Old 07-17-2016, 05:22 PM   #15
Box Elder (formerly of Center Moriches, NY) , South Dakota
If you got it in without hitting the wall, then you can get it out without hitting the wall. Reverse the procedure.
NY24 is offline   Reply With Quote
Old 07-17-2016, 05:28 PM   #16
2003 30' Classic
Fresno , California
Moving forward and turning left....
Here is how I see it. Unless you are turning left at a ninety degree angle without moving forward at all you should be OK. Moving forward while turning left will move you away from the wall without moving the rear into the wall. My Airstream always follows my tow vehicle....moving forward will move you away from the wall at the same rate as turning left....ONLY MY SIMPLE LITTLE OPINION....please always use a spotter when in any situation where you feel uncomfortable....you feel that way for a reason....trust your instincts.
ldireland is offline   Reply With Quote
Old 07-17-2016, 06:11 PM   #17
2015 22' FB Sport
Wethersfield , Connecticut
I back my 22 sport into my 100+ft driveway each time about 6 to 8 inches from a wall on my left (drvr side). I pull out slowly very gradually turning right and keeping an eye on the rear of the camper via my mirrors.
TinkersToy is offline   Reply With Quote
Old 07-17-2016, 06:53 PM   #18
2007 25' Safari
Attleboro , Massachusetts
Jeez...I have issues like that in my own driveway. I've been thinking of getting one of those trailer dollies that e-trailer sells so I can park my Airstream without the TV
romeb is offline   Reply With Quote
Old 07-17-2016, 08:26 PM   #19
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Sorry, but this is not true. As others have stated, the rear of the trailer will hit the wall if you turn away from the wall too quickly. I know because I've done it! Fortunately the rear clearance light on our Sovereign sticks out farther than anything else at that point so it took the hit. We ended up with small dent where the light was which mostly pulled out, and we had to replace the light. I also caught the end of the bumper on the wall which pulled the bumper off bending it at 90į where it attached at the other side of the trailer. No great loss there, the bumper was in poor shape when I got the trailer and there is no bumper trunk. I patched the bumper up and while it's obviously been repaired at least it looks no worse than when I got the trailer.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 07-17-2016, 08:32 PM   #20
2020 Classic 33 on order
Box Elder , South Dakota
So if you pulled into the wall going forward why not simply backup away from the wall?
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NōVPN
ghaynes755 is offline   Reply With Quote
Old 07-17-2016, 09:00 PM   #21
1964 26' Overlander
Milton , ON
If you're referring to my message, I was turning around in a parking lot next to a store and got careless about the amount of space I had. The piece of the building I hit actually stuck out a bit from the rest of the building. I wasn't actually parked next to the wall, just driving past it slowly and then turned away from it. I was completely aware that this could happen, but succumbed to a combination of fatigue, hurrying and carelessness.
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
Old 07-18-2016, 07:07 AM   #22
2015 27' FB International
Mary Esther , Florida
Walk ie talkie
Well first tv was Television,the to the walk ie Talkies we just use our cell phones no use having to push a button when you need both hands and eyes. Just get it straight shining with v is bow and right is starboard left is port like you finger 4 p O r T. Now just pull out slowly edging away from wall if the cell phone dosent start yelling you got it made��
Grateful2 is offline   Reply With Quote
Low Voltage Disconnect - Parallel Honda Generator One out of Fuel GeeSag Generators & Solar Power 11 07-15-2016 09:34 AM
2 gang wall box under 2 inches deep ? Zstream Electrical - Systems, Generators, Batteries & Solar 1 08-24-2013 04:04 PM
Can two more inches make a difference? ROBERTSUNRUS Hitches, Couplers & Balls 19 02-02-2011 10:22 AM
1953 Vintage Airstream Clipper 16 foot 5 inches eBay Watch Airstreams on eBay 0 02-27-2009 01:52 AM
