Old 08-22-2014, 08:18 PM   #1
1971 31' Sovereign
alta vista , Kansas
How will it tow?
I have studied many of the excellent posts on this site for months and have formulated a plan to begin renovation of my old AS. One large question remains before I begin. How well will a 71 Sovereign pull with either a 99 f 250 ld or a 84 f 250 diesel both 4x4? I do not want to waste my time if it will not pull comfortably in Kansas' normal 30 mph crosswinds. The hitch is a Eaz lift with 1000# bars and a Eaz sway bar. I regularly pull a 24 ft gooseneck stock trailer or 24 ft gooseneck flatbed with these trucks. My previous experience pulling "on the ball" with pickups is not good. I found pulling bumper hitch implement or stock trailers to be very unpleasant and felt unsafe. However, my goosenecks and fifth wheel trailers seldom cause any concern, even in heavy crosswinds. I have only pulled the AS twice--once with a 74 Chev Monte Carlo, not an experience to repeat, and once on the bumper of 6 cylinder f250 very slowly. Please, will this work or should I put the AS back in the hedge row. (I don't MIND being slow, just not unsafe.)
sascher is offline   Reply With Quote
Old 08-22-2014, 08:43 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Not familiar with that hitch, but based on price alone, may not perform as well as others typically discussed on here. But I'd think that trailer would tow fine with either TV. Worst case you might want a different hitch. The only way to know for sure is hook it up and try it out.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 08-22-2014, 09:16 PM   #3
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
I pull my 25' Trade Wind with a 2003 F250 Super Duty V10 manual. It pulls like a dream. But the heavy duty suspension of the F250 gives the AS a bumpy ride...which is not good. I am considering an Airsafe hitch, so the tongue of the AS actually rides on a commercial grade airbag and is effectively disengaged from the harsh up and down movement of the truck. Of course, the heavier I load the truck, the smoother the ride.
arktos55343 is offline   Reply With Quote
Old 08-23-2014, 01:59 PM   #4
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
We just did 9000+ miles towing a 34' Windjammer with an 01 F250 crewcab 4X4, automatic, v10, same WD sway setup. Got caught in 60 mph side winds in Nevada, slowed down a bit but no problems. It was enough wind to deploy the steps on the RV! Truck was a bit short on power leaving West out of Denver CO @ 7%+ grade.
sheriff1 is offline   Reply With Quote
Old 08-23-2014, 07:17 PM   #5
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
We pulled our 1977 31' Sovereign with one of our F250s and with a 3/4 ton Suburban. Can't remember what year F250 we had at the time. We have pulled all the trailers we have with an F250 crewcab diesel. Stock trailers, Airstreams and equipment trailers. I am not familiar with your hitch. Our experience with high winds and our Airstreams has been no problem.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 08-23-2014, 07:23 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
http://www.airforums.com/forums/f464/joy-in-driving-124322.html
Old 08-23-2014, 08:36 PM   #7
1971 31' Sovereign
alta vista , Kansas
Thank you for your very helpful responses. I feel much better about trying to tow the AS. What I take from this is that towing "on the ball" will likely be unnerving if any adverse conditions, no matter how slight, are encountered. Towing a 31 ft AS would likely be easier than most other comparable trailers. The use of a WD hitch with primitive sway control will make it tow even better. If this is still not as pleasant as I have become accustomed to with goosenecks and fifth wheel trailers, then ha/pp hitches are available. As I am cheap, I must note that a new pp hitch costs more than my TV, AS, and WD hitch combined.
Old 08-23-2014, 08:44 PM   #8
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I have an Easy lift hitch that I use to pull a 24' Argosy. I handles the trailer well. If you are concerned about sway, add another sway bar. That should help. A friend of mine has two on his hitch and he says they work great.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Can you tow a 31' with 12 a bhp tow vehicle? goatfarmer Member Introductions 6 06-30-2010 10:40 PM
Tow, tow tow your Airstream Hhthorny Towing, Tow Vehicles & Hitches 11 04-12-2008 12:06 AM
To tow or not to tow...that is the question. tkendall Tow Vehicles 10 02-09-2008 04:31 AM
Tow company vs. Tow Myself? Aluminati Brakes & Brake Controllers 4 10-14-2007 07:45 PM
