Join Airstream Forums Today
Old 01-24-2012, 02:05 PM   #1
GAT
Owner Spirit of "76"
GAT's Avatar
1976 31' Sovereign
Ball Ground , Georgia
How to level an AS
I know this has been answered several times but reaffirm for me. I recently purchased a new 2500 TV with a much higher ground clearance then my other one. Therefore I am going to have to purchase a new hitch shank with extended length and additional holes for the bolts. Can I assume that I can hook up the old hitch with the weight of the AS plus weight distributation on flat ground, measure the distance to the top of the ball and do the math to see how many more holes I need to get me to 19.5 inches. Do I need one more hole that could give me another inch or two. I think most standard hitches are six hole so eight or nine.It may not matter but I have a Curt hitch. Once the part comes in and the hitch is rebuilt then do I forget the ball height and measure the belt line front and back and level using that measurement. Am I thinking properly.?
Second question. Since I have to redo much of this set up and spend money on additional parts I considered changing completely to a hitch that doesn't use friction anti sway. Do Reece or Equalizer run in the 7 or 8 hundred dollar range and is that good money to spend or is a friction sway a reasonable way to go?
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
GAT is offline   Reply With Quote
Old 01-24-2012, 03:02 PM   #2
dznf0g's Avatar
Oswego , Illinois
I do not like friction controls on bigger trailers. Others will disagree. EQ is less than $500 and Reese dual cam is about $600. Shop around online.
These choices have been discussed extensively on other threads. Use the search function in the blue bar above, if you haven't read some of the threads. A LOT of info there.
My choice was Reese dual cam.
"All I want in this life of mine..... is some good clean fun" - Little Feat
Old 01-24-2012, 04:00 PM   #3
"CLOUDSPLITTER" (tahawus)
ROBERT CROSS's Avatar
Hoover Beach , "Niagara Frontier" NY
Images: 53
What I did.....
Get the trailer level unhitched...
Measure the height from the top of the socket to ground...
Select drop to match that measurement...
When hitched adjust wd to return trailer to level...
Visit CAT scales to check for proper weight distribution...
Level TV & trlr is the goal...
Others may differ...but that has worked fine with our Hensley.
Agree....research and shop around for the sway control.
Don't scrimp the Peace-of-Mind/safety factor is very important
IMHO.... our Hensely has been our best investment in that regard.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
How to measure to get Trailer and Tow Vehicle level Airperson Towing, Tow Vehicles & Hitches 11 08-24-2011 05:45 AM
Do I need to be level for water heater to work? sharptalk Water Heaters, Filters & Pumps 0 07-25-2011 01:02 PM
Tank Level Sensor - Just Learned Something AirsDream Plumbing - Systems & Fixtures 3 06-26-2011 04:15 PM
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 25 02-07-2011 12:46 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
