' Ambassador
Gatlinburg
, Tennessee
Thank you for all the replies & opinions.
Although this matter has been covered several times in the forums, it clarifies my specific need.
I have several more vehicles but not one of them would be able to pull the trailer up a hill let alone across the USA.
Thank you for your time.
Jerry
09-22-2014, 08:11 AM
1966 26' Overlander
Anderson
, Indiana
Hello Jerry,
I've got a 3/4 Dodge SRW, and have pulled my 1966 26' Overlander a few times, and agree that a WD hitch is not necessary. The tongue weight is not that heavy on our trailers. I do however use the sway control, so I've been using a WD hitch set up, just not putting the load bars on. I like having the sway control on there, but with your dually, you should be fine.
09-22-2014, 09:29 AM
Princeton
, New Jersey
Originally Posted by Kline1966
Hello Jerry,
I'm confused. How are you getting sway control out of the system without putting the bars on? The bars are what provides the sway control.
2004 Excursion 4x4
09-22-2014, 09:37 AM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Imo you NEED neither WD or antisway for your 3500 so long as you drive cool and keep it below about 62.
A ProPride or a Hensley will make your ride more pleasant though. (For the antisway, never mind the need for WD with your mildly loaded 3500)
As a disclaimer I will state that I have;
A. Towed on the ball.
B. Towed with a Hensley.
I cant say how well other devices change the towing experience, I can only state emphatically that an articulated hitch greatly alters the towing mannerisms of the combination to an amazing degree toward the positive.
