Old 06-08-2014, 02:50 AM   #1
2008 31' Classic
Lake Charles , Louisiana
Install Receiver on Classic 31 To Tow Jet Ski
Any thoughts on installing a receiver in order to tow a small jet ski? Any aftermarket recommendations? We have a Yamaha Wave Runner I would like to be able to tow behind. Thanks
Steve & Mary is offline   Reply With Quote
Old 06-08-2014, 03:28 AM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Yes, almost everyone here will say no to installing a hitch. The chassis of the Airstream isn't designed to do this. If you search these forums, you'll see that doing thus same thing just for a bicycle carrier will cause big damage (over time)
Please be prepared, as this querry almost always insights an opinion war!
Personally, I would not add a hitch either....
Old 06-08-2014, 05:40 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I would not add a hitch either. Mainly because of the extreme distance from the back axle of the Airstream and the new hitch ball.
Even small amounts of Airstream movement or trailer sway is going to cause the back trailer distress. Think of a whip being cracked.
Old 06-08-2014, 06:20 AM   #4
SteveH's Avatar
Common Sense , Texas
I've done it with a 24' Argosy and a 17' boat. Didn't like it. Didn't do it long enough to see if there would be any damage, but wouldn't do it again.
Regards,
Steve
Old 06-08-2014, 06:28 AM   #5
2008 31' Classic
Thanks for all of the good comments. I have pretty much decided it is a poor thought on my part. Thanks again..... steve
Old 06-08-2014, 06:35 AM   #6
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The wise man learns from the mistakes of others.
Depending on your tow vehicle, you might be able to rig up a lift on the corner of the bed (if you have a pickup with a long bed) and place the jet ski in the bed. That's a far from ideal solution, as well, though. Once you got to the lake or beach, you would have to figure out how to get the ski in the water.
Jet Blue's Mobile Airstream Classic 350 at Colonial Airstream Colonial Airstream Classic Motorhomes 21 10-02-2011 03:05 PM
Install 2 inch receiver on fiberglass Moho? myfirstrv Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 2 05-06-2008 05:41 AM
West b'docking ski slopes Turtle Boondocking 9 09-21-2007 10:02 AM
ski house bookvalue Member Introductions 15 01-22-2006 09:52 AM
Using AS as ski lodge? Bronze Dancer On The Road... 8 10-18-2004 10:54 PM
