Old 07-29-2016, 07:00 PM   #1
Tao
Tao's Avatar
2013 19' International
Chapel Hill , North Carolina
Intl. Signature 19, GMC Sierra 4x4 crew cab - Ball Hitch Only?
Just took delivery of a 2013 Intl. Signature in mint condition. Seller delivered from Miami, FL to Chapel Hill, NC driving a few year old Ford Expedition.
I noted he just had a straight ball hitch, no weight distribution, sway control, etc. on his set up.
Questioned him about this and he said that is all he had used since purchase of the trailer new in July 2014! Asked how he came up and he said I-95 to I-40. Asked about truck sway, proposing, etc. He claims no issue because he drives 63 to 65MPH.
Question/Guidance: Is he just lucky OR is this adequate for a 19' International?
I'll be towing with a 2015 GMC Sierra SLT 4x4 Crew Cab with the 5.2 gas and tow package.
I'd like to avoid the hassle of the various configurations of hitches IF the straight ball hitch is adequate for a 19.
Opinions from those that have actual experience would be appreciated.
Tao is offline   Reply With Quote
Old 07-29-2016, 10:33 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
His Expedition has the considerable advantage of full independent suspension, which places the rear suspension attachment to the body at a much wider stance than a pickup. More stable. The Expedition's body/frame probably has less frame flex, which helps stability. He also watches his speed, maybe even lower than 63 to 65 in windy conditions. He may be loading the back of his SUV lightly, keeping enough weight on the steering axle under normal conditions. And he's lucky several sway inducing conditions have not happened at the same time.
Don't risk it, weight distribution hitches ensure you always have good steering control and a balanced load. The sway control device helps keep sway oscillations from gaining momentum.
Doug and Cheryl
Old 07-30-2016, 02:27 AM   #3
1991 25' Excella
Stanfield , Oregon
Wd wont be needed for that light of a trailer. But under certain conditions sway control might be, especially being a single axle trailer.
SpletKay06 is offline   Reply With Quote
Old 07-30-2016, 02:14 PM   #4
Tao
Tao's Avatar
Worked on getting my stuff stowed in the trailer today. Want it set up so I just go out the door, hit Whole Foods for groceries and leave.
Ran a test:
Unhooked from trailer, GMC measured as follows:
Drivers front, pavement to top of wheel well: 36 5/8"
Passangers front: 36 1/2"
Drivers rear: 39"
Passenger rear: 39"
Hooked up trailer and raised the support, all weight on the truck with just a ball hitch:
Drivers front: 36 7/8"
Passenger Front: 36 3/4"
Drivers rear: 37 1/4"
Passenger rear: 37 1/4"
Trailer tongue dropped exactly 2" from perfectly level before hooking up to truck.
To keep Trailer level in transit I''d nee to get a received with 2" of less drop.
Anyone have any impressions from these numbers?
Seems the front end of the truck rise is not substantial BUT it is probably enough to screw up the alignment and affect tire wear negatively.
Old 07-30-2016, 02:55 PM   #5
1973 31' Sovereign
Middletown , California
I would live with that if it feels stable on the highway. Just put any cargo in the bed of the truck at the front and don't add weight to back of trailer. A trip to a scale would be informative but I'd bet the numbers would look good.
ijustlee is offline   Reply With Quote
Old 07-31-2016, 11:49 AM   #6
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
These are always decisions that you have to make for yourself. The best intentioned advice means little when you have issues. Strictly personal, I would never spend $40-100 thousand or more, on a trailer and assume I'll never have a WD or sway issue. Especially over a $500 to a $1000 hitch! I tow a 19c with a Ram 1500 eco diesel, I spend $600 on a Blue Ox WD hitch and it tows like a dream and that's well worth the peace of mind.
jtwind is offline   Reply With Quote
Old 07-31-2016, 11:55 AM   #7
Tao
Tao's Avatar
JTWind,
After pondering the question this weekend, I've decided to go "over kill". On my 3 other Airstream trailers I've always used a Hensley or a ProPride. hitch, even on the Anniversary 16 that I had. NEVER experienced one moment of "white knuckles".
Yes, overkill, unless you encounter the one moment you wish you had it!
Will go ProPride and just not enjoy as much ice cream this year, yeah, next year too.
Decision made,
Jack
Old 07-31-2016, 12:26 PM   #8
Gainesville , Florida
Sway control devices welded to ball mount, at least.
Old 07-31-2016, 02:23 PM   #9
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I have pulled on the ball with a TV like yours and have not had any trouble. My new 26U pulls very well.
larryglarson is offline   Reply With Quote
Old 07-31-2016, 02:28 PM   #10
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Silver City , New Mexico
The manís been very lucky... Driving 60-65 MPH may help in the modulation of the sway but it does not prevent sway from occurring... Weight distribution may not be so much of an issue but I would surely get an anti-sway hitch for safety sake. The reason theyíre called accidents is because nobody plans on Ďem...
Shoot, I drive with tin foil on my head but it still doesnít keep all the voices out...:
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 07-31-2016, 02:31 PM   #11
50KIP's Avatar
2009 19' International
Woodinville , Washington
This is my own personal experience: take it or leave it. I have a 2009 Sig. Intl 19 foot AS and a 19 foot 2006 F150. Perfect balance. I have towed with only the ball hitch. Never had a sway problem due to cross winds or semi-wake. Towed from Arizona to Yukon and Alaska. Sometimes I bring an ATV in back of truck which maxes out the GVW. But I have air suspension boost on rear truck axle. As for WD, if I had two axles on trailer I might consider it. If I remember my physics right, WD will distribute weight equally to front axle of tow vehicle and to trailer axle, I don't need any more weight on my single trailer axle. I'm running on OEM GYM tires (second set) and have only had a single nail puncture. Other than being a little slow on mountain passes you would never know that trailer is back there.
