Old 08-09-2013, 07:58 AM   #21
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Originally Posted by panheaddale View Post
Yes aftermarket controllers do light the brake light when manually activated. Check your information before GUESSING. Brake controllers are wired through the brake light circuit
The brake controller may be wired directly to the brake light switch, but the trailer brakes are not. They are activated by current from the controller. They run off a different pin and different wiring than the brake lights. Sending current to activate the brakes by using the manual lever does NOT send current to the brake lights. At least not with my controller.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
