Originally Posted by jcl
Are these the same truck, loaded to the same conditions, apart from the trailer on the ball in the attached scale ticket?
You have added 1880 lbs to the rear axle?
If so, if you had WD installed and set up correctly, just think how much closer to your desired 50:50 front:rear axle weight ratio you could get.
I don't think there is an exact ratio for weight distribution that anyone will agree on. I can only say that I will never use a wd hitch unless i need it to keep my rear axle from overloading or having my headlights point at the sky. The rig loves load on the rear axle. It tows solid as a rock and the truck is level.