DonS
"It's like magic, only real"
(Bud Light commercial)
Women and cats can do as they please, while men and dogs should relax and get used to the idea.(R. Heinlein)
50KIP is offline   Reply With Quote
Old 07-31-2016, 05:59 PM   #12
Tao
Tao's Avatar
"Shoot, I drive with tin foil on my head but it still doesnít keep all the voices out...:"
I had the same problem BUT I found using Reynolds brand of foil, then doing a "double layer" shield helped!
Old 07-31-2016, 08:13 PM   #13
dkottum's Avatar
Note that a w.d. hitch not only distributes the trailer hitch weight among the truck and trailer axles, it also distributes the weight of gear in the bed of the truck located behind the truck's rear axle.
This makes a more balanced truck than the truck with the same load in the the bed, but without the trailer. Another good reason to use a w.d. hitch when traveling with your Airstream.
Doug and Cheryl
Old 08-01-2016, 07:52 AM   #14
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I lean towards WD & sway control for all Airstream towing combinations
It is a small dollar investment when compared to the total, and a safety improvement for Family and fellow travelers that is well beyond monetary rationalization.
“Its better to have what you don't need when you need it, than not to have it when you don’t.”
RLC
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 08-18-2016, 01:33 AM   #15
Alluminati's Avatar
St. Louis , Missouri
Last month I readjusted our hitch from the ground up. We just bought our trailer from a private party who didnít know much about the physics of WD, but that was a whole lot more than I knew. We set it up the way he thought it should go, and thatís how we drove it for a while. I didnít know any better. Stopped at the CAT scales three weeks later, and realized our spring bars were way too light. So I muscled them up a notch for a huge improvement in handling. But then the bars were not level.
After we got home I took the whole thing apart. For our needs, we raised the ball two inches, and tilted it way out, adding four washers. Now the front fender is exactly the same height when unloaded, and the rear is down 1Ē.
So now Iíve towed with three settings. First with too much weight on the back axle, and too light in the front. The TV felt ďfloatyĒ. Second with radically improved weight. The steering was greatly improved, but the hitch was still maladjusted. Truck felt entirely under control. Very capable ride. Entirely satisfied even though we knew it wasnít ideal. Third, with the hitch spot on. Wow what a difference! Now the truck and trailer feel like a single unit. The truck had felt like it was competently carrying the trailer, but now itís not carrying at all. The engine is doing all the work.
You can competently tow in below ideal conditions. At least it can feel competent, but you may not know how much steering and brake control youíve lost.
But when everything is right, the difference is remarkable.
The Morgans
1989 Avion 34VB
Alluminati is offline   Reply With Quote
Old 08-18-2016, 05:04 AM   #16
Tao
Tao's Avatar
Mr. Mogan, Question
Thanks for your post. I installed the ProPride with 1,000 pound bars.
I've adjusting but just does not feel right to me. Goes from Porpose to rigid and harsh. Nothing in truck bed and tailer loaded VERY light as I travel alone, and with a smile these days!
I'd like to know, are you using the ProPride?
A shot of how you have rigged your "stinger"?
How many inches rise on the "jacks"?
Getting ready for a 10 day trip to Maine and I want it to tow better than it does at the moment.
Suggestions are welcome!
Jack
Old 08-18-2016, 08:59 AM   #17
Alluminati's Avatar
Iím still too much of a newbie to instruct others, but I am happy to share my experience.
Iím pulling a 34í 1989 Avion GVWR 9995, hitch weight 850.
TV is 2008 Toyota Sequoia 5.7L (401 ft lb torque ) with towing capacity 10K.
CAT scales says trailer axle weight 8600 fully loaded.
No idea how old my hitch is. It has no discernable brand markings. Itís a class IV with round spring bars. I donít have any pics of my hitch, and the trailer is parked a half hour from here. Iíll try to remember to take a few shots next time weíre out. How many inches rise on the jacks? Not sure I know what youíre asking, but I think the answer is 2.
The chains on the spring bars are welded on and showing some wear. I hitched up and took it to a local RV dealer for advice. He didnít have what I needed, but it was nice to have a pair of experienced eyes to look over my setup. He set some of my fears to rest, but raised a couple other issues. Most were addressed when I reassembled the hitch.
The dealer said it looked like I had 800 lb spring bars, and suggested I move up to 1K lb. He said if theyíre too soft it will porpoise, but if too stiff, it will make my ride harsh. This may explain why your ride is so uncomfortable if you have 1K spring bars on a 19í trailer with 500 lb hitch weight.
Since Iím operating at about 90% of my TV capacity, I do watch how things are loaded. I donít carry excess baggage heavier than a pillow in the truck, lol. Everything gets stowed in the trailer.
The Morgans
1989 Avion 34VB
Old 08-18-2016, 11:04 AM   #18
Tao
Tao's Avatar
Thanks for sharing, I appreciate it.
Think I need to find a site to have my rig weighed.
Who is/has towed with a 2010 GMC SIERRA 1500 SLE CREW CAB? Happydays Towing, Tow Vehicles & Hitches 11 10-31-2013 11:31 PM
Crew Cab vs. Extended Cab moosetags Tow Vehicles 43 02-01-2012 03:40 PM
Chevy Colorado/GMC Canyon (Crew Cab only) Apache_Camp Tow Vehicles 8 02-01-2010 08:23 AM
Extended Cab or Crew Cab 2500HD w/Duramax for TV??? TomR Tow Vehicles 19 01-31-2007 06:27 PM
Ford F-150 4x4 Crew Cab TV? Buzzy4 Tow Vehicles 4 07-17-2005 07:54 PM
